Old 02-28-2011, 02:57 PM   #1
GodWhomIsMike
Member#: 102287
2014 Crosstrek Ltd.
Tangerine Orange
Default Blue Footwell Illumination Kit in a 2011 WRX?
Blue Footwell Illumination Kit in a 2011 WRX? Anyone do this? How does it look? Pics?
GodWhomIsMike is offline   Reply With Quote
Old 02-28-2011, 03:54 PM   #2
cheezmunky
Member#: 167627
2011 WRX Ltd Hatch
cheezmunky is offline   Reply With Quote
Old 02-28-2011, 04:36 PM   #3
Bruins1982
Member#: 240365
2011 WRX Premium
Sedan WRB
^^^ That's my car in the thread. I still like it a lot. If you're in to that sort of thing, it's a good kit for the money.
Bruins1982 is offline   Reply With Quote
Old 02-28-2011, 05:25 PM   #4
punjabi408
Member#: 218434
2000 2.5rs
BRP
really easy to install at home don't get it dealer installed.
punjabi408 is offline   Reply With Quote
Old 02-28-2011, 07:47 PM   #5
Strobe Media
Member#: 241600
2004 WRX STi
like a million whp
go look at a honda, but just imagine it was fast, voala.
Strobe Media is offline   Reply With Quote
Old 03-01-2011, 03:19 PM   #6
cheezmunky
Member#: 167627
2011 WRX Ltd Hatch
I have the red kit and enjoy it quite a bit as well. If you like blue better, go for it. The only real debate is whether or not to replace the stock red cubby light with a blue one
Old 03-01-2011, 03:50 PM   #7
jonklein611
Member#: 117776
2011 WRX Limited 5dr
WR Blue Pearl
I got the blue kit and got a blue cubby light from someone on here. The older WRX's came with the blue light and the STIs got the red cubby light, so lots switched. If not they are quite cheap to get.
jonklein611 is offline   Reply With Quote
Old 03-01-2011, 04:44 PM   #8
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
I got it done a very ghetto way. Will post pics eventually, but it involved a set of white LED strips bought online for pennies, a 3 Ohm resistor as the said LEDs would fry @ 14V, and wires hooked up in parallel to the dome light. The former required some gymnastics to avoid prying the entire roof up, but I managed to slip the wire in between the dome light and the front left corner where the A pillar arrives (had to unscrew the sun visor to reach). The LED strips were glued under the console, and I put scotch tape on them to further diffuse the light. Works nicely, and it dims out along with the dome light
Old 03-02-2011, 02:01 AM   #9
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
The concept is simple.
Mount your LEDs in a desired sport and tap into the power from your dome light and connect to a ground.
Smoke is offline   Reply With Quote
Old 03-02-2011, 11:26 AM   #10
Bruins1982
Member#: 240365
2011 WRX Premium
Sedan WRB
You can always use the parking light wire too. At least then the light would come on like Subaru's kit does. When the lights are on.
Old 03-02-2011, 05:22 PM   #11
Strobe Media
Member#: 241600
2004 WRX STi
like a million whp
i'm sorry but none of you find that a little.....i hate to say it.......ricey?
Old 03-02-2011, 06:25 PM   #12
Bruins1982
Member#: 240365
2011 WRX Premium
Sedan WRB
It's definitely not for everyone.
Old 03-02-2011, 06:36 PM   #13
Hailwood
Member#: 64077
2016 VW GTI
Racist
Not really, it's actually a fairly subtle effect, similar to the center tray light. It adds a bit of accent at night, but isn't in-your-face at all.
I added the red kit to my '11 and am quite pleased with the results, as I too was a bit worried it would be too much.
Hailwood is offline   Reply With Quote
Old 03-02-2011, 06:37 PM   #14
PlasticFoamMan
Member#: 197764
2002 Nissan Frontier
buh bye WRX :(
You can say that again.
PlasticFoamMan is offline   Reply With Quote
Old 03-02-2011, 06:39 PM   #15
Strobe Media
Member#: 241600
2004 WRX STi
like a million whp
i just feel like the next step is underbody kitp
Old 03-02-2011, 06:40 PM   #16
Bu11dogg2
Member#: 101474
2004 "Insert
Something Witty Here"
c'mon Mike... you know better
Bu11dogg2 is offline   Reply With Quote
Old 03-03-2011, 12:31 AM   #17
Kentrik
Member#: 125937
03 WRX I do not
like your tweed, chap.
Has anyone retrofitted this into an older GD chassis Impreza?
Kentrik is offline   Reply With Quote
Old 03-03-2011, 10:40 AM   #18
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
You could also tap the power to the cubby LED. That is what Subaru's factory footwell kit does. If you get the Subaru kit, you can even just daisychain 2 kits, extend the wires, and run them to your rear footwells too. Note, however, that the cubby LED has dash power and will work (and dim)with your dash lights, not come on when you open a door.
As far as "rice" goes, many, many cars are now coming with footwell illumination as an OEM option. I have a friend who has it on his new F150...and his actually have 7 different color settings (okay, so that's borderline rice). It's not uncommon, and it's nice to be able to see into the footwell at night.
I went with the red kit from Subaru and swapped out the blue LED for red in the center console. It matches the overall dash lighting and looks nice. Mixing colors would have been too much for me. The Subaru kit is understated, not super bright, dimmable, and is functional without being too showy.
Ogden is offline   Reply With Quote
Old 03-03-2011, 10:43 AM   #19
Bruins1982
Member#: 240365
2011 WRX Premium
Sedan WRB
Good post.
Old 03-03-2011, 10:44 AM   #20
Kupkake
Member#: 213288
2007 SWP VF39 WRX
Sti Mikey Tuned
my buddies forester has them. imo not my taste, but they aren't as bad as neons.
Kupkake is offline   Reply With Quote
Old 03-03-2011, 10:45 AM   #21
1RandomW
Member#: 269224
'11 WRX-4 Door, SWP
Any pics of red Footwell Illumination Kit just for comparison purposes ?
1RandomW is offline   Reply With Quote
Old 03-03-2011, 10:48 AM   #22
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
The Subaru kit plugs into the wiring for the LED that the 08+ cars have in the dashboard cubby. You unplug the cubby LED, plug in the footwell kit, and then plug in the cubby LED to the new spot provided on the footwell kit. Reinstall the cubby light, run the wires and mount to the OEM locatiosn. Totally plug and play. You can build a kit cheaper than the one Subaru makes, but for the 15 minute install, it's well worth an extra $20-$25 IMO.
It shouldn't be that hard to adapt it to a different power source, but as you will have to rewire some of the kit anyway, you might as well source the LEDs and wiring seprately and save some money.
Old 03-03-2011, 10:50 AM   #23
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
Originally Posted by jonklein611 View Post
Is the premium interior for the '11 tan leather with red stitching? Or is that just the photo?
Old 03-03-2011, 10:55 AM   #24
jonklein611
Member#: 117776
WR Blue Pearl
Just my horrible horrible white balance in the garage @ night.
It's black leather with red stitching
Old 03-03-2011, 11:36 AM   #25
cheezmunky
Member#: 167627
2011 WRX Ltd Hatch
here's red:
It's definitely ricey in the sense that it does nothing for performance and is only for appearance, but I found it to be a really nice and subtle effect. Note that the red is a lot brighter in the pic than in real life due to a fairly long exposure time.
How do you install the Footwell Illumination Kit (H201SSC000) in the '09 FXT/WRX/STI? GodWhomIsMike Interior & Exterior Modification 228 10-16-2015 06:21 AM
Footwell Illumination Kit (H201SSC000, H201SSC100) Retrofit? littledrummerboy Interior & Exterior Modification 12 11-21-2013 02:38 PM
Rock Stuck in Brakes? 2011 WRX ping Brakes, Steering & Suspension 5 03-01-2011 12:14 AM
WTT : Blue Subaru Footwell Illumination Kit (factory option) for the red version Louros Tri-State Area Private Classifieds 12 02-01-2011 10:44 PM
Subaru Footwell Illumination kit $30 Shipped TEK112 Interior/Dressup/Audio & Security 7 01-05-2010 09:43 AM
