Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 03-24-2011, 10:19 PM   #51
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
great job. about time someone done a write up like this....wish i had something like this to go by on my first build.
spoolinred is offline   Reply With Quote
Old 03-24-2011, 10:22 PM   #52
biodude
Member#: 271720
damn some of you guys know a phenominal amount of stuff about these cars. Super impressive. Pretty good timing too as Im about to try to figure out what I want to/need to do with my S20 heads for my EJ22 build
biodude is offline   Reply With Quote
Old 03-24-2011, 10:30 PM   #53
stoke
Member#: 164513
2001 2.5RS+EJ20+VF34
'13 WRX Special Ed
Originally Posted by Homemade WRX View Post
See destroked EJ25
Also mean piston speed as you described is just tip of the iceberg for acceleration and speeds on the piston.
That's absolutely true - just offering it up as a possible addition, and something for people to consider before choosing an engine setup.
stoke is offline   Reply With Quote
Old 03-25-2011, 09:30 AM   #54
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I'll probably cover all the reciprocating dynamics. I've already started reworking the curves (since losing my jumpdrive) for instantaneous velocities, acceleration, displacement and piston loading. So I should have them up again in the coming week.
I plan to do two sets. One for EJ257 (as the standard in the US), EJ20 and then my +4mm long rod. The second will be an EJ257, EJ257 (+2mm rod) and 83mm stroker...the short rod ratio group.
Old 04-11-2011, 01:09 AM   #55
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Here's one added to the group..
Here is a stock 2.5L EJ255/EJ257 B25 combustion chamber to a 97mm bore.
FuJi K is offline   Reply With Quote
Old 04-15-2011, 08:26 PM   #56
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
once I get to a PC with photoshop, i'll edit the photos to show where to look for.
Old 04-17-2011, 12:24 PM   #57
dark_stalker
Member#: 278847
2002 wrx wagon
What about a 2.1 build?
dark_stalker is offline   Reply With Quote
Old 04-18-2011, 01:47 PM   #58
Homemade WRX
Member#: 33782
96 bastard child
^^^what about it?
Notice he posted the 2.35 stroker for EJ22 (for EJ20 as well)...you are essentially the same thing as the EJ22 but with the smaller bore and 2.12L instead.
Old 04-18-2011, 01:52 PM   #59
Prevent
Member#: 149114
This seems like the place to ask my question.
If you're using long rods in a EJ25 with a 79mm crank, do you change the location of the wristpin or ??
So the piston wont sit above the deck.
Prevent is offline   Reply With Quote
Old 04-18-2011, 02:02 PM   #60
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Rotated BW S256 6speed
So what would it look like with the 99.5mm bore, or even 100mm bore. It seems it's pretty flush with the 97mm bore, so would you have a lip there like on a 2.5L block/2.0L head hyvrid, but just smaller?
I know it's a bad thing on the hybrids, and just assumed the 2.5 chamber to the 2.5 block would be flush like it looks on the 2.2 bore/2.5 chamber in that pic.
Thanks for all your hard work on this epic thread!
morrocco88 is offline   Reply With Quote
Old 04-20-2011, 09:42 AM   #61
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
The B25 heads are right at 99mm at the very corner on the edges of the chamber. It's 97mm where the side of the chambers actually go into the head. However Subaru rounded off the sides of the chamber so instead of a sharp corner edge, it's a rounded edge.
I'll get you that picture soon
Old 04-20-2011, 10:41 AM   #62
Homemade WRX
Member#: 33782
96 bastard child
^^^yup, the put a radius all around the chamber. IIRC is about 98.5 or 99mm from the edge of the radii. so roughly a 1mm radius on the rounded edge.
Old 04-20-2011, 12:16 PM   #63
smokey07
Member#: 151683
[quote=FuJi K;33426982]
How about a 65.8mm crank with +6mm rods on a 2.0L bore NA build with ported heads and long duration cams? Maybe 14,000rpms?
quote]
has this been attempted?
i wonder what it'd sound like
smokey07 is offline   Reply With Quote
Old 04-20-2011, 01:10 PM   #64
Homemade WRX
Member#: 33782
96 bastard child
It's been discussed before. Financially it's pointless
I had commented about it in a thread somewhere on here. I'd had a customer (from when I had a vendor account) in a spec 2.0L class asking me about it I began to show him all the parts that would need to be custom. It's not worth the mountains of cash, even in a spec class.
Old 04-20-2011, 04:26 PM   #65
smokey07
Member#: 151683
Old 04-20-2011, 04:35 PM   #66
Prevent
Member#: 149114
bizump
Old 04-20-2011, 05:28 PM   #67
Homemade WRX
Member#: 33782
96 bastard child
yes, you would have to shorten the compression height
Old 04-20-2011, 06:11 PM   #68
Prevent
Member#: 149114
Gotcha, what i was thinking but wanted to confirm.
i was thinking you move the wristpin or change the compression height.. (which are both the same thing lol)
Old 05-09-2011, 12:03 PM   #69
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I'm going to get the STi head CC'd and also the modded EJ205 head CC'd (the one that I ported out to match the EJ257. I've heard from 56cc to 58cc on the EJ257 chambers so.... I just chose 57cc. .... lol we'll find out.
BRB!!!
Old 05-10-2011, 01:08 AM   #70
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Okies.. the STi heads are 57cc.
Old 05-21-2011, 11:46 PM   #71
driftingrotary
Member#: 234715
2003 wrx
charcoal
So is it going to be bad to match the 97mm bore with the b25 heads? Is it gonna be that bad that the head's end is just 1.5-2 mm bigger?
driftingrotary is offline   Reply With Quote
Old 05-22-2011, 12:01 AM   #72
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
actually it'll work just fine.
Old 05-22-2011, 12:15 AM   #73
driftingrotary
Member#: 234715
2003 wrx
charcoal
Awesome! XD thanks Fuji!
Old 05-31-2011, 10:24 AM   #74
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
a lot of build threads recently....
Old 05-31-2011, 10:31 AM   #75
Paidfor
Member#: 267815
Be in awe
dont hate .)
^^^^^^^^^^^^^^^ as there will be alot of "whats this noise" "whats that noise" lol Nah hopefully not you guys seem to know whats up in here.
Paidfor is offline   Reply With Quote
nj building n00b wants to build his own gaming desktop NJSwamplands Off-Topic 11 01-29-2010 03:50 PM
I want to build my engine... HELP! usmc 04sti Built Motor Discussion 1 08-30-2008 01:04 PM
to build up my 2.0 or to build a 2.5 pulser9 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-19-2007 08:13 PM
Wanting To Build Engine But Have Questions wrxxer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-04-2003 12:15 PM
I want to build a rally car... but I don't know where to start. majglow Motorsports 25 04-24-2002 12:55 PM
