Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 08-14-2011, 10:40 AM   #226
BoostinChick
Member#: 218971
2007 WRX
Contact cement or super glue is your friend. I also pulled the material over the edges to make sure the adhesive had good contact with the object I was wrapping.
If you plan on keeping this as a permanent solution, you could also create micro abrasions on the object with a Scotch pad. Could always go back and plasti dip!
BoostinChick is offline   Reply With Quote
Old 08-14-2011, 12:20 PM   #227
Ketzer
Member#: 281795
2006 Foz XT
There is a specific adhesion promoter that is recommended for DiNoc.
It's called 3M 94. I couldn't find any locally and ended up ordering from a boating supply house (cheapest). I did a couple of pieces on my interior without promoter and they started to curl after a few days.
As many have said, a little heat does wonders. The DiNoc is pretty tough to do anything with cold but just a little warmth from a heatgun, hairdryer, whatever, and presto! Super easy.
Here is a youtube video of someone covering a sink in DiNoc, I wouldn't have thought this possible...
Get a couple of small pieces and have some fun with it.
Jeff-
Ketzer is offline   Reply With Quote
Old 08-14-2011, 12:39 PM   #228
goswald79
Member#: 119292
2003 WRX
Sonic Yellow
Hmmmmm....carbon fiber look sink in my kitchen....
goswald79 is offline   Reply With Quote
Old 08-14-2011, 02:35 PM   #229
AWDspider
Member#: 43748
just ordered some silver and pewter cf di-noc. im gonna be doin my dash and a/c vents.
shaun h
AWDspider is offline   Reply With Quote
Old 08-15-2011, 09:03 AM   #230
BoostinChick
Member#: 218971
2007 WRX
It's called 3M 94.
I used this and it's "ok". It dries VERY quickly so it's a bit difficult to work with especially since you have to switch from the 3M 94 stick/glue to the heat gun to work the Di-Noc over the edges or whatever.
Old 08-15-2011, 10:55 AM   #231
Ketzer
Member#: 281795
2006 Foz XT
Thanks for the headsup, I just got my can in the other day and haven't experimented with it yet. With daytime temps around 100 here, probably gonna be a real mutha to do any outside dinoc-ing.
Jeff-
Old 08-15-2011, 11:35 AM   #232
AWDspider
Member#: 43748
Just so you guys know, you can go to 3m's website and get free samples of any of their di-noc patterns. It's under the architectural coverings section. I got 7 pieces from them. They have a matte metallic silver that I'm thinking about wraping my car in.
Shaun h.
Old 08-20-2011, 03:21 AM   #233
2.5ReallySexy
Member#: 167943
My first attempt sucked because i cut out the square part wrong.
I couldnt figure out how to get the circle parts and curves to work
2.5ReallySexy is offline   Reply With Quote
Old 08-20-2011, 08:01 AM   #234
spyrule
Member#: 222703
2006 Impreza 2.5i
Crystal Grey
heat gun.
spyrule is offline   Reply With Quote
Old 08-20-2011, 12:20 PM   #235
CpnNeeda
Member#: 20060
02 WRX
Midnight Black Pearl
and for a first attempt that looks fine. Peel it off and try again.
This time, you need more Cow Bell (aka heat gun)
CpnNeeda is offline   Reply With Quote
Old 08-20-2011, 12:34 PM   #236
The1SloR/T
Member#: 251879
1998 Neon R/T 178whp
2010 Wrx Sedan WRB
I wanna Carbon DiNoc my toilet seat and see what my wife says
The1SloR/T is offline   Reply With Quote
Old 08-20-2011, 12:52 PM   #237
th30dd7
Member#: 281451
2011 Impreza 2.5i
Camellia Red
Please post pictures if you do!
th30dd7 is offline   Reply With Quote
Old 08-20-2011, 01:19 PM   #238
wrxnevox
Member#: 225281
08 Evo X,IS 300
Rally Red,Black
looks good!
wrxnevox is offline   Reply With Quote
Old 08-20-2011, 01:43 PM   #239
The1SloR/T
Member#: 251879
2010 Wrx Sedan WRB
I got free samples from 3M, playing with it now on my key fob to see if I can do it ( not really good with vinyl) Figured if I can do a key fob I could do anything
Not horrible for my first time, but I need work with heat and bending it around edges
Old 08-20-2011, 11:27 PM   #240
2.5ReallySexy
Member#: 167943
removed
Old 08-20-2011, 11:33 PM   #241
spyrule
Member#: 222703
2006 Impreza 2.5i
Crystal Grey
Not bad, but don't be afraid to pull it once it's warmed up. Does wonders to remove the sharp fold points.
cheers
Old 08-21-2011, 04:23 AM   #242
The1SloR/T
Member#: 251879
2010 Wrx Sedan WRB
cheers
Im Perfect wraping it around the straight parts, the bends I have a little trouble with. I did alot better with my 2nd fob
Old 08-23-2011, 03:18 AM   #243
2.5ReallySexy
Member#: 167943
Well my wife decided to give it a go and she redid the center console.
Old 08-23-2011, 08:37 PM   #244
BoostinChick
Member#: 218971
2007 WRX
The weave pattern is a different direction from the vents/cup holder to the body of the where all the knobs go...that would drive me nuts ha!
Old 08-23-2011, 08:59 PM   #245
02MillzRex
Member#: 206359
2005 WRX
CGM
^^^^^^ me too..... But looks good
02MillzRex is offline   Reply With Quote
Old 08-23-2011, 09:05 PM   #246
spyrule
Member#: 222703
2006 Impreza 2.5i
Crystal Grey
yeah, good job, but that would drive me biznana's!
So luckily, all you'd have to do is the vents a cup holder to re-match the pattern.
Other then that... good job!
Old 08-23-2011, 10:07 PM   #247
NutWagon
Member#: 230925
04 WRX Wag Stage 4
06 Impreza 2.5I
I second that with the pattern in different directions. Would eat me up inside. lol
NutWagon is offline   Reply With Quote
Old 08-24-2011, 10:34 AM   #248
robisunreal
Member#: 207807
1998 98 OBS red
2011 forester red
Default dash and back trim
Gave it a try, I think it looks nice. Will probably redo the dash piece, has some small problems and bubbles.
robisunreal is offline   Reply With Quote
Old 08-24-2011, 04:22 PM   #249
2.5ReallySexy
Member#: 167943
Ya i noticed it too but doesnt really bother me too much
Old 08-24-2011, 11:34 PM   #250
AWDspider
Member#: 43748
I used some of the extra for this
Before
after
was just testing to see if i like the color of the grips on the gun, if i did i was gonna order some similar in color. think im gonna go with a darker silver/grey
3m carbon fiber wrap xxscaxx Interior & Exterior Modification 13 05-17-2010 12:03 AM
3M Carbon Fiber-look self-adhesive wrap! Mach V Dan Interior/Dressup/Audio & Security 14 04-16-2010 09:11 AM
3M Carbon Fiber Overlay The Database Interior & Exterior Modification 17 04-01-2010 09:59 PM
3M Carbon fiber wrap upperguy General Community 2 07-22-2009 09:48 PM
The Official Carbon Fiber Thread thxmygoodman Member's Car Gallery 4 02-19-2008 10:04 PM
