Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 02-27-2011, 03:31 PM   #1
daWagon
Member#: 72665
2002 wrx wagon
whtie, 6MT, vf22
Default My P1507 and P0507 throttle cable solution.
So I got these codes after I had my manifold off and want to share my solution since I didn't see it on here when I was searching for solutions and it could easily happen to others.
I was getting high, fluctuating idle, and misfires ... when I got on the throttle when driving it was great. I naturally thought IACV, and then started reading about the neutral switch being a possibility. Since I had the manifold off I also thought it could be a vacuum leak. After double checking everything, checking for leaks, it turned out to by my throttle cables. I tightened them by hand during the re-installation, and was going to go back and tighten them with a wrench but forgot. They worked themselves loose and stopped the throttle from closing all the way causing a horrible air/fuel mix and P1507/P0507 and idle issues.
If you're getting these codes, it's worth taking a look at you throttle cables before messing with the IACV and definitely before pulling your trans for the neutral switch.
daWagon is offline   Reply With Quote
Old 04-26-2014, 10:51 PM   #2
snobordboi
Member#: 149130
2002 WRB WRX
VF39 Brembos etc
Just bumping an old thread since this made me happy today, had both codes after a ton of work and 4 months of my car down. Was about to start messing with the IACV when I found this, loosened my cables and it fixed it.
snobordboi is offline   Reply With Quote
P1507 and throttle position Scooter923 Normally Aspirated Powertrain 4 08-20-2009 09:46 AM
Detaching throttle body from throttle cable..how? jcbluescooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-03-2008 01:28 AM
wtb: sti throttle cable and brake lights switch darkmist2k1 Private 'Wanted' Classifieds 1 05-20-2008 01:23 AM
Throttle cable problem and info hybrid gti 2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-22-2007 01:41 AM
TMIC and Throttle Cable Issues scoobyimprza Subaru Conversions 8 09-09-2003 08:14 PM
