Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2015
Old 07-13-2002, 04:31 PM   #1
Camperguy
Member#: 21274
2002 Mc_Bains car
I use to have a WRX :(
Question I just did the boost sol mod and found a small brass restrictor in the line.
I just did the mod here. http://www.scoobymods.com/forums/sh...hp?threadid=542
But I did it a little different.I just ran a new hose from the solinoid to the T-fitting and put in a 3/16 T.
I noticed something strange in the tube between the T-fitting and the out put side of the turbo.There is a little brass reducer inside the piece of tubing it has a really small hole in the center of this plug...It looks like some kind of restrictor...Does anyone know what this thig does If you remove it will you gain or lose performance....Trinity help.
Thanks Bill(New Guy)
Camperguy is offline   Reply With Quote
Old 07-13-2002, 04:52 PM   #2
IMPREZIV
Member#: 862
Its a restrictor in the hose and it is needed. I know a manual boost controller wont work correctly without that piece. Dont lose it.
Pete
IMPREZIV is offline   Reply With Quote
Old 07-13-2002, 04:59 PM   #3
Camperguy
Member#: 21274
2002 Mc_Bains car
Damn..I just went to the Boostmonkey page and did some reading .I guess it`s the boost solinoid restrictor? What the hell does it do?...It looks like it limits the amount of boost the turbo makes? According to the info on boostmonkey if you remove it ,it allows the turbo to make 17psi of boost...yes ,no ,maybe?
Bill
Old 07-13-2002, 06:59 PM   #4
Camperguy
Member#: 21274
2002 Mc_Bains car
Have a Nice Day? Holy crap
There is alot of threads on this subject So it looks like I`ll put the stock T back in an get a Boost Monkey
I feel like a jerk...
Bill
Old 07-13-2002, 11:29 PM   #5
light12
Member#: 2198
HI.
quite the opposite removing the restrictor will give you less boost
the restrictor delays the signal going to the solanoid , solanoid opens a little later building a boost spike and so you get the car to boost to lets say 1.0 bar and drop to 0.8 steady .
if you can get/make a restrictor with a smaller hole ( i think the original is 0.13 m"m ) then you get more of a spike but also maybe fuel cut .
light12 is offline   Reply With Quote
Old 07-14-2002, 11:21 AM   #6
WizardBlackWRX
Member#: 14979
I believe it's not a delay insomuch as you simply get less pressure to the other side of the restrictor. If you make it smaller, you will get more boost, depending on where it is. This is what the 300ZX TT JWT kit does if I'm not mistaken. Someone should sell smaller restrictors for a free upgrade in boost. Then you can get factory ramped 16 psi of boost. I haven't looked at it much so I'm not sure if this is how it accomplishes things or not.
WizardBlackWRX is offline   Reply With Quote
Old 07-14-2002, 11:19 PM   #7
light12
Member#: 2198
you will only get a boost spike after that boost will return what ever your ecu sets , we tried different restrictors but they only change the spike .
Old 07-17-2002, 04:24 PM   #8
disco
Member#: 10089
I don't remember seeing this piece when I installed my EBC. Is it something that matters with the EBC? Meaning, how does it change the way an EBC works?
Thanks,
-disco
disco is offline   Reply With Quote
Old 07-17-2002, 04:31 PM   #9
cnk
Member#: 10757
2013 BRZ Limited 6MT
I don't think it matters with an EBC as an EBC is controlling the solenoids to give you the boost that you desire. With a MBC, there's no computer helping out. I replaced all the hoses and used the included hoses from my Blitz SBC-ID and everything works fine.
Calvin
cnk is offline   Reply With Quote
When installing the GM Boost Solenoid do you keep plastic restrictor in Vacume Line mrtrex Engine Management & Tuning 3 11-13-2005 12:16 PM
I did a boost leak test..and found some intresting leaks. BoostedAWD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-13-2004 08:56 PM
Replacing restrictor in the tubing to the OEM Boost Gauge Wacky Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-07-2002 01:47 PM
LINK Boost Sol. Working And She is Running Great (finally) redmeanie Normally Aspirated with bolt-on Forced Induction Powertrain 6 07-22-2002 07:13 AM
