Old 02-26-2011, 07:48 PM   #1
05wrx89
Member#: 274159
06 sti
obp
Default best way to install oil pressure gauge
whats the best way to install a oil pressure gauge using the oil filter sandwich or i belive where the oil pressure sending unit suppose to be which i guess is behind the block
05wrx89 is offline   Reply With Quote
Old 02-26-2011, 11:47 PM   #2
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
Purchase the oil pressure relocation kit from Prosport: http://prosportgauges.com/remote-oil...ation-kit.aspx
(or buy a galley plug, a SS braided line and the proper adapter from SS line - sending unit) and use one of the oil galley plugs on top of your block.
There's two: one under the alternator where your stock oil pressure dummy light is and one under the turbo on the back of the motor. I personally used the rear one and left the stock dummy light plugged in.
ThreeEleven is offline   Reply With Quote
Old 02-27-2011, 12:56 AM   #3
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
If you use the galley plug under the alternator, and an oil pressure sender that is small enough, then you don't need to buy a relocation kit (or any other hardware at all).
I have the Defi oil pressure gauge and I installed it in the gallery plug under the alternator, and it was very easy to do. As I said before, there is no additional hardware needed. If you use a gauge with a larger sender, or if you use the other galley plug, then you'll need the relocation kit.
xluben is offline   Reply With Quote
Old 02-27-2011, 07:50 AM   #4
Sk8er
Member#: 129045
2004 Subaru WRX Sti
I have a great setup I will post pics when I get off work. my DEFi oil Press.temp are located on the Galley on the block below my intercooler piping.
Sk8er is offline   Reply With Quote
Old 02-27-2011, 11:49 AM   #5
Sk8er
Member#: 129045
2004 Subaru WRX Sti
Enjoy!
Old 02-27-2011, 12:19 PM   #6
05wrx89
Member#: 274159
06 sti
obp
so in order to get to the one on the alt i will need to remove the alt right?
Old 02-27-2011, 01:41 PM   #7
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
Yes, to get to the one on top of the block towards the front that holds the stock dummy light sensor, you will need to remove the alternator.
Old 02-27-2011, 03:00 PM   #8
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Removing the alternator is easier than removing the TMIC, IMO.
Old 02-27-2011, 04:39 PM   #9
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Yes, use the one under the alternator. Don't waste your money on a sandwich adapter. The one on the backside of the block is not prefered because you have passages that branch off before that plug/port (although it's better than nothing). The one below the alternator is right above the pump.
KillerBMotorsport is offline   Reply With Quote
Old 02-27-2011, 04:59 PM   #10
Supraru
Member#: 23313
99' 2.5Rs
black
I bought prosports and am just being lazy and not installing them. My first attempt I went to thread in at the stock location and it seemed like it was the wrong size but just by a tiny bit. I will probably buy the sandwich plate for now.
Supraru is offline   Reply With Quote
Old 02-27-2011, 05:16 PM   #11
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
Did you buy the Prosport Oil Galley adapter?
The stock pitch is 1/8" BSPT while the Prosport (and most other) thread is 1/8" NPT, IIRC.
Old 02-27-2011, 05:16 PM   #12
05wrx89
Member#: 274159
06 sti
obp
well i gotta change my trans oil anyway so i gotta remove the tmic so i can fill the trans back up so ill prob get the one in the back.....
also what power source did any of you use for the backlight for the gauge
Old 02-27-2011, 05:18 PM   #13
05wrx89
Member#: 274159
06 sti
obp
Originally Posted by Sk8er View Post
Enjoy!
what boost gauge is that
Old 02-27-2011, 05:18 PM   #14
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
I used the clock harness.
Old 02-27-2011, 05:49 PM   #15
Supraru
Member#: 23313
99' 2.5Rs
black
crap, didn't realize this. Glad it just didn't crank on it. With this adapter does that sending unit fit in there pretty good? It looked like it would be cutting it close fitment wise.
Old 02-27-2011, 06:13 PM   #16
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
The Prosport oil pressure sender is pretty large. Haven't seen the available space on the RS, but you'd be cutting it pretty close (if it even fits under there) on an 02-07 WRX/STi. I'd personally get the relocation kit for that one. Not to mention the Prosport senders have a reputation of cracking/going bad, so to remove the alternator every time you had to replace it/troubleshoot it would be a PITA, IMO.
Old 02-27-2011, 06:23 PM   #17
Supraru
Member#: 23313
99' 2.5Rs
black
I'm running an 04 wrx engine and will soon have an 08 sti engine in there. I guess I'll give it a try. Just gotta get more wire so it can reach to where I need. It takes me 5 minutes to pop off the belts and alternator. Just seems like the easiest option. I'd rather that then popping off my intercooler with a relocation kit. Only other option would be the sandwich plate which people seem not to like. I've also heard they tend to leak but not sure if that's installer error or not.
Old 02-27-2011, 06:26 PM   #18
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
You can use the relocation kit with the one under the alternator. It's just a braided SS line that screws into the galley plug with another fitting on the other end that the sensor screws into.
Old 02-27-2011, 06:31 PM   #19
Supraru
Member#: 23313
99' 2.5Rs
black
I guess in the end I will just buy the adapter and the sandwich plate. If it doesn't work out well I'll just throw that on there real quick so I can just get my gauges in.
Old 02-27-2011, 06:39 PM   #20
Sk8er
Member#: 129045
2004 Subaru WRX Sti
That is the Turbosmart Eboost 2 boostcontroller
Old 09-23-2011, 11:51 PM   #21
SUBIEBOI91
Member#: 294433
2015 sti
white
I had a question when you use the galley under ther alternator do you need a tee fitting to hook up the stock sensor and the sending unit ?
How do yall do it ?
SUBIEBOI91 is offline   Reply With Quote
Old 09-24-2011, 09:21 AM   #22
Gtikid98
Member#: 290742
2011 WRX Ltd 5dr
Satin Pearl White
its on a 2011 but its a great write up
http://forums.nasioc.com/forums/show....php?t=2182561
Gtikid98 is offline   Reply With Quote
Old 09-24-2011, 10:21 AM   #23
b1aze
Member#: 284003
2010 Alpine 135i
How do yall do it ?
Just remove the stock one. It only registers as low pressure around 3psi. If you get to that point, you're screwed anyways. I used that galley for my oil temp install.
b1aze is offline   Reply With Quote
Old 09-24-2011, 11:31 AM   #24
klarowe
Member#: 284753
2004 WRX STI
World Rally Blue
a little offtopic, but do they make a dual purpose sending unit? Something I could put in the galley under the alt. for both oil pressure and temp???
klarowe is offline   Reply With Quote
Old 09-24-2011, 11:58 AM   #25
SUBIEBOI91
Member#: 294433
2015 sti
white
But will a light come on the dash if I just remove the stock sensor ?
Installing oil pressure gauge to 04 WRX ? playnine9 Electrical & Lighting 3 07-26-2006 05:57 PM
how to instal oil pressure gauge.. calistisun Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 05-19-2006 11:23 AM
Best way to mount oil pressure AND temp sensors? 2thAche Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 03-06-2006 04:15 PM
Installing Oil Pressure Gauge! barkall4 Normally Aspirated Powertrain 7 06-19-2002 12:31 AM
Installing Oil Pressure Gauge Sender JP Money Normally Aspirated Powertrain 19 03-01-2001 07:49 PM
