Welcome to the North American Subaru Impreza Owners Club Wednesday September 17, 2014
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 02-27-2011, 07:09 PM   #1
jrigby
Member#: 256134
2005 Baja Turbo 6MT
Default Mythbusting the STI ecu swap and no cruise control
Ok so looking through a ton of threads on this, the cruise control issue seems to have carried from 1 thread (post#21. In it the guy used an ECU from an STI without cruise. In another thread, this guy claims that he did not lose cruise.(post#8)
There are very few people that have actually done the swap. I believe most of the talk on losing cruise control is hearsay. So if you have ACTUALLY swapped in an STI ecu, could you please comment on whether or not you lost cruise control, what year your Baja is, and can you confirm if the vehicle the ecu came out of had cruise?
jrigby is offline   Reply With Quote
Old 02-27-2011, 08:58 PM   #2
BajaSTI04
Member#: 121071
2004 Baja STi
TeamJDMFresh.com/CSJ
I have an 04 with and 04 sti ecu swap tuned open source with cruise control. I don't know if the donor sti had cruise control though. Hope that helps you out.
BajaSTI04 is offline   Reply With Quote
Old 03-10-2011, 07:43 PM   #3
bajaturk
Member#: 224600
2004 Baja Turbo
Regal Blue
I also have an 04 with an 04 STI Ecu swap. I DO NOT have working cruise control since the swap out.
bajaturk is offline   Reply With Quote
Old 03-11-2011, 01:53 AM   #4
jrigby
Member#: 256134
2005 Baja Turbo 6MT
Any way you guys would be willing to check the part numbers off your ECU's?
Old 03-11-2011, 04:49 PM   #5
BajaSTI04
Member#: 121071
2004 Baja STi
It will be hard for me to check since my car is down for a year or so and at my buddy's house. Sorry.
Old 03-18-2011, 05:54 PM   #6
jrigby
Member#: 256134
2005 Baja Turbo 6MT
OK, so I just tried an STI ECU in my 2005 baja and it was a no go for cruise. I know theres a few different versions and this was an older one. 22611AJ241, my baja's ecu is a 22611AJ960.
I know there's a cruise control module, and they have different part #'s. The forester also uses a different cruise module, and it still works with the STI ecu. So it may not be the difference. I've also been going over the wiring diagrams for the baja and the STI and I'm finding very minor changes but nothing thats a clear "swap this wire with that one."
Wiring diagrams if any one wants to take a look. I am far from educated when it comes to these.
STI cruise 1
STI cruise 2
Baja cruise 1
Baja cruise 2
I can get any other diagram if needed. Just let me know.
Old 03-20-2011, 01:12 PM   #7
bajaturk
Member#: 224600
2004 Baja Turbo
Regal Blue
if you are highly versed in electronics and are thinking about field hacking the wiring from a working module to a non working. Let me know how it turns out for you.
I attempted this early on and was quickly overwhelmed.
As you say there is no clear cut swap to make this an easy mod.
Old 04-05-2011, 08:59 AM   #8
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
Why wouldn't someone just use a FXT ecu? Wouldn't this be an easier route? I'd think these would be more identical and they have AP support also if that is what you are looking for.
Has anyone swapped it with a FXT ecu and kept cruise?
Ben
Old 04-05-2011, 12:26 PM   #9
kidjoe
Member#: 120797
2004 Baja Turbo
I believe the intent is to be able swap in the 04 sti ECU, turbo, injectors without tuning. With the FXT ecu they would still require a tune........same as keeping their Baja turbo ecu
kidjoe is offline   Reply With Quote
Old 04-05-2011, 11:17 PM   #10
PHATsuby
Member#: 13617
2001 Legacy GT back
Yea makes sense, but I thought the Baja did not have the AP support if someone wanted it over the open source. Also I feel like putting the STi ecu on there even though you have the injectors, turbo and TMIC still could be a bit risky. The heads are not the same. Maybe it has enough learning ability so it doesn't matter. Obviously if people have done it and logged their cars and it is knock free then that is good.
Ben
Old 04-06-2011, 02:51 PM   #11
singincanary
Will mod for Guinness
Member#: 77921
'02 Foz
'07 'beca, '08 OBXT
Did the Baja get smaller injectors than the FXT? In my '04 FXT I swapped the '04 STi ecu over without any issues, and without changing injectors since the STi and FXT came with the same sized injectors, just different turbo's and tmic's.
singincanary is offline   Reply With Quote
Old 04-06-2011, 03:38 PM   #12
Subie_Sleeper68
Member#: 166403
2006 Baja Turbo
Silver 340 AWHP 365 AWTQ
I keep seeing these questions come up.
I hope that everyone knows that all you need is a Utec Delta to use the stock ECU.
Subie_Sleeper68 is offline   Reply With Quote
Old 04-06-2011, 03:49 PM   #13
Subie_Sleeper68
Member#: 166403
2006 Baja Turbo
I've been running a FP 68HTA @ 21 psi for almost a year now.
EJ 257 with CPs.
EJ 255 heads.
Full supporting mods.
STOCK ECU, TurboXS Utec Delta & Tuned by Area1320 in Easton Pa.
Old 04-06-2011, 08:11 PM   #14
Hawk296
Member#: 14555
1995 Impreza L
Baja
The 04-05 Baja turbo is the same engine as the 04 FXT. It is the same injector as the FXT and the STI.
And the Heads ARE the same. the part number is the same. the cams are the same the valves are same etc. etc. etc. (of course later model EJ255 heads are different)
Hawk296 is offline   Reply With Quote
Old 04-06-2011, 08:22 PM   #15
Hawk296
Member#: 14555
1995 Impreza L
Baja
And I hope that everyone knows you can run the stock ECU without wasting money on a Utec.
Seriously though, people want to use an STI ECU so they can put on an STI turbo, intercooler, and exhaust and just plug and play an ECU with nothing else. And then all they have to do from there is an AP if they want something more down the road. So it is worth looking into.
There are tons of engine management options out there. factory ECU, Reflash of the factory ECU, piggyback, stand alone etc.
Old 04-07-2011, 01:32 AM   #16
jrigby
Member#: 256134
2005 Baja Turbo 6MT
This ^
I have no tuning knowledge and all the E-tuners I talk to want me to switch over to an STI ecu anyways.
Old 04-07-2011, 08:11 AM   #17
Subie_Sleeper68
Member#: 166403
2006 Baja Turbo
WOW. Hardly a waste man.
I started with a new 06 Baja Turbo.
I wanted STi power out of it. Sooo
I put the VF39 (standard STi turbo at the time) & STi TMIC on it.
Cobb had/still has NOTHIN' for Baja management & was less than helpful when I asked if a FXT unit would work. So I went open source, first.
The Baja was more fun, but nowhere NEAR an STi. Barely kept up with WRXs.
My fault, I didn't factor weight & driveline differences in when I only put STOCK STi parts on.
I got the Utec for quick map switches & more options for my tuner. A mix of open source & Utec tune on ANY Subaru ECU is IMHO the best of both worlds.
If someone just wants to go a little faster with STi parts & bolt ons it STILL let's the tuner do MORE than open source, because there are 5 selectable maps. Via push button. No cables, no waiting.
Rant\
Sorry, just got a bit torqued up at the "Waste" part. LOL
In ALL the trial & error I've gone through to get mine to reliable high horsepower (for a Baja) DD status, the Utec is by far the mod that made it easiest for my tuner.
Old 04-07-2011, 09:55 AM   #18
Hawk296
Member#: 14555
1995 Impreza L
Baja
Hey man just making a point. It was not intended as an insult.
I only said "waste" because you mentioned an STI ECU being a waste. It might be for you, but this thread is related to questions about using an STI ECU in a Baja, not if doing so is the best option for Subie_Sleeper68. If people are simply looking for an STI powerplant in a Baja, than a UTEC can be seen as a waste in the same sense, as it is not needed. Lets keep it on track for those who decide to go the STI ECU route.
In reality most people who don't have time, money or knowledge to do the ECU calibrations themselves (which is a majority) will go to a performance shop or person who has knowledge and experience doing so. These shops all have their opinion on what is the best engine management option and that is typically what they are most comfortable with or what they sell. Most of them can achieve the same results safely.
Your car has turned out excellent, probably one of the quicker ones around and you have done a wonderful job with it. But it's not for everyone. It comes off equally as harsh as I may have been when you come into their thread telling them the route they are going (which may be best for them or their tuner) is a "waste" That is all,
If you would like to further discuss this you can always send a PM.
As far as STI ECU use-
We need to know what model year Baja people have and what model year and number the STI ECU is and of course if cruise works or not. Hopefully we can find which ECUs will work with which Bajas.h
The forester XT and STI are both based on the Impreza platform. The Baja turbo was based on the previous generation Legacy platform when it was released and was the only car based on this platform in North America to be turbocharged so it is not surprising some things may be different.
Old 04-07-2011, 11:36 AM   #19
Subie_Sleeper68
Member#: 166403
2006 Baja Turbo
I see what you're saying.
Apologies to those who are trying to figure out the aforementioned issues with cruise etc. on a Baja with an STi ECU. I'm not sure if a Utec for an STi would even clear it up if it's a harness/ECU pin out issue.
I guess I got into a "Don't bother with ECU swap 'cause it's not needed mode" because of how MY build went.
I completely dismissed that people already HAVE the STi ECUs in their cars & are having issues. Again, I apologize for my one track solution attitude. I wish you all the best of luck. & I will recommend calling Germaine Riddick @ TurboXS in Gaithersburg Md. to see if a Utec for an STi will clear up the problem. Used ones can sometimes be had for 2-3 hundred. New are a bit more than an AP .
Good luck. I hope you guys find the solution you're looking for without having to buy anything else.
Old 04-07-2011, 10:55 PM   #20
PHATsuby
Member#: 13617
2001 Legacy GT back
bajaturk, is your car a manual or auto? I am curious if there is a difference in the canadian versions if yours is from Canada?
Obviously I'm assuming you all looked at this but I was comparing the 2004 Baja ECU pinout to the 2004 STi and they are identical, except the baja does have 2 CAN communication wires on B137 18 & 26.
Not sure if that matters or if the CAN is used on the cruise at all for the Baja. I need to look at the diagrams but there has to be an element we are missing if one 04 to 04 swap worked and another didn't. I can't believe there aren't more people who did this.
Ben
Old 04-08-2011, 02:20 PM   #21
honda killer
Member#: 239621
2005 Baja Turbo
Silver/Gun Metal
For those that have that did the ECU swap, and lost Cruise, is your Cruise Control Button Blinking; and are you stuck in OPEN LOOP?
honda killer is offline   Reply With Quote
Old 04-11-2011, 05:23 PM   #22
jrigby
Member#: 256134
2005 Baja Turbo 6MT
No, the cruise on off button lights up and stays lit when pushed. The dash light doesn't come on at all. Basically when you use the set/accel/cancel switch nothing happens.
Old 04-11-2011, 05:30 PM   #23
honda killer
Member#: 239621
2005 Baja Turbo
Silver/Gun Metal
Sounds like "the lights are on but nobody is home". Meaning the switch is receiving power, but the ecu isn't getting the signal.
I bet the cruise control button , on the STi, is mounted on the steering wheel not the council.
I bet you need to upgrade your steering wheel and center gauge cluster; or re-wire your cruise control button for the ECU's sake.
GL
Old 04-12-2011, 07:28 AM   #24
honda killer
Member#: 239621
2005 Baja Turbo
Silver/Gun Metal
Just for *****s and giggles would you mind hooking a code reader; and see if there's a CEL. Since the cruise control button is not recoginized by the ECU, I wounder if the center gauge cluster will eluminate the CEL light.
If you don't find anything the first time, then enduse a fault condition like:
-unplug the front O2 sensor (which will send a low/no signal)
-unplug the TPS sensor (sends a low reading)
-DO NOT unplug any TGV sensors, as they are a pain in the ass to install
-Unplug the MAF (sends a low reading)
Old 04-12-2011, 08:18 AM   #25
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
why just opensource tune the car.
ej255 with side feed, 04-05 are same size injectors as STI, yellow ones.
you would only have swap turbo & tmic. yes tbe would be helpful.
i understand the OP wanted to do. swap with out a tune.
but it stands to reason to get the most "reliable" power out of
the set up, a custom tune would be the way to go.
I have and still do tune utecs, stock ecu's, other forms of em.
but the easiest swap would be turbo, tmic & tune.
Seat swap = no cruise control fateo66 Electrical & Lighting 8 06-10-2010 12:46 PM
Already get CEL, no traction control light, and blinking cruise control! Shohin Newbies & FAQs 17 02-04-2008 01:08 PM
P0851 and no cruise control Twiztidunreal Transmission (AT/MT) & Driveline 2 06-08-2007 07:05 PM
CEL and No Cruise Control? Bearkat Service & Maintenance 7 04-04-2006 02:05 PM
airbag light is on and no cruise control wreckedWRX Service & Maintenance 3 01-24-2005 10:26 PM
