Old 01-03-2012, 02:07 PM   #151
ripman
Member#: 305707
1999 WRX
WRC Blue
Thanks for your help Fuji.
ripman is offline   Reply With Quote
Old 01-06-2012, 04:33 PM   #152
ebong777
Member#: 244812
2004 WRX
This probably has been said, but I couldn't find it. If I were to build a 2.2 stroker and use a oem ej257 crank shaft how would that work if I'm using a phase one ej22 block?
Because if phase one blocks had thrust bearings at #3, but using a phase 2 crank which has the thrust bearing at #5
Noob question.
ebong777 is online now   Reply With Quote
Old 01-06-2012, 05:29 PM   #153
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I'd change the thrust to #5.
Old 01-07-2012, 09:15 AM   #154
ebong777
Member#: 244812
2004 WRX
how much do 2.2/2.0 hybrid stroker cost on average?
would i be able to use my wrx ecu for it?
Old 01-07-2012, 10:41 AM   #155
biodude
Member#: 271720
There's a lot of variables when determining cost. I can tell you what mine cost so far, but i bet you won't like it.
biodude is online now   Reply With Quote
Old 01-07-2012, 02:34 PM   #156
ebong777
Member#: 244812
2004 WRX
Do you mind telling me your set up and a ball park estimate?
Old 01-07-2012, 03:58 PM   #157
biodude
Member#: 271720
I'm in for about $5200.
I have an MPS built EJ22: +2mm rods and JE pistons to match ~ $2400
Then I bought JDM V7 heads ~$1000
Kelford 264's ~$900
and about another $900 in head work and misc parts (buckets, gaskets, ect)
if your sticking with your WRX heads you will use your ECU, but you would want to get tuned
Old 01-07-2012, 04:36 PM   #158
Nuke209
Member#: 108089
2003 WRX
NF Performance
Kelford 264's ~$900
Thats really good compare to what others have paid
U know who u are LOL
Nuke209 is offline   Reply With Quote
Old 01-07-2012, 04:58 PM   #159
ebong777
Member#: 244812
2004 WRX
Thanks bio.
I was thinking about buying a used ej22t short block for about- $500
ej205 heads- $0
ej257 crank- $350
pistons/rods- $1000??
gaskets,machine work, misc- $1000
I know I have to get the thrust bearing relocated to #5 and mill my heads to 96.9mm iirc.
any other major parts I'm missing?
Old 01-07-2012, 05:39 PM   #160
biodude
Member#: 271720
first off, group buys rock!!
and
if you add in all the little extras, like gauges, screwups and a bigger turbo of there's about an additional grand or so spent. But he did only asked about the engine
Old 02-09-2012, 10:15 AM   #161
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
these 2.1 drives nice. more torque than my 2.2. it's like a mini 2.5.
FuJi K is offline   Reply With Quote
Old 05-14-2012, 11:33 AM   #162
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I'll grab a few more pictures of these phase 1/phase 2 blocks as i have a few on hand at the moment. I'll get some bell housing bolt patterns
Old 06-08-2012, 01:23 PM   #163
Soarer
Member#: 134872
98 Legacy GT Wagon
STi Swap
Hey Fuji,
Any input on building a hybrid with ej255 shortblock out of a 2005 legacy gt with ej205 heads from a 2002 wrx? Any machine work needed? What head gaskets would you run?
Cheers!
Soarer is offline   Reply With Quote
Old 06-08-2012, 02:11 PM   #164
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Originally Posted by Soarer
Hey Fuji,
Cheers!
flared out chambers, minimal decking, i usually ask .002" and run oem 257 '04-06 STi hg.
Old 06-08-2012, 02:26 PM   #165
SpamMansXe
Member#: 15920
1999 White Mock 22B
SPB SAYS WATCH YO BACK...
Subscribed for hours of reading and learning!
SpamMansXe is offline   Reply With Quote
Old 06-13-2012, 12:33 PM   #166
Soarer
Member#: 134872
98 Legacy GT Wagon
STi Swap
Do you have an estimate on what compression ratio I'd end up with on this build after machine work?
Old 06-13-2012, 12:46 PM   #167
kakarot09
Member#: 182375
08 Sti
Wrbm
Well you said you're building the shortblock which usually means at a minimum forged pistons. So you'd need to say what pistons to even get a ball park figure. That ball park figure could also be pretty far off depending on what the machining is like on the chambers. If you flare them out to fit the cylinders you'd have to measure them to know the chamber volume.
kakarot09 is offline   Reply With Quote
Old 06-13-2012, 01:19 PM   #168
Soarer
Member#: 134872
98 Legacy GT Wagon
STi Swap
That question was directed to Fuji K. As I stated in prior post, I'm running an ej255 short block so, no forged pistons.
Old 06-13-2012, 01:50 PM   #169
kakarot09
Member#: 182375
08 Sti
Wrbm
I realize that but most people do not put stock pistons back in so the assumption would be that you were changing pistons in which case Fuji would need to know the same info. The block out of an 05 LGT uses the same pistons and crank as an sti which with stock 02wrx heads puts your compression ratio ~8.85:1. After machining the heads I'm sure Fuji can give a better estimate but I would say 8.5-8.6:1.
Old 06-13-2012, 02:06 PM   #170
Soarer
Member#: 134872
98 Legacy GT Wagon
STi Swap
Kakarot09, I appreciate your willingness to try to help out here but I think you're just muddying the waters of this thread. If you read the prior few posts, you'll see that Fuji K has all the pertinent info to answer the question. Also, if you read the prior pages of this thread or others on the differences between the ej255 and ej257 short blocks, you'll see that they use the same case halves and crank but different pistons. The ej255 has a lower compression ratio than the ej257. Not trying to call you out or anything, just trying to keep this thread on track with no misinformation. Let's let the guru Fuji K respond to the compression question, please. Thanks.
Old 06-13-2012, 03:05 PM   #171
kakarot09
Member#: 182375
08 Sti
Wrbm
I'll be happy to do that, and I realize that Fuji is the one people ask questions to because he is pretty respected on the boards, however to help prevent muddying the waters on the off chance that he didn't know the answer or that he misreads your post or makes a mistake etc, it is always beneficial to have more than one person answer the question to double check. It's the reason scientific journals are put up for peer review. Mistakes happen. For info in the future the EJ255 does not cover just one engine configuration. If you look at these charts
You'll see that the Sti and the 05 LGT do in fact share the same piston part number, and thus dimensions, and they share the same crank with the same stroke. That is the only information you need from the shortblock for the calculation.
I'm sure Fuji will chime in for you though He's a pretty helpful guy around here.
Old 06-13-2012, 03:26 PM   #172
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
it comes out to around 8.6-8.7cr.
The 05/06 LGT runs the same longblock as the same year STi. The '07+ LGT runs the same as '06+ WRX/FXT with D25 heads.
Old 06-13-2012, 03:32 PM   #173
Soarer
Member#: 134872
98 Legacy GT Wagon
STi Swap
Thanks very much Fuji K.
Kakarot09, I stand corrected. Thanks for the helpful info and putting up those part numbers. That is incredibly helpful! Where did you find those charts?
Old 06-13-2012, 03:54 PM   #174
kakarot09
Member#: 182375
08 Sti
Wrbm
No problem, I think the charts were initially posted by Jeff Sponaugle? I'm not positive, but they've been floating around for quite a while now. I wish he posted regularly still. He always had good info.
Old 06-13-2012, 04:05 PM   #175
Aczwild
Member#: 71721
Great thread, just spun a bearing in my '98 RS (Phase 1 EJ25) and will be swapping a EJ22T (Phase 1) in. Thank you very much for the time you put into this!
Aczwild is offline   Reply With Quote
nj building n00b wants to build his own gaming desktop NJSwamplands Off-Topic 11 01-29-2010 03:50 PM
I want to build my engine... HELP! usmc 04sti Built Motor Discussion 1 08-30-2008 01:04 PM
to build up my 2.0 or to build a 2.5 pulser9 Factory 2.0L Turbo Powertrain 13 05-19-2007 08:13 PM
Wanting To Build Engine But Have Questions wrxxer Factory 2.0L Turbo Powertrain 0 10-04-2003 12:15 PM
I want to build a rally car... but I don't know where to start. majglow Motorsports 25 04-24-2002 12:55 PM
Message Board Statistics All times are GMT -4. The time now is 08:40 AM.
