Old 02-26-2011, 03:19 AM   #1
pheonix991
Member#: 154173
2006 STI
Default Rebuilding replace oil pump? New tensioner assebly also?
Rebuilding a 2.2NA in the next couple months(buying car now, it is too cold to work on it now -15 right now). Since I'm going to be that deep, and the car has 160k miles, should I change the oil pump, or is there a way to refurbish it myself?
And, when I do the timing belt, would it be wise of me to get the updated tensioner assembly?
pheonix991 is offline   Reply With Quote
Old 02-26-2011, 05:36 AM   #2
Back Road Runner
Member#: 60082
2004 Forester STI
You typically want to replace all the pulleys and tensioner. Basically you want all new bearings. If one seizes, it means broken belt and damaged motor, so you just do it when the timing belt gets changed.
Old 06-24-2013, 05:43 PM   #3
scooby_x
Member#: 73130
2005 WRX sedan
Would that include replacing the cam gears? I would figure those are supported by the cam bearings so there should be no need to replace them unless the teeth look worn out for some reason? Thanks
scooby_x is offline   Reply With Quote
Old 06-24-2013, 06:39 PM   #4
pheonix991
Member#: 154173
2006 STI
A timing belt job usually does not include changing cam gears. Only reason you'd change the cam gears is if they are worn, or cracked. Which, if they're worn, or cracked, you've got other problems...
As a follow up on this, anyone wanting to do a timing belt on an older car, you should upgrade to the new tensioner. There is absolutely no reason not to.
How do I know? I work in an automotive pulley, tensioner and accessory belt engineering center.
Old 06-25-2013, 09:57 AM   #5
scooby_x
Member#: 73130
2005 WRX sedan
Thanks pheonix, I'll give the gears a close look for wear and cracking.
Replacing Oil Pump Seal? pittsburghscoobie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-21-2009 09:22 PM
08 STi Oil Pump.. New Norrberrt Private 'Wanted' Classifieds 0 09-28-2008 04:56 PM
replaced oil pump, now won't start sureshot007 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-06-2008 03:35 PM
replace oil pump at 117,000mi.? billtrev Service & Maintenance 5 12-08-2005 05:49 AM
Replacing Oil Pump on 1.8L - Advice Needed speedblind Service & Maintenance 10 06-06-2005 10:08 PM
