Old 07-13-2002, 08:38 PM   #1
Camperguy
Member#: 21274
2002 Mc_Bains car
I use to have a WRX :(
Question Where do I get tha air-box velocity stack from?
Hey..I have an Amsoil airfilter I just want a V-Stack...Anyone?
Thanks Bill
Camperguy is offline   Reply With Quote
Old 07-13-2002, 09:37 PM   #2
WRblue'02
Member#: 15667
2004 STi
Alpine White
summitracing.com
Part # AVC-19002
I don't have one yet...does anyone know if it fits right into the gasket on the underside of the airbox? Will I have to remove the gasket? Will the velocity stack rattle against the inside of the fender?
It seems like a better option than duct tape or foam insulation, are there any downsides?
WRblue'02 is offline   Reply With Quote
Old 07-13-2002, 09:41 PM   #3
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
I bought mine as a complete kit from WRXfx here on the boards.
http://forums.nasioc.com/forums/show...hreadid=182973
dbrier is offline   Reply With Quote
Old 07-13-2002, 10:50 PM   #4
Ezmendriz
Member#: 10747
Unhappy Can you post pic of it?
I have never been able to see pic of the kit could yu pos some?
I mean the WRFX kit.
Ezmendriz
Ezmendriz is offline   Reply With Quote
Old 07-13-2002, 11:30 PM   #5
MackDaddy
Member#: 15451
2016 Accord EXL Navi
Lunar Silver
Thumbs up Works like a champ
Originally posted by ~WRblue'02
summitracing.com
Part # AVC-19002
No rattles, squeeks, nada. You don't need anything else to hold it in. It fits tight in the OE airbox rubber. You'll need to bend the large lip a bit for inner fender liner clearance. No big deal, it's made of aluminum. Also, turn up the brightness on your monitor. You'll see the upper portion of the radius lip is held in by the OE wiring harness. That works!
Like Nike, just do it.
Jim
MackDaddy is offline   Reply With Quote
Old 07-13-2002, 11:36 PM   #6
WRX216
Member#: 8027
2002 WRX sedan
Midnight Black
summitracing.com
Part # AVC-19002
Akimoto motorsports velocity stack fits very nicely into the airbox gasket. It only needs a minor trim to fit the inner fenderwell radius. Just use some silicone goo to glue it to the fenderwell.
Chris
WRX216 is offline   Reply With Quote
Old 07-14-2002, 01:58 PM   #7
Camperguy
Member#: 21274
2002 Mc_Bains car
Thumbs up Thanks on the info guys!
Will be getting it through Summit..and I like the price
Bill
Old 07-29-2002, 05:20 PM   #8
WRX_ONLY
Vendor
Member#: 13455
Sliver
Thumbs up Sweet
Just ordered one...thanks for the heads up.
Areg
WRX_ONLY is offline   Reply With Quote
Old 07-29-2002, 05:44 PM   #9
CTP
Member#: 16835
Blaze Yellow
Question question
Is this "velocity stack" for people who did the intake mod to connect the gap betweenthe airbox and the fender?
Is that a one piece metal?
If it is, does it require to remove the airbox and put this "velocity stack" in? I notice that the 2 bolts that holding the whole airbox are very tight, I couldn't get it out.
Thanks
CTP
CTP is offline   Reply With Quote
Old 07-29-2002, 06:20 PM   #10
elgorey
Member#: 4374
06 Titan,99,94 SM
06 nasa spec miata champ
get it from summitracing
they have the silicone coupler there too if you want to replicate the WRXfx kit.
the WRXfx kit was a ripoff, wish I had saved $$ and bought through summit.
elgorey is offline   Reply With Quote
Old 07-29-2002, 07:17 PM   #11
MackDaddy
Member#: 15451
Lunar Silver
Talking Yes, and no
Thanks
CTP
Yes, it fills the gap and is one piece.
No, you don't need to remove the OE airbox to install it. You do have to open the inner fender liner to gain access for the install though.
HTH - Jim
Old 07-29-2002, 07:31 PM   #12
Camperguy
Member#: 21274
2002 Mc_Bains car
Thumbs up Cool beans!
Hey,pretty simple install..you can really hear the turbo now and it seems to spool faster
Bill
Old 07-29-2002, 07:36 PM   #13
ToddStratton
Member#: 8351
2002 WRX Wagon
Looks nice, except that it may make it difficult to remove the lower half of the airbox. This would make it difficult to change spark plugs and anything else that requires access to that area.
TRS
ToddStratton is offline   Reply With Quote
Old 07-29-2002, 07:39 PM   #14
MackDaddy
Member#: 15451
Lunar Silver
Talking It costs to be the boss
TRS
Or, you play, you pay. Either one is applicable here.
Agree it's going to make some things more of a PITA, but worth it IMHO.
Jim
Old 07-30-2002, 01:43 AM   #15
SAL-23
Member#: 3474
2013 WRX
I just got a 3" to 4" pvc dryer vent reducer for a dollar in the dryer vent aisle at Home Depot to fix that gap. It may not exactly be a velocity stack but it fits perfectly and works fine for me and I'm not complaining
SAL-23 is offline   Reply With Quote
Old 07-30-2002, 04:09 AM   #16
en3d
Member#: 5238
GGA Black
I did almost the same thing, can't beat it for the price and I'll bet that there is no difference in power between this and a velocity stack.
en3d is offline   Reply With Quote
Old 07-30-2002, 10:50 AM   #17
mynew02
Member#: 13726
2002 WRX - 264 AWHP
ION-Turbo&LINK [email protected]
Two questions..
1. What does it sound like? Is it like the AEM with the loud sucking sound?
2. I have heard that the oil on the K&N filter can make the map sensor go bad. Are there any hi-flow filters that will not cause this to happen?
-Jonathan
mynew02 is offline   Reply With Quote
Old 07-30-2002, 02:23 PM   #18
CTP
Member#: 16835
Blaze Yellow
Can you tell me the right size for the PVC dryer vent?
3" or 4" ? of any size in particular?
Thanks
CTP
Old 07-30-2002, 02:27 PM   #19
scrmnsmn
Member#: 8299
Midnight Swirl
3" fits perfectly into the airbox, but 4" would fit better around the underhood "scoop". I cut and flared out the 3" to fit.
Chris
scrmnsmn is offline   Reply With Quote
Old 07-31-2002, 02:30 AM   #20
SAL-23
Member#: 3474
2013 WRX
Thanks
CTP
The actual item is called a 4" to 3" dryer vent reducer. It is a white pvc pipe in the dryer vent aisle (not plumbing) at Home Depot and it costs exactly $1 (atleast at the HD near me). The pipe has a 3" piece that fits perfectly to the airbox and extends out to 4" in diameter to seal the hole in the fender well. It's fits like a velocity stack but it's not really one since the 4" side doesn't flare out flush against the fender wall like a velocity stack should. I don't think you would really be able to tell the difference though and plus I think the 4" side extending out would block some moisture or debri coming from the fender. There are many other I-clubbers that have done this too.
Old 07-31-2002, 09:53 AM   #21
wrxspeed
Member#: 16119
Silver Wagon
Default Or.
when you remove the resonator hack off the lower "box" portion and you get the benefits of all this work for less time and $. plus it looks COMPLETELY stock.
wrxspeed is offline   Reply With Quote
Old 07-31-2002, 05:31 PM   #22
sochico
Member#: 18377
2002 wrx
midnight black
hello every one,
that velocity stack piece from summit is on back order. tentative shipping date they had was aug 10th i was wondering if anywhere else carried them. i wanted to order mine today but it is on back order
sochico is offline   Reply With Quote
Old 07-31-2002, 05:55 PM   #23
jimb
Member#: 9923
2005 Legacy GT
RIP MBP WRX
I'm sure there is a guy doing inventory at summit scratching his head and wondering where the hell all the Part # AVC-19002's went.
jb
jimb is offline   Reply With Quote
Old 08-02-2002, 01:32 PM   #24
sochico
Member#: 18377
2002 wrx
midnight black
k i am still curious if anyone else has found this part else where or something comprable. it is now on back order till the twelth. so not sure
Old 08-02-2002, 02:30 PM   #25
CTP
Member#: 16835
Blaze Yellow
I saw one on this web-site
http://www.slickperformance.com/Miat...es/intake2.htm
but they sell it for $39.99.
I received one from Summit 2 days ago
CTP
FS (tn): air box velocity stack and fender plug DamnYank! Private 'For Sale' Classifieds 1 09-21-2005 01:04 PM
Where do I get the pipe to eliminate the first cat converter with the 02 in it?? RyanA Normally Aspirated Powertrain 8 10-05-2004 04:52 PM
Where do I get the GC8 WRX stickers? Eric SS Interior & Exterior Modification 7 10-11-2001 11:07 PM
Where do you get the animated smilies Soon2Bgreat General Forum Archive 2 09-10-2000 02:53 PM
