Welcome to the North American Subaru Impreza Owners Club Friday September 4, 2015
Old 02-27-2011, 03:55 PM   #1
s94658
Member#: 247671
2007 Impreza 2.5i
Obsidian Black
Default 07 impreza- oil on spark plugs
I have a 2007 subaru impreza 2.5i with about 47k and while I was changing my spark plugs i noticed that they have oil on the top of them. The wire caps as well. Any ideas as to what is causing this? Maybe valve gaskets?
s94658 is offline   Reply With Quote
Old 02-27-2011, 05:31 PM   #2
Wrencher86
Member#: 250463
2010 Impreza 2.5i
There's not really anywhere else it could be coming from.
Wrencher86 is offline   Reply With Quote
Old 02-27-2011, 06:20 PM   #3
flstffxe
Member#: 155358
2008 Forester
Steel Silver
Spark plug tube seals.
flstffxe is offline   Reply With Quote
Old 02-27-2011, 06:28 PM   #4
Jose99
Member#: 164319
2013 STi/05 Rs
Silver Bullet
I've had this same issue before at 80K.If you search on google for impreza valve cover gasket kit there are some websites which sell everything you need as a kit.The kits include the valve cover gaskets,the spark plug tube gaskets and grommets needed to be replaced while your in there.I inserted below a link you can take a look at.http://www.google.com/gbproducts/...ek+Google+Base
Jose99 is online now   Reply With Quote
Old 02-27-2011, 06:42 PM   #5
spike_101
Member#: 160609
05 Outback XT
Definitely tube seals. My 04 had this too when I bought it at 44k miles.
spike_101 is offline   Reply With Quote
Old 02-28-2011, 01:39 AM   #6
s94658
Member#: 247671
2007 Impreza 2.5i
Obsidian Black
Thank you everyone for the help. I really appreciate it.
Old 02-28-2011, 11:37 AM   #7
maruksai
Member#: 233276
2009 2.5i Hatch
How many miles do you have on you 07 2.5i? I'm just wondering when I should expect something like this on my 09.
maruksai is offline   Reply With Quote
Old 02-28-2011, 12:08 PM   #8
newtothescene
Member#: 222368
2006 Cone Dodger
CGM
Oil on spark plugs >>> oil in spark plugs. Whew!! You lucky man ya !!
newtothescene is offline   Reply With Quote
Old 02-28-2011, 01:44 PM   #9
s94658
Member#: 247671
2007 Impreza 2.5i
Obsidian Black
It has about 48k
Old 02-28-2011, 01:51 PM   #10
BDZ
Member#: 246673
My 06 2.5i had the same thing at 98k miles. At 108k I did the timing belt and water pump and replaced tube seals, valve cover gaskets and adjusted the valves while it was apart.
Seals are moderately easy, there are good write ups on here on how to do it.
BDZ is offline   Reply With Quote
Old 03-01-2011, 11:49 AM   #11
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
mine lasted about 100k I think. I didnt change em until like 190k though, they werent leaking too badly, I just had it all done with the inevitably failing head gaskets were replaced..
Samirr76 is offline   Reply With Quote
Old 03-01-2011, 11:50 AM   #12
Samirr76
Member#: 4835
2003 Baja 5MT
BTW anyone who is less than 5yrs/60k miles should still be under warranty. Oil seals/gaskets fall under Subaru Powertrain Warranty. You should not have to pay for this repair.
Old 03-01-2011, 04:33 PM   #13
Dsilko
Member#: 226246
2005 Impreza 2.5 RS
I noticed this when i bought my car at 79k...I thought this was normal on these types of engines since it was my first subaru. Wow do i feel like an idiot.
oil was on the threads of the spark plugs
is this something I can do myself if I just buy the kit?
Dsilko is offline   Reply With Quote
Old 03-01-2011, 06:26 PM   #14
crimson2
Member#: 224756
04 ej207 JDM swap
yep..I have an 07 2.5i as well that had the exact same issue. The dealership found it actually when I took it to have my 60k service done. Should have been covered, however I took it in at 61k and got fuc**d.
They did replace my cat. converter at 74k when it kicked the bucket. It was warrantied to 75k..LOL. Would have been a nice $700 to replace it if I hadn't of been pissed off about another thing going wrong with this car with such little mileage and bothered to ask if that was under warranty still.
I figured since the 60k warranty was up nothing would be covered, but it paid to ask.
They really need to up the warranty coverage like everyone else has. I drive 30k+ miles a year and that warranty is pathetic.
crimson2 is offline   Reply With Quote
Old 03-01-2011, 06:42 PM   #15
maruksai
Member#: 233276
2009 2.5i Hatch
I found the same exhaust kit on Amazon for less.
Amazon.com: Fel-Pro Vs50561R1 Valve Cover Gasket Set: AutomotiveAmazon.com: Fel-Pro Vs50561R1 Valve Cover Gasket Set: Automotive
It's cheaper for me because I have amazon prime. Free 2 day shipping
Old 03-02-2011, 10:18 AM   #16
Dsilko
Member#: 226246
2005 Impreza 2.5 RS
I had this same problem on my 05rs, I think my post got skipped over. Just wanted to know if this gasket set is something I'm able to put on by myself before I order the set.
Old 03-02-2011, 10:38 AM   #17
Samirr76
Member#: 4835
2003 Baja 5MT
#1 You could have called Subaru or had the dealer call Subaru and request goodwill repair coverage, since you were only 1k out of warranty. Not a guarantee you would get it, but a very good possibility it would have been covered. SOA is pretty good about that.
#2 Subaru's standard warranty is reasonable and very comprehensive. The 100k warranties that some brands advertise cover very little and with alot of stipulations. If you really wanted more warranty coverage, Subaru offers it as an option, up to 7 years/100k miles. I got that on my Baja and it only added about $10 month to my payments over 5 years. Really a drop in the bucket. Other manufacturers do charge you as well, including the "standard 100k warranty" and just including it as part of the MSRP. Either way you're paying for it. With Subaru, you dont have to pay for it if you dont need it.
Old 03-02-2011, 11:29 AM   #18
BDZ
Member#: 246673
I would call it a mildly advanced procedure for a novice mechanic.
Some of the lower valve cover bolts on the '06 are a pain to get to and almost impossible to torque with a torque wrench.
The Valve covers are a little trickly to remove, you have to rotate them 90 to get them out.
Replacement is pretty straight forward just make sure the valve cover gasket remains seated during reassembly or you will pinch it and get an oil leak.
Take your time, follow the directions, have fun, and in a few beers it will be done.
Old 03-02-2011, 12:39 PM   #19
Jose99
Member#: 164319
2013 STi/05 Rs
Silver Bullet
Lol cool.Yea I just looked up the quickest example I could to help him out. Great price compared to going the dealership route though.
Old 03-02-2011, 03:10 PM   #20
Dsilko
Member#: 226246
2005 Impreza 2.5 RS
good enough, thanks very much for the input.
Old 04-11-2011, 10:20 AM   #21
soloz2
Member#: 260128
2014 WRX 5 Door
Ice Silver Metalic
Where can I find instructions for this?
soloz2 is offline   Reply With Quote
Old 04-11-2011, 12:03 PM   #22
Back Road Runner
Member#: 60082
2004 Forester STI
OP's car is new enough that it's still under warranty.
Old 04-12-2011, 04:20 PM   #23
DiscoBerry
Member#: 264156
2006 2.5i Wagon
Grey
spark plug tube seals i changed mine at 70k and had the same thing they are part of a valve cover gasket kit and leaking is very very common
DiscoBerry is offline   Reply With Quote
Old 04-12-2011, 05:22 PM   #24
TheDynamite
Member#: 230165
2007 NA Wagon
Its your valve cover gaskets and seals like mentioned above. It is actually a really easy job to do yourself. I did it with a mechanic buddy of mine and took about an hour. make sure you have extra oil and check the seals before you go for a drive.
TheDynamite is offline   Reply With Quote
Old 04-13-2011, 08:53 PM   #25
Ctnightster
Member#: 263479
2003 wrx
yellow
Is it necessary to drain the oil first? Need to do mine soon. Dripping onto my uppipe and smokes and smells. Figured if oil leaks out now, a lot more will come out with the cover off. Lol. Just want to make sure though.
Ctnightster is offline   Reply With Quote
Found oil on spark plug wires rubberman Service & Maintenance 6 10-25-2011 02:38 PM
STi, small amount of oil on spark plug BrandonWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 12-26-2005 02:31 AM
Oil on spark plug boots (even after new valve cover gaskets) FujiHeavyFreak Service & Maintenance 2 08-14-2005 12:30 PM
help oil on spark plug wires and scoobie Normally Aspirated Powertrain 6 04-11-2005 10:27 PM
Oil on spark plug wires normal HighTachPrez Normally Aspirated Powertrain 1 05-21-2003 02:36 AM
