Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 07-23-2012, 03:59 AM   #201
Shylight
Member#: 209812
2003 WRX
Platinum Silver Metalic
Originally Posted by FuJi K View Post
which crank? it's basically the compression height that changes, and then given the combustion chamber cc, the piston manufacturer can size the dish to your desired compression ratio.
Wiseco now uses like oem if not the same c-clips for the piston wrist pin.
2011 STi crank, EJ255 (50cc) heads, EJ20 CDB
Shylight is offline   Reply With Quote
Old 07-23-2012, 11:58 AM   #202
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
is the bore of that block going to be close to 97mm at all? That's what the chambers width are of the 255 D25 heads.
FuJi K is offline   Reply With Quote
Old 07-23-2012, 12:19 PM   #203
Shylight
Member#: 209812
2003 WRX
I thought that in my case with EJ25 crank & rods the EJ20 block should be bored out to 97.5mm, no?
Old 07-23-2012, 04:07 PM   #204
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
i just don't know if there is enough meat on the EJ20 to bring it out to that size. If you sleeve the block you can go whatever bore you want.
Old 07-23-2012, 11:00 PM   #205
SpamMansXe
Member#: 15920
1999 White Mock 22B
2014 Plasma Blue GR STi
it'll work just fine. what are you afraid of? on a serious note, what turbo?
For the time being, Blouch TD06 20G.
SpamMansXe is offline   Reply With Quote
Old 07-24-2012, 10:36 AM   #206
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
after that?
Old 07-24-2012, 11:22 AM   #207
SpamMansXe
Member#: 15920
1999 White Mock 22B
Undecided but was debating a Dom 3.
Old 07-26-2012, 12:36 PM   #208
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
Question regarding using phase 2 heads on a phase 1 block:
Do the coolant passages meet up exactly or just enough to work?
Soarer is offline   Reply With Quote
Old 07-26-2012, 03:42 PM   #209
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
choose one, then the engine is built around it
Old 07-26-2012, 03:42 PM   #210
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
which block?
Old 07-26-2012, 06:27 PM   #211
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
guess what im doing lol!!!
stroked phase 2 ej22 je customs 9:1
s20 heads with sti chambers pnp +1s kelfords
gtx3071 with sti tmic ohh im ****ing excited.
in a 99 0bs with a spec b 6sp
NW2TONE is offline   Reply With Quote
Old 07-26-2012, 07:04 PM   #212
B.R.E.D
Member#: 289606
06 WRX
white
I know these guys with a sweet machine shop that can help you out with that....LOL...J\K
B.R.E.D is offline   Reply With Quote
Old 07-26-2012, 09:07 PM   #213
NW2TONE
Member#: 212509
your **** go faster
not sure what the joke is lol
Old 07-26-2012, 09:31 PM   #214
jura11
Member#: 255146
2001 2002 WRX Wagon
WR BLUE
We are went with 2.1 OBD(Open Block deck),currently running 490bhp and very happy
Spec of the engine:
Cosworth pistons
Manley Rods
ACL Race Bearing sets:big end and main bearing set
Cosworth baffled sump
10mm Modified Oil pump and water pump
12mm ARP Headstuds
Cosworth Stopper 1.1mm HG
79mm Subaru V8(EJ257) Nitrided Crankshaft
Cosworth timing belt kit
JDM WRX AVCS heads
But now we are looking to get 2.35L
Jura
jura11 is offline   Reply With Quote
Old 07-26-2012, 11:16 PM   #215
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
which block?
ej22t out of a legacy sport sedan.
Old 07-27-2012, 09:48 AM   #216
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
there is enough for flow. I ran WRX S20 heads and now WRX D25 heads. I did modify the HG for the D25 heads.
Old 10-18-2012, 07:21 AM   #217
subarugod91
Member#: 334939
hi i am rebuilding my ej205 and wanted to know if the ej205 crank shaft could take 10k rmp? i am debating about geting a after market one or not?
subarugod91 is offline   Reply With Quote
Old 10-18-2012, 09:47 AM   #218
CatfaceType-R
Member#: 81102
Use the jdm 2.0 crank, fuji has the part number, I pm's him about that a while ago.
CatfaceType-R is offline   Reply With Quote
Old 10-18-2012, 11:19 AM   #219
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
12200AA240 - 2L double cross drilled crank
12200AA330 - 2.5L new heat treated crank
Old 10-18-2012, 08:57 PM   #220
subarugod91
Member#: 334939
can i use the 2.5l in my ej205? i have heard of people doing it but would it have to be machined out a ton for it??
Old 10-18-2012, 09:48 PM   #221
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
As long as you're using a '99+ EJ25 crank, it will work. Don't get suckered into a '96-'98 EJ25D 2.5L crank. It will not drop in the EJ205 block and your connecting rod selection will be few if not one.
If you have any questions in my write up from the beginning of this thread, don't hesitate to ask. There are also other very knowledgeable and experienced members here who are able to help answer any questions that I can't.
Old 10-19-2012, 07:24 AM   #222
subarugod91
Member#: 334939
sorry going to post here again because i only have one more question. if i use the ej25 crank it will make it 2.1l right? and will i use ej205 or ej25 rods?
Old 10-19-2012, 11:22 AM   #223
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Yes the final engine displacement will be 2.1L. WRX and STi rods are the same length. You can use STi rods for more strength or simply go forged aftermarket rods made for WRX/STI if you are shooting for more power.
Old 10-22-2012, 12:06 PM   #224
greece1nfs
Member#: 335797
2006 Subaru Forester
Awesome info, I am trying to figure out what engines would fit on my 2006 Forester, this is helpful.
greece1nfs is offline   Reply With Quote
Old 11-01-2012, 06:14 PM   #225
subarugod91
Member#: 334939
hello im going to start my ej205 rebuild soon and want some opinions on the parts i have selected and what bearings should i buy.
-Brian Crower Stainless Steel Valves Subaru WRX STi EJ205 EJ257 STANDARD SIZE
-BRIAN CROWER STAGE 3 280/280 CAMS CAMSHAFTS SUBARU WRX EJ20 EJ205
-Brian Crower BC Adjustable Cam Gears for Subaru EJ205 WRX EJ257 STi BC8860
-Darton Dry Sleeves Subaru Impreza WRX EJ20 EJ205 EJ207 92mm-96mm
-Brian Crower BC1600 Valve Springs Kit Subaru Impreza WRX EJ205 EJ257 EJ257B
-VITON VALVE STEM SEALS SEAL SUBARU IMPREZA EJ20 EJ205 TURBO DOHC H4 16V 2003 03
-Subaru Heat Treated OEM Crankshaft for 2.5L
-Manley H-Beam 4340 Forged Connecting Rod Set of 4 EJ205 EJ257 EJ255 WRX STi
-Wiseco Forged Pistons Subaru WRX EJ20 EJ205 EJ207 2.0L
-02-05 2.0L Subaru Impreza WRX Turbo EJ205 MLS Full Gasket Set USDM
-gt35r? gt40r? gt45r?
-Turbo Front Mount Intercooler 31X12X4 - 3.0" I/O
-Injector Dynamics ID1000CC EJ205 EJ207 340lph Fuel Pump
-maybe nos kit? or water injections?
-all turbo supporting mods!
-have 3 inch exhaust
nj building n00b wants to build his own gaming desktop NJSwamplands Off-Topic 11 01-29-2010 03:50 PM
I want to build my engine... HELP! usmc 04sti Built Motor Discussion 1 08-30-2008 01:04 PM
to build up my 2.0 or to build a 2.5 pulser9 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-19-2007 08:13 PM
Wanting To Build Engine But Have Questions wrxxer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-04-2003 12:15 PM
I want to build a rally car... but I don't know where to start. majglow Motorsports 25 04-24-2002 12:55 PM
