Old 01-09-2014, 12:14 PM   #626
Preludicrous
Member#: 334356
2006 2.5i Wagon
SRR
See how it wrinkled and bubbled near curves & corners? Make sure you take your time. (my car is filthy, sorry)
Looks good on my guitar...
Preludicrous is offline   Reply With Quote
Old 01-09-2014, 12:35 PM   #627
Pingers
Member#: 257944
2009 Forester 2.5x
Satin White Pearl
^ You could probably take that piece off, apply some heat and see if the bubbles come out. I noticed you live in AZ, Tucson of all places so it's likely the temp inside your car is HOT, maybe over 200 degrees if you park outside in the sun which is what caused it to bubble.
Pingers is offline   Reply With Quote
Old 01-09-2014, 01:16 PM   #628
Preludicrous
Member#: 334356
2006 2.5i Wagon
SRR
Actually it did that while I still lived in VT. Eventually I will replace or remove it.
Old 01-09-2014, 06:28 PM   #629
Dmochowski
Member#: 306478
2016 Focus RS
stock
just ordered a 1'x2' piece to test some pieces hopefully it will work well with some heat and the primer pen i got
Dmochowski is offline   Reply With Quote
Old 01-09-2014, 09:58 PM   #630
easterbran
Member#: 307359
'05 STi Stage II
It was my first time working with vinyl so there was a learning curve. 3 hours the first day and an additional 2 hours the second day so 5 hours total. Probably could have been a lot quicker with more experience with it.
Ah that's nothing! It took me about the same time to do my center dash.
easterbran is offline   Reply With Quote
Old 01-09-2014, 10:06 PM   #631
Mr. Lin
Member#: 344988
2013 WRX STi
ISM
not the dinoc, but the other 3m stuff
Mr. Lin is offline   Reply With Quote
Old 01-09-2014, 11:21 PM   #632
RiskyRicky
Member#: 349901
2006 Subaru STi
SGM
Sorry for such late reply, but finally got some free time. I re-wrapped my center console again with the metro-restyling stuff 4d cuz it had lifted in a few corners. Peeling off the old left no residue but is was only on for 4ish weeks. I did prep all the major curves with the primer stuff. As noted before use caution this stuff is potent, use in a ventilated area.
Center console redone and did the rear window spoiler. Its been about 2months now and nothing has lifted. Contemplating doing my front lip.
RiskyRicky is offline   Reply With Quote
Old 01-10-2014, 12:24 PM   #633
Pingers
Member#: 257944
2009 Forester 2.5x
Satin White Pearl
^ Good luck if you decide to do your lip. I used one continuous piece, roughly 8 feet long by 1 foot wide and it was extremely hard to work with. Roll out a bit, heat, apply. I wish I had another set of hands. I guess it also matters what type of lip. The v-limited was no joke to wrap, but if you're wrapping a single flat section, that would be tons easier.
Old 01-10-2014, 01:32 PM   #634
Dmochowski
Member#: 306478
2016 Focus RS
stock
Been watching a couple tutorials and I was under the impression you had to stretch it on and after watching them that doesn't seem the case. I have seem them all just lay it on there use the tool to get bubbles out and use heat around edges and corners? Is that it?
Old 01-10-2014, 02:56 PM   #635
Pingers
Member#: 257944
2009 Forester 2.5x
Satin White Pearl
Depends on the piece. If it doesn't have many curves, it will be much easier to lay it on and heat it up. If you're dealing with something with many curves, the material will need to be stretched. It can be stretched a great deal without deforming the carbon-fiber pattern or ripping the vinyl.
One tip that I think has already been mentioned is that once the 3M 1080 is heated up once and then applied, if you decide to pull it up and re-apply heat it wont stick the same.
Old 01-10-2014, 05:35 PM   #636
PANNERZ
Member#: 375298
2011 WRX
IF ANYONE IS INTERESTED IN WRAPPING THEIR TRANSMITTER OR ANYTHING ELSE THAT IS SMALL CHECK OUT 3m WEBSITE JUST GOT MY CARBON FIBER SAMPLE FOR FREE GOT TO MY HOUSE IN 24 HOURS.
PANNERZ is offline   Reply With Quote
Old 01-10-2014, 06:19 PM   #637
easterbran
Member#: 307359
'05 STi Stage II
THANKS SO MUCH FRIEND
Old 01-10-2014, 07:09 PM   #638
Dmochowski
Member#: 306478
2016 Focus RS
stock
What is the size I just ordered one.
Old 01-15-2014, 11:19 PM   #639
Mr. Lin
Member#: 344988
2013 WRX STi
ISM
the rest
Old 01-16-2014, 12:50 PM   #640
Alex15
Member#: 316457
Originally Posted by Mr. Lin View Post
the rest
Did you wrap the long dash trim piece yourself?
Alex15 is offline   Reply With Quote
Old 01-16-2014, 01:04 PM   #641
Mr. Lin
Member#: 344988
2013 WRX STi
ISM
did all of it myself. first timer
Old 01-16-2014, 01:13 PM   #642
PANNERZ
Member#: 375298
2011 WRX
anytime man
Old 01-16-2014, 07:29 PM   #643
Alex15
Member#: 316457
Any difficult parts or tips? i'm going to be doing this soon. I've wrapped my roof twice and some other interior parts so I think I'll be fine.
Old 01-17-2014, 09:15 AM   #644
Mr. Lin
Member#: 344988
2013 WRX STi
ISM
you really have to take your time and cut a piece big enough to wrap it in one go. start on the side closest to the steering column and work your way over. use a blow dryer to warm it up for some of the curves. finally, when u get to the passenger vent, take your time trimming bc it's such an odd shape and u really want to make sure u don't have weird gaps in the vinyl. mine actually looks terrible there bc I did t do it right
Old 01-17-2014, 01:05 PM   #645
Jason P.
Member#: 376761
2011 Impreza WRX STi
Dark Gray Metallic
Just got finish with the 3M wrap/JPM alcantara install:
for more and a sort of how to check out my blog:
http://jasonphan.wordpress.com/2014/01/17/its-a-wrap/
Jason P. is offline   Reply With Quote
Old 01-19-2014, 09:45 AM   #646
Bak3rSkat3r
Member#: 328769
2005 WRB WRX
2007 UGM 2.5i
Well this was my first attempt at this stuff and it is far from perfect, and I'll probably end up re-doing soon but here's how mine came out. I went with the gloss black metallic 1080 wrap
(I know I need a new shift knob )
Bak3rSkat3r is offline   Reply With Quote
Old 01-19-2014, 11:50 AM   #647
Millhouse_5
Member#: 269208
95 JDM STI RA
08 2.5i Sedan
Love the steel vinyl and love the gloss, but what's not perfect in the gloss. Looks great from here.
Millhouse_5 is offline   Reply With Quote
Old 01-19-2014, 12:04 PM   #648
manys
Member#: 265277
1999 Outback
Legacy
This stuff is good only for flat or slightly curved parts.
Don't bother to do radio bezel for example because it will start to peel off from those tight corners and look like ****.
manys is offline   Reply With Quote
Old 01-19-2014, 12:54 PM   #649
easterbran
Member#: 307359
'05 STi Stage II
Originally Posted by Bak3rSkat3r View Post
Well this was my first attempt at this stuff and it is far from perfect, and I'll probably end up re-doing soon but here's how mine came out. I went with the gloss black metallic 1080 wrap (I know I need a new shift knob )
Looks real good!
Old 01-19-2014, 12:55 PM   #650
easterbran
Member#: 307359
'05 STi Stage II
Originally Posted by manys View Post
This stuff is good only for flat or slightly curved parts. Don't bother to do radio bezel for example because it will start to peel off from those tight corners and look like ****.
Hmm, I haven't run into any problems with mine. If you wrap it around the back of the curved parts then it's pretty tough for it to lift.
3m carbon fiber wrap xxscaxx Interior & Exterior Modification 13 05-17-2010 12:03 AM
3M Carbon Fiber-look self-adhesive wrap! Mach V Dan Interior/Dressup/Audio & Security 14 04-16-2010 09:11 AM
3M Carbon Fiber Overlay The Database Interior & Exterior Modification 17 04-01-2010 09:59 PM
3M Carbon fiber wrap upperguy General Community 2 07-22-2009 09:48 PM
The Official Carbon Fiber Thread thxmygoodman Member's Car Gallery 4 02-19-2008 10:04 PM
