Welcome to the North American Subaru Impreza Owners Club Friday May 22, 2015
Old 07-13-2002, 11:51 AM   #1
TaiChih
Member#: 3467
1998 Dinan3
Bleck
Unhappy help, does anyone know where....
Hi, does anyone know where the fuel pump relay is located in an RS? I'm not getting fuel when I crank the car and the fuel pump does not purge like it should when I turn the car to ON. any info would be greatly appreciated. thanks,Stephen
TaiChih is offline   Reply With Quote
Old 07-13-2002, 01:25 PM   #2
EddyRS
Member#: 1257
2000 GC8 WRX
93 RS-W Wagon (White) RIP
The Fuel-Pump Relay is located on the driver side, just behind the instrument cluster. So for us US base Subies, that would be the upper-LEFT. There are three relays there, I believe that it is the one closest to the front.
It is fairly hidden with all the wires there.
Note: The WRX is located on the passenger side. Only the GC8 style is on the Left side.
Hope this helps
Cheers
EddyL.
EddyRS is offline   Reply With Quote
Old 07-13-2002, 08:29 PM   #3
TaiChih
Member#: 3467
1998 Dinan3
Bleck
thank you. is the plug brown with a bunch of wires?
Old 07-13-2002, 10:07 PM   #4
8Complex
Member#: 922
04 FXT
Red
If you want to stop the fuel, go under the passenger side of the rear seat and disconnect both those plugs. That is much easier then fishing under the dash, IMO.
Old 07-14-2002, 12:37 AM   #5
TaiChih
Member#: 3467
1998 Dinan3
Bleck
Nick, I can't seem to get the fuel pump to ressurize. and my ECU is not getting main power
Old 07-14-2002, 12:53 AM   #6
8Complex
Member#: 922
04 FXT
Red
Start with the basics, like checking the underhood fuses and batter connection and whatnot? Check the battery to see what type of voltage it's holding?
does anyone know where the vss is on a 6 speed? efmd3 Transmission (AT/MT) & Driveline 0 03-30-2008 10:36 PM
so does anyone know where the Air Temperature Sensor is on a 99? Big_Hitter Texas Impreza Club Forum -- TXIC 3 10-20-2005 03:43 PM
so does anyone know where the shock sensor adjustment knob is on a 99 forester? Big_Hitter Forester Forum 3 09-23-2004 08:43 PM
so does anyone know where the shock sensor adjustment knob is on a 99 forester? Big_Hitter Texas Impreza Club Forum -- TXIC 1 09-18-2004 06:51 PM
Does anyone know where the sun is Templar South East Region Forum 9 03-18-2003 10:48 AM
