Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 02-26-2011, 09:10 PM   #1
scoobysnax86
Member#: 266325
2009 Civic Si
ASM
Default 02 rs hard to start when hot, need help asap!!
Have an 02 2.5 rs, that's hard to start when hot, have replaced the crank sensor, has fuel coming to the engine, will start and run perfect, it's just getting it started, what's going on? Coil pack possibly? Need some help!
scoobysnax86 is offline   Reply With Quote
Old 02-26-2011, 11:38 PM   #2
GrundleJuice
Member#: 165749
A failing coil pack or weirs can be bothered further by heat but usually there will be symptoms when already running and hot also, like misfires, not just difficulty starting. I would dig a bit more before swapping any parts that you would have to buy or find some known good parts you can swap in to test for free.
Old 02-28-2011, 11:30 PM   #3
xvwsubyrail
Member#: 266035
i was looking at alldata and there was a tsb for a coil breaking down by where the coil wires connect. you would see carbon traces and cracks on the coil and also in the cap of the wires. that could be a hot start issue to look at.
xvwsubyrail is offline   Reply With Quote
Old 02-28-2011, 11:45 PM   #4
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
Coolant temp sensor?
Jessekrs123 is offline   Reply With Quote
Old 03-01-2011, 01:04 AM   #5
mrride2low
Member#: 188461
2002 Impreza Wagon
vacuum leak??
mrride2low is offline   Reply With Quote
Old 03-01-2011, 03:39 AM   #6
gene4ace
Member#: 108210
swap starters as my corolla used to NOT start when hot only when cold, had to wait about 15 mins with hood open to re-start it, culprit ended up being the starter of all the things ehh....
gene4ace is offline   Reply With Quote
Old 03-01-2011, 12:41 PM   #7
scoobysnax86
Member#: 266325
2009 Civic Si
ASM
Found the problem, was driving through this crazy ass rain, and all my sensor harnesses got wet, had to take a can of compressed air to them and it fired right up.
Old 03-01-2011, 06:24 PM   #8
nasiocjunkie
Member#: 80864
I'll have the tuna.
No crust.
battery or alternator.
nasiocjunkie is offline   Reply With Quote
02 WRX hard to start bobdhead39 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-06-2009 12:39 AM
Hard to start when it is hot outside mslide Newbies & FAQs 1 07-19-2009 02:02 AM
Built motor doesn't like to start when hot. 5iveLug_EK Built Motor Discussion 9 08-16-2008 08:58 PM
93 legacy hard to start when cold diaper eater Service & Maintenance 3 11-08-2004 10:36 PM
94 Impreza hard to start when hot davy94 Technical Forum Archive 0 10-10-2000 02:21 PM
