Old 08-30-2011, 05:47 PM   #276
AWDspider
Member#: 43748
How are you guys keeping the di-noc stuck to your parts. I have a few spots where it was lifting after it sat in the heat all day. All the flat areas are fine but the tight curves would lift off. I used the 3m primer "pen" should I buy the can and be more liberal with it?
Is the 1080 better for this?
Shaun h
AWDspider is online now   Reply With Quote
Old 08-30-2011, 07:26 PM   #277
Ketzer
Member#: 281795
2006 Foz XT
Shaun h
Ketzer is offline   Reply With Quote
Old 08-30-2011, 08:36 PM   #278
AWDspider
Member#: 43748
does it really make that much of a difference. i used the primer pen but it felt like very little was coming out plus it dries up really fast (the pen itself).
Old 08-30-2011, 09:50 PM   #279
rsutton1223
Member#: 280744
2009 CTSV 1,216whp
Black Raven
You don't need the primer with the 1080.
rsutton1223 is offline   Reply With Quote
Old 08-30-2011, 10:14 PM   #280
Ethan_Drift
Member#: 264930
2011 GT, Evo 8
I'm ordering 3M 1080 tomorrow to do my 05 console swap. Hope it turns out good!
Ethan_Drift is offline   Reply With Quote
Old 08-30-2011, 10:20 PM   #281
AWDspider
Member#: 43748
so this stiff works that much better than the di-noc huh?. the di-noc sticks like a mother on flat surfaces...
i had some cheaper vinyl, oracal, and it didnt seem to shrink up so much after it cooled down like the di-noc does.
i just pulled off my di-noc because of it lifting. i guess i will be ordering some 1080, i was hoping i could find it local but i dont think thats gonna happen
Old 08-31-2011, 11:05 PM   #282
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Spent 20 min wrapping armrest with 3M di-noc film...
Old 09-01-2011, 10:52 AM   #283
BoostinChick
Member#: 218971
2007 WRX
Shaun h
See this post: http://forums.nasioc.com/forums/show...&postcount=230
Then this post: http://forums.nasioc.com/forums/show...&postcount=226
Works wonders
BoostinChick is offline   Reply With Quote
Old 09-01-2011, 08:50 PM   #284
AWDspider
Member#: 43748
Thanks for the reply.
I ordered some 3m 1080 the other day because what a few have said on here and I talked to 3m and they told me not to use di-noc on interior plastics with compound curves also, they didn't recommend using it on the exterior too
Old 09-01-2011, 09:08 PM   #285
AWDspider
Member#: 43748
Di-noc is gone
Shaun h
Old 09-04-2011, 06:35 PM   #286
ToxicCrucible
Member#: 254200
2008 WRX - 316hp
Rally Blue
My license plate delete was getting a bit nicked up so I fixed it up and added a piggy
ToxicCrucible is offline   Reply With Quote
Old 09-05-2011, 09:19 PM   #287
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Plastic piece by side mirror wrapped in 3M 1080. I had to apply some 3M adhesive spray in order for film to stick to curvy area.
1080 was easier to work on compared to Di-Noc since it stretches easily, but it was also easier to tear when pulling it.
3M di-noc (later removed and replaced w/ 1080 since it matches better with OEM stock carbon fiber interior pieces)
Old 09-06-2011, 01:18 AM   #288
O HELLA JDM
Member#: 292267
2002 Impreza WRX
nice work guys, does anyone have a diy thread or something so i know how to take apart my interior on a 02 wrx? i wanna try to cf some parts
O HELLA JDM is offline   Reply With Quote
Old 09-07-2011, 12:09 PM   #289
Duvanator
Member#: 217257
2008 2.5i hatch
Satin White Wrap
3m 1080, I covered all the silver on the dash, around the door pulls, and down the length of the console. I then added a red pinstripe following the dash line.
Duvanator is offline   Reply With Quote
Old 09-07-2011, 12:52 PM   #290
Duvanator
Member#: 217257
2008 2.5i hatch
Satin White Wrap
Also,
CF over amber reflector (bad pic)
CF eyebrow (INSIDE the lamp )
and CF front grill piece
Old 09-07-2011, 01:15 PM   #291
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Di-Noc is slightly thicker and the adhesive backing isn't as good on some surfaces. The 1080 forms easier around curves and in tighter cranks in the interior.
Di-Noc was not actually made for automotive applications like the 1080 is. The 1080 also isn't really glossy. It looks exactly like the carbon pieces in my friends 135i.
Do you have tips for sharp corners? Mine always creases. I've done a few different trim pieces and I have found that I have to make relief cuts to prevent that gathering crease
Louie is offline   Reply With Quote
Old 09-07-2011, 01:20 PM   #292
Gfunk720
Member#: 42549
E92 M3 M\\\
VW Sportvagon Oilburner
I have a 6'x2' sheet of Di Noc, if anyone is interested they can PM me.
I was planning on using it, but it sounds like the 1080 is better for what I am looking to do.
Gfunk720 is offline   Reply With Quote
Old 09-07-2011, 01:21 PM   #293
Duvanator
Member#: 217257
2008 2.5i hatch
Satin White Wrap
with the 1080, I just used a heat gun and patience, the 1080 is a dream to work with, apply a little head and it forms itself
a little trick I figured out is on curves wrap it over the edge and continue molding it to the back side of the piece (anchoring it in sorts) I haven't had any issues doing this (see my work one or two posts above) its been in so pretty hot temps and nothing has lifted anywhere (I didn't use any adhesion promoter either)
Old 09-07-2011, 03:18 PM   #294
ToxicCrucible
Member#: 254200
2008 WRX - 316hp
Rally Blue
yeah I used both and the 1080 is so much nicer and easier to work with. The di-noc seems a little more rigid than the 1080.
I would use the di-noc outside and the 1080 inside.
Old 09-07-2011, 04:22 PM   #295
spyrule
Member#: 222703
2006 Impreza 2.5i
Crystal Grey
Except, from what I understand Di-Noc was never intended for automobiles, and will remove paint/clearcoat on cars if removed incorrectly... 1080 will not.
spyrule is offline   Reply With Quote
Old 09-07-2011, 09:19 PM   #296
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
this stuff looks pretty good! does anyone know if the 1080 comes in matte/dry carbon? i'm debating what to do about my 10 year old interior.
lil'redwagon is offline   Reply With Quote
Old 09-08-2011, 12:09 AM   #297
sc00by4life
Member#: 97135
Di noc is designed specifically for fleet vehicle graphics. It will remove clear coat if you use adhesive when installing it, but will come off just dandy if you don't use any of the liquid adhesive.
Old 09-08-2011, 10:21 AM   #298
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Neither 1080 nor Di-Noc will stick to the Subaru interior pieces well, especially in areas with curve. I had to use 3M adhesive spray in order to make them stick.
Old 09-08-2011, 10:52 AM   #299
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Do you think it has to do with the way you prepped the pieces? I wiped everything down with alcohol, and had my interior trim pieces done in my legacy with Di-Noc and it never gave me any lifting issues.
Old 09-08-2011, 11:09 AM   #300
ToxicCrucible
Member#: 254200
2008 WRX - 316hp
Rally Blue
yeah same for me. it sticks fine
3m carbon fiber wrap xxscaxx Interior & Exterior Modification 13 05-17-2010 12:03 AM
3M Carbon Fiber-look self-adhesive wrap! Mach V Dan Interior/Dressup/Audio & Security 14 04-16-2010 09:11 AM
3M Carbon Fiber Overlay The Database Interior & Exterior Modification 17 04-01-2010 09:59 PM
3M Carbon fiber wrap upperguy General Community 2 07-22-2009 09:48 PM
The Official Carbon Fiber Thread thxmygoodman Member's Car Gallery 4 02-19-2008 10:04 PM
