Welcome to the North American Subaru Impreza Owners Club Wednesday August 20, 2014
Old 02-27-2011, 12:37 AM   #1
CGMDan
Member#: 127883
'09 C63 AMG '99RSTi
'05 CGM STi - RIP
Default needing advise. 6-spd -> RS
So I'm in the middle of installing a STi 6 speed into my RS. The motor is in the car, so we're putting it in from underneath. At this point though it doesn't want to fit.
We can't get it high enough to be able to attach it to the lower dowels coming from the motor. Right now if we raise it up with the input shaft just barely tounching, but not clearing the clutch bearing, it hits the top of the tunnel.
Anybody have any pointers?
The next thing we're going try is unbolt the engine crossmember and lower it slightly, trying to make the angle work better.
Bear in mind this is a full shop with transmission jacks and such. Not a driveway-car-on-jackstands install.
I've searched on here IWSTI and RS25 and haven't come up with anything.
CGMDan is offline   Reply With Quote
Old 02-27-2011, 09:12 AM   #2
KONKILR
Member#: 3190
2004 Impreza TS and
the Suxass racing mobile!
Try jacking the front of the motor up to tilt the engine. This will lower the rear of the engine and allow you to attach the trans. When the trans is removed the engine tilts forward unless it is supported by a jack.
A 6 speed will fit in a GC chassis.
jake
KONKILR is online now   Reply With Quote
Old 02-27-2011, 04:27 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Yeah, what he said. I would probably unbolt the pitch stop, too, to make it a bit easier to tilt the engine.
Old 02-27-2011, 05:24 PM   #4
KONKILR
Member#: 3190
2004 Impreza TS and
If he has the trans out then the pitch stopper is obviously out since it bolts the the trans case.
jake
Old 02-28-2011, 12:16 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Ummm... oh yeah. I was just testing you.
Old 03-01-2011, 03:56 AM   #6
Needsacar
Member#: 188919
2005 Wrx Wagon
CGM
Default What these guys said
As everyone before me said,
But I'll re-iterate, tilt the motor down. It will rotate a LOT more than you think. I was having a ton of trouble getting the 6-speed into my WRX, had a guy that had done it come over. All he did differently was tilt the motor down, after that easy as just pushing them together and bolting it up.
If you need slightly more details...
Rotate the engine down about as far as you feel comfortable. You can use a jack to do this (don't put the jack on the oil pan...read all the stories), or grab a hand winch and attach up at the top of the motor and then put the bolt for the pitch-stop back in and rotate the engine down with that (just don't pull too hard on the firewall)
Bring the tranny in as far as you can and start some bolts if you can.
Then keep working it closer and steadily raising the engine and tranny back up. This means that if you let off some tension from the winch (or the jack) make sure you raise the tranny jack at the same time or the bolts will bend or strip out the engine. Again it also depends on how close they are together and how many bolts you have in.
Hopefully that'll get you done...definitely was not fun moving that thing around under there...
Gl
Needsacar is offline   Reply With Quote
Old 03-01-2011, 11:13 AM   #7
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Jake and Patrick make me
Old 03-01-2011, 12:13 PM   #8
KONKILR
Member#: 3190
2004 Impreza TS and
What, am I funny looking?
jake
Old 03-03-2011, 12:15 AM   #9
CGMDan
Member#: 127883
'09 C63 AMG '99RSTi
'05 CGM STi - RIP
Thanks for the info guys. I was able to finish the swap the other day. I think we only had to install and remove it 3-4 times for various issues. I will say I don't know how people manage to do it without a tranny jack.
Old 05-05-2011, 01:12 AM   #10
johnpaul76
Member#: 71075
1998 Impreza RSTi
Faded Rally Blue
Installation is the opposite of removal...
johnpaul76 is offline   Reply With Quote
FS (NC/RTP Area): 60k 05STI 6 spd and 24k 05STI 6 spd CyborgX_CZ Drivetrain 12 07-05-2009 01:22 PM
5 spd-> STi 6 bugeye-brawler Newbies & FAQs 8 07-31-2008 08:17 AM
WTT: USDM 6-spd from STi for JDM 6-spd non-dccd o2sys Tri-State Area Private Classifieds 8 02-03-2006 10:25 AM
Need some 6-spd swap parts o2sys Private 'Wanted' Classifieds 3 01-24-2006 03:48 AM
6 spd conversion on 2002 2.5 RS? PunKidd Transmission (AT/MT) & Driveline 14 04-04-2003 12:35 AM
