Old 12-08-2011, 11:35 PM   #351
NutWagon
Member#: 230925
04 WRX Wag Stage 4
06 Impreza 2.5I
I just bought a few colors of tester sheets. Black sheet and a gold sheet. I wanna do a few lil things around the house and see how it goes.
NutWagon is offline   Reply With Quote
Old 12-08-2011, 11:57 PM   #352
corvid
Member#: 300097
are you guys using extra adhesive? Or does a hairdryer just get it to stretch and stick?
corvid is offline   Reply With Quote
Old 12-09-2011, 09:23 AM   #353
P-Train
Member#: 279233
2008 WRX
Originally Posted by nutinbuthehits View Post
How will that hold up to the heat?
P-Train is online now   Reply With Quote
Old 12-09-2011, 10:10 AM   #354
NutWagon
Member#: 230925
04 WRX Wag Stage 4
06 Impreza 2.5I
Im sure it wont! G.L tho
Old 12-09-2011, 10:44 AM   #355
kh15
Member#: 132400
I give that 5 minutes....
kh15 is offline   Reply With Quote
Old 12-09-2011, 10:45 AM   #356
P-Train
Member#: 279233
2008 WRX
unless........ You put a turbo blanket under
Old 12-09-2011, 11:04 AM   #357
NutWagon
Member#: 230925
04 WRX Wag Stage 4
06 Impreza 2.5I
15 mins then
Old 12-09-2011, 11:28 AM   #358
BoostinChick
Member#: 218971
2007 WRX
Why would you do something like that when you see how the material acts/expands with just hair dryer heat?!?
BoostinChick is offline   Reply With Quote
Old 12-09-2011, 01:36 PM   #359
stuinkuwait
Member#: 301597
I have done this with a couple different colors and love the way it looks. Like others have said ... its not that hard to work with and a heat gun really makes it easy.
stuinkuwait is offline   Reply With Quote
Old 12-09-2011, 02:04 PM   #360
fourmicah
Member#: 128760
2015 STI
Because it looks cool. That's it! It won't hold up long unfortunately.
fourmicah is offline   Reply With Quote
Old 12-09-2011, 02:11 PM   #361
BoostinChick
Member#: 218971
2007 WRX
What a waste of materials for maybe 5-minutes of "looking cool".
Old 12-09-2011, 04:57 PM   #362
daigledangle8
Member#: 253642
2008 Impreza 2.5i
SSM
What did you do to the the middle knob on the climate controls? Switch it out with something else?
daigledangle8 is offline   Reply With Quote
Old 12-10-2011, 09:12 AM   #363
Pcolasurfer89
Member#: 294775
Just a few things Wrapped: -wing
-width of the windshield on both sides
-hubcaps(only untill the I can afford some new wheels)
Pcolasurfer89 is offline   Reply With Quote
Old 12-10-2011, 09:25 AM   #364
daigledangle8
Member#: 253642
2008 Impreza 2.5i
SSM
^ not a fan of the wheels or the pillars..wing looks good though
Old 12-10-2011, 12:14 PM   #365
PlanB
Member#: 175608
2006 Impreza
1998 Honda VFR 800FI
Agree.
PlanB is offline   Reply With Quote
Old 12-10-2011, 01:38 PM   #366
NutWagon
Member#: 230925
04 WRX Wag Stage 4
06 Impreza 2.5I
Agreed!
Old 12-10-2011, 08:11 PM   #367
PunkRocket
Member#: 243132
05 STI
PunkRocket is offline   Reply With Quote
Old 12-11-2011, 01:17 AM   #368
nutinbuthehits
Member#: 214758
spray with high temp clear coat......you stand corrected.
nutinbuthehits is offline   Reply With Quote
Old 12-11-2011, 01:45 AM   #369
WinterSubie
Member#: 243234
2009 Hatch
^I don't think it'd be too much of a problem with the vinyl itself getting too hot. I would see the problem as being the glue backing getting too hot and seeping out, like if you leave a duck tape wallet in a hot car for too long...
WinterSubie is offline   Reply With Quote
Old 12-11-2011, 04:19 AM   #370
pho_shizzle
Member#: 181064
00' 2.5RS
BRP
Regardless, Im sure you will get smoking from the adhesive that will eventually melt. Also, not all "high-temp" clear coats are made equally and are "high-temp" rated enough lol. Vinyl is not made to withstand constant extreme temperature ratings. Even if you have to temperature set some 3M vinyl for it to properly cure into its new shape, I doubt over longed exposure to heat will help its resilience.
Please update us with how it goes though, Im interested. At least you can say you did it.
pho_shizzle is online now   Reply With Quote
Old 12-11-2011, 09:56 AM   #371
BoostinChick
Member#: 218971
2007 WRX
I will stand corrected if the vinyl lasts over a year in the engine bay. As already mentioned high temp clear coat won't withstand heat that the turbo heat shield takes on. Again, waste of materials unless you can provide actual evidence otherwise.
Old 12-11-2011, 11:04 AM   #372
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
The same can be said about your post, you have no quantifiable evidence to support your view. Let the guy try it and save your hate for the ....omg my car caught fire... Thread.
Louie is offline   Reply With Quote
Old 12-11-2011, 12:57 PM   #373
BoostinChick
Member#: 218971
2007 WRX
Actually, I do. I used it on a spark plug cover on a Evo MR with a clear high temp coat and its peeling from the edges and lifting up in certain places. If you want a pic I will be more than happy to provide.
The stuff is not rated for high temp under the hood applications, period.
Old 12-11-2011, 03:17 PM   #374
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
on metal or on plastic? Not that i'm trying to discredit you, I'm genuinely interested. I've had it on my alternator cover from killer b (aluminum) for about 7 months without issues. I didn't put clear coat over it, it seemed counter-intuitive to put it on.
Edit, it's not di-noc but the 1080.
Old 12-11-2011, 04:08 PM   #375
BoostinChick
Member#: 218971
2007 WRX
I don't think your alternator cover is going to see the heat like the turbo heat shield will. Like I said, if the person that posted found a way for it to work, more power to him, and I will stand corrected.
3m carbon fiber wrap xxscaxx Interior & Exterior Modification 13 05-17-2010 12:03 AM
3M Carbon Fiber-look self-adhesive wrap! Mach V Dan Interior/Dressup/Audio & Security 14 04-16-2010 09:11 AM
3M Carbon Fiber Overlay The Database Interior & Exterior Modification 17 04-01-2010 09:59 PM
3M Carbon fiber wrap upperguy General Community 2 07-22-2009 09:48 PM
The Official Carbon Fiber Thread thxmygoodman Member's Car Gallery 4 02-19-2008 10:04 PM
