Old 02-28-2011, 01:44 AM   #1
impreza boy 89
Member#: 274766
1997 impreza
Default Coilovers
can anyone tell me what years are the 2ed gen impreza. or can most parts like a coilover kit go on other year imprezas? from what i saw thay r the same up till 04 but not shor.
impreza boy 89 is offline   Reply With Quote
Old 02-28-2011, 02:28 AM   #2
awdorgtfo
Member#: 252252
2007 WRX Wagon
UGM
This is NA forum, post in Suspension..
awdorgtfo is offline   Reply With Quote
Old 02-28-2011, 07:12 AM   #3
Smezmerz
Member#: 223561
02 Tacoma/01 RS
white/ sedona red pearl
models are
GC/GM/GF- 93-01
GD- 02-07
GR- 08-current
All GD coilovers are interchangable with other GDs, same with GCs. However if you want to put GD coilovers on a GC you need to drill an extra hole for the rears as one of the studs wont line up. fronts mount up fine. GRB I don't think the match GC or GD
Smezmerz is offline   Reply With Quote
Old 02-28-2011, 08:47 AM   #4
impreza boy 89
Member#: 274766
1997 impreza
thanx alot guys
Old 02-28-2011, 08:54 AM   #5
Smezmerz
Member#: 223561
02 Tacoma/01 RS
edit: I made a mistake, if you want to put GD coilovers on a GC it requires modification.
Old 02-28-2011, 12:05 PM   #6
impreza boy 89
Member#: 274766
1997 impreza
what im trying to is put 2ed gen coilovers on my 97 impreza L 2.2 AWD and drop in 1 inch with 17" STI BBS rims
Old 02-28-2011, 01:55 PM   #7
Smezmerz
Member#: 223561
02 Tacoma/01 RS
I know that with the OEM GDB struts on the GC chassis, it sits high. Maybe if you do coilovers like you said and set them either all the way to the lowest point or close to that it will look good. I am not sure. Check out RS25 and search for it, there are some guys that have done it there
You will also have to drill a new hole for one of the studs on the top hat for the rear
Old 02-28-2011, 02:23 PM   #8
impreza boy 89
Member#: 274766
1997 impreza
that shouldnt be that bad to drill new holes but what were you saying about going to its lowest point like drop it almost all the way down like few inches off the roed?
Old 02-28-2011, 02:38 PM   #9
Smezmerz
Member#: 223561
02 Tacoma/01 RS
I mean if you set the coilover to it's lowest point it might just be where you want it on the GC. The GDBs have a taller strut iirc so if you have them at a normal setting for the GDB and then put it on a GC it might look really high
Old 02-28-2011, 03:23 PM   #10
impreza boy 89
Member#: 274766
1997 impreza
ok i understand u now my car is like that now looks high i hate it lol thanx for the info
Old 02-28-2011, 03:27 PM   #11
impreza boy 89
Member#: 274766
1997 impreza
i wont to swap a 98 GC8 EJ20 16v turbo in to my 97 impreza L it should be like a WRX and i also wont to go with a 411 5speed trany fromm what i hear its just as fast as most 6 speeds cars and with a few mods ill be siting at 315 to 340 HP to the wheels for about 6500.00 that why i wont to drop it this year cuz the new motor swap will have to happen next year hope you have an idea of what im doing
Old 02-28-2011, 03:45 PM   #12
Smezmerz
Member#: 223561
02 Tacoma/01 RS
I'd actually recommend the EJ207 instead of the EJ20K. They have a semi-closed deck as a opposed to an open deck block. Plus parts availability is better because the newer Japanese STis have 207s as well. And the EJ205 and EJ257 from the states work with the 207 IIRC.
I'd also recommend the 6 speed as well. My friend shattered an RA 5 speed here with one shift. the 6 speeds are much stronger.
For me the ideal swap in the US would be a JDM 207 with a 6 speed, however 257s are much easier to come by.
that is just my 2 cents
Old 02-28-2011, 04:04 PM   #13
impreza boy 89
Member#: 274766
1997 impreza
yah but its what almost 10000$ for the whole 6 speed set up
Old 02-28-2011, 04:13 PM   #14
Smezmerz
Member#: 223561
02 Tacoma/01 RS
http://www.rs25.com/forums/f14/t1512...s-goodies.html
This is 8000, but it is also RHD, with Brembos, and bugeye parts. You could sell all of that for a little bit too. Unfortunately it doesn't have DCCD
Old 02-28-2011, 06:40 PM   #15
impreza boy 89
Member#: 274766
1997 impreza
yah i saw that on ebay do you get alot of parts from there?
Old 03-01-2011, 03:20 AM   #16
Smezmerz
Member#: 223561
02 Tacoma/01 RS
no, I've actually never used them
Old 03-01-2011, 11:27 AM   #17
impreza boy 89
Member#: 274766
1997 impreza
well i just got the coilovers waitin on them to get here so thanx for every thing and all the info
Old 03-01-2011, 05:16 PM   #18
nasiocjunkie
Member#: 80864
I'll have the tuna.
No crust.
8k spring rates would pull a premium.
nasiocjunkie is offline   Reply With Quote
Old 03-02-2011, 06:30 PM   #19
michaelcisek
Member#: 238379
2000 Outback Sport
Two-Toned Silver/Brown
michaelcisek is offline   Reply With Quote
Old 03-02-2011, 06:39 PM   #20
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Originally Posted by michaelcisek View Post
you get a gold star!
Impreza boy gets minus eleventy billion points for not reading/following forum rules. maybe one day he will be impreza man... but probably not.
FS : SOUTH FL: Tein SS-P Coilovers WRX 02+ $1000 SHIPPED!! jorgeTOOlow Suspension/Brakes/Handling 14 09-04-2011 10:03 PM
FS : gc coilover sleeves. 02-04 wrx em1bugeye Suspension/Brakes/Handling 11 05-30-2011 12:24 AM
FS : BC racing coilovers (CA) Subiracer06 Suspension/Brakes/Handling 29 03-06-2011 07:59 PM
FS : Tein SS Driving Master Coilovers NJ thirdchild Suspension/Brakes/Handling 4 03-04-2011 07:07 PM
WTB : BC coilovers wrench set CHAZ08WRX MAIC Private Classifieds 1 02-27-2011 05:20 PM
