Old 07-13-2002, 06:21 PM   #1
adam@stonehill.edu
Member#: 6655
2000 Impreza 2.5RS
Dirty White
Default NA Fuel Pressure High after Pump Install
Installed a Walbro 255lph pump in a friends 2001 RS since his stock pump died. About a week later his fuel pressure is around 80-90psi @ idle. We've been trying to regulate pressure with a Paxton FMU and removing the stock FPR but that hasn't worked either.
Anyone got any ideas?
Thanks for any help.
- Adam
adam@stonehill.edu is offline   Reply With Quote
busted stud during fuel pump install, proper fuel tank pressure? overdose Factory 2.5L Turbo Powertrain 9 09-25-2006 11:20 AM
Not sure where to post: Fuel Pressure & EGT Gauge installs? nxwrxfx Engine Management & Tuning 16 05-09-2006 01:15 PM
P0453 code EVAP Fuel pressure high circuit pitcrew Subaru Conversions 0 08-17-2004 10:08 PM
do i install the fuel pressure gauge after the rrfpr? GregBolby Normally Aspirated with bolt-on Forced Induction Powertrain 3 02-08-2004 05:47 PM
Higher oil pressure, lower fuel pressure after turbo, FMIC install SFastWRX Factory 2.0L Turbo Powertrain 1 08-08-2002 07:12 AM
Message Board Statistics All times are GMT -4. The time now is 05:57 PM.
