Old 02-25-2011, 10:17 PM   #1
polarisboy385
Member#: 222041
2009 Impreza 2.5i
PRP
So I left work today and as I backed out I noticed two bright yellowish green fluid spots in the snow.
They were located along the exhaust piping
so I figured it was anti freeze.... No biggie, checked it when I got home, and it was a little low, so I topped it off. Then I headed out to dinner...
So in the middle of dinner my dad called telling Me to check my fluid before I leave cause there was a trail of discolored fluid in the driveway
So I checked my reservoir... It had settled a little.. Backed my car up but didn't see any fluid on the ground
Drove her home, but didn't notice anything out of the ordinary.
Any suggestions of what to look for?
Thanks for any help
polarisboy385 is offline   Reply With Quote
Old 02-25-2011, 11:17 PM   #2
Wrencher86
Member#: 250463
2010 Impreza 2.5i
Brake fluid?
What do you mean by "along the exhaust piping"?
Wrencher86 is offline   Reply With Quote
Old 02-25-2011, 11:29 PM   #3
subbiedoobie08
Member#: 216595
2000 2.5RS SWAP
white
i would think brake fluid if it's a yellowish color, but what you could do it let it sit a while on a flat floor, (garage) and jack the car up to see exactly where it's coming from. If then you still have no idea, refer back to us but i bet you can handle it at that point.
good luck!
subbiedoobie08 is offline   Reply With Quote
Old 02-26-2011, 12:40 AM   #4
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
A cat peed next to the exhaust as it was warm there?
Old 02-26-2011, 08:05 AM   #5
polarisboy385
Member#: 222041
2009 Impreza 2.5i
PRP
Originally Posted by Wrencher86
Brake fluid?
the spots were located roughly perpendicular underneath where the piping runs for my exhaust.... If I'm making any sense
Lol it looked like it for a second
Old 02-26-2011, 08:08 AM   #6
polarisboy385
Member#: 222041
2009 Impreza 2.5i
PRP
good luck!
Lol I parked where there is snow cover on my driveway when I got home so I will be able to see where the fluid is coming from....
Ill prolly take it to the stealership as it is still under warranty. And see if they'd be able to find it (but that's my last resort)
Old 02-26-2011, 12:06 PM   #7
polarisboy385
Member#: 222041
2009 Impreza 2.5i
PRP
doesn't seem to be anything leaking in the snow and all fluids check out
t hanks for the help guys! much appreciated
ill keep an eye on things over the next week or so
Old 02-27-2011, 07:56 PM   #8
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
The location of the drip can be deceiving. There are lots of places under the car that something can leak from, collect somewhere else, then drip from there. The cross-member for the transmission is a common low-point that fluid can leak on top of, then it can run over and drip in a place that isn't near the actual leak.
Best thing to do is crawl under with a light (and possibly a mirror) to try to find exactly where the leak is coming from. Header leaks can look like this, power steering fluid, plumbing from the radiator or heater core, etc.
Good luck, and hope everything works out for you
Rudgers73 is offline   Reply With Quote
Old 02-28-2011, 09:00 PM   #9
Thesystem3
Member#: 233014
2008 Impreza Hatch
Satin White Pearl
THE SAME THING HAPPENED TO ME!! I called the dealership and even though its under warranty they want to charge a $90/hr rate to see whats up -_- I also topped my antifreeze off as it was low and I have cardboard sitting under my car now but no leaks as of yet. Some one help us! Im confused as mine was in the back too!
Thesystem3 is offline   Reply With Quote
Old 02-28-2011, 09:42 PM   #10
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
this is really strange. Same thing happened to me this weekend.
Sun spots? Planets aligning? Subaru conspiracy? haha
I have an appointment on Thursday
Old 03-01-2011, 03:05 PM   #11
Bluefoton
Member#: 141373
2008 2.5i-hatch -
Collect a sample of it!
Old 03-01-2011, 04:23 PM   #12
PMMJKL
Member#: 217611
2000 Impreza RS
BRP
I have the same problem on my L. Looked as if it were coming from the PS lines, but the two fluids are very different colors, completely soaked my passenger's side suspension components, but there are no symptoms in the cars performance so I have no idea what the hell it is.
PMMJKL is offline   Reply With Quote
Old 03-01-2011, 04:48 PM   #13
ruckus racing
Member#: 196844
1997 Impreza L
flat black/green
stealership doesnt know what a warrenty is?! WTF... take it in, if they try yo charge you, get hold of SoA
ruckus racing is offline   Reply With Quote
Old 03-01-2011, 05:34 PM   #14
Gilgamesh
Member#: 234949
This also has happend to me and I can't figure it out, 06 2.5i. I whipped the car around in the snow so the back tires were spinning and then once I got out I noticed a few green drops in the snow. Can't figure out where it came from. It doesn't continue to leak but shows up whenever I lose traction and the tires are spinning. Any ideas? The only green fluids I'm guessing it could be are coolant or perhaps freon? But why doesn't it continue to drip out? I'm stumped
Gilgamesh is offline   Reply With Quote
Old 03-01-2011, 05:40 PM   #15
Wrencher86
Member#: 250463
2010 Impreza 2.5i
This sounds like a blown out strut. The seals go bad and the pressurized oil inside can leak.
This sounds like a torn CV boot. CV grease is green and too thick to drip on its own. Spinning a tire at high velocity can throw the grease out of the boot if it's got a hole or tear in it.
Old 03-01-2011, 05:43 PM   #16
ruckus racing
Member#: 196844
1997 Impreza L
flat black/green
freon...if it leaks, it leaks quickly, would about all be gone in the span of a day...and when it escapes, it's mostly a gas, but would leave a residue at the leak site.
so, its not freon...and its called R134a, and AC pump oil is clear
Old 03-01-2011, 06:02 PM   #17
Wrencher86
Member#: 250463
2010 Impreza 2.5i
Who are you responding to?
A/C systems can have slow leaks. PAG oil is clear though some manufacturers put in a green UV dye to aid in finding leaks. Shops will also do this if the car has A/C work done.
Old 03-01-2011, 10:41 PM   #18
Thesystem3
Member#: 233014
2008 Impreza Hatch
Satin White Pearl
^this Guy
That has to be it cus I was burning rubber trying to get out of the snow
Old 03-02-2011, 10:09 AM   #19
KootenayWRX
Member#: 119134
04 Fxt
02 wrxwgn
+++++ I had the same thing happen, It was the ac pump leaking. ****ty deal but thats the prob.
KootenayWRX is offline   Reply With Quote
Old 03-02-2011, 11:05 AM   #20
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
I used to hear this all the time from customers when I worked at SOA. What the dealer is actually (poorly) trying to say is that if they should inspect your vehicle and fnid an issue that is not covered under warranty, I.E. abuse, neglect, lack of maintnenace, mods, etc. you will be responsible for the diagnostic charges per hour of their time.
They will NOT charge you $90 just to look at it. If it is a warranty issue, the diagnostic charge will also be covered, as well as the parts/labor.
Samirr76 is offline   Reply With Quote
Identify this mystery fluid. White 2.5rs Off-Topic 28 08-23-2009 02:52 PM
The mystery house and mystery girl with mystery Porsche - Speculation Thread snvin Off-Topic 36 03-27-2006 02:51 PM
Mystery Fluid Leaking from my car? BrysImpreza Normally Aspirated Powertrain 4 12-30-2004 12:03 PM
STI VII boost spike mystery - can anyone in US solve the mystery? alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 05-18-2002 05:00 AM
