Old 07-13-2002, 09:02 PM   #1
snowone
Member#: 6035
05 92-X Saabaru
87 VW Westfalia
Default Whiteline HD Endlinks > Front
Any of you running these? Went to install a set today, and they didn't seem to fit... just curious if anyone else has used these. There wasn't enough clearance on the lower connection.
Anhow... thought I'd check... thanks in advance for info.
BB
snowone is offline   Reply With Quote
Old 07-13-2002, 09:39 PM   #2
HIHO
Member#: 7624
BD5; family sedan
that just wooped your ass
They work great for me and were easy to install. Weird. Can you post pics of the problem?
HIHO is offline   Reply With Quote
Old 07-13-2002, 10:07 PM   #3
tora
Member#: 5851
09 Forester XT
+ NA Miata
I'm running them on my stock bar...but different MY.
tora is offline   Reply With Quote
Old 07-14-2002, 12:59 AM   #4
snowone
Member#: 6035
05 92-X Saabaru
87 VW Westfalia
Wish I had my camera with me when I was installing today. I'll post pics if I attempt again...
The issue was the lower bolt... where the link bushing fits into channel box-shapped fitting; in the back side of this "box" fitting there is a weld that attaches it to the arm/suspension/brace (obviously don't konw the correct name for this part, and sound like a jackass ). Anyhow, this weld in the back protrudes enough to not allow the endlink to slip far enough back where it should in order for the holes to line up. Also, when comparing the stock plastic/rubber link to the WL link, the WL link is approx. 3/4" longer.... which wouldn't seem to be an issue as the bar can rotate up to match.
From what I know, there is only one link set by WL that is supposed to work on "most" subarus.
The rears fit like a charm. I know the fronts should too This should be, and is, a very simple installation, kinda bummed they didn't seem to fit correctly.
Tora: I too was going to run these w/ my stock bar in the front... and have the WL adjustable in the rear.
I purchased these from a local guy; they came off his 99/00 Impreza RS.
Old 07-14-2002, 05:45 AM   #5
sovereignmk1
Member#: 11858
1998 Silver Legacy
Try going for the bottom bolt in first? How about the reem on it till it goes in method? Well, Like everyone else, Mine worked fine.
/Mark
sovereignmk1 is offline   Reply With Quote
Old 07-14-2002, 07:38 PM   #6
snowone
Member#: 6035
05 92-X Saabaru
87 VW Westfalia
Got under the car again today to make sure I wasn't just having a special moment yesterday. I checked both front endlinks for fit, had a rubber mallet on hand, and tried every angle/rotation inserting the bottom end of the link first... they don't quite fit.
Took a couple photos for reference:
Oh well.
Old 07-14-2002, 09:30 PM   #7
HIHO
Member#: 7624
BD5; family sedan
Umm...it looks like you are putting them in wrong. I could be wrong.
Old 07-15-2002, 12:43 AM   #8
snowone
Member#: 6035
05 92-X Saabaru
87 VW Westfalia
What helped you differentiate the top from the bottom in that blurry photo?
That wasn't the problem. The Top has a larger diameter bolt, and hole, this helps in figuring which way is up ; ) However, I did try flipping it... and the metal is the same thickness at either end and still contacts the point shown (screwdriver) just the same.
Old 07-15-2002, 08:59 AM   #9
pleiades
Member#: 2491
06 Miata
81 Fiat Spider
Funny, I've decided that's where my noise up front is coming from. At first I thought it was the sway bar mounts, then I replaced the lower ball joint (which made the car feel a little better, but I still had this pop noise occasionally) and now I've noticed that the end-link is rubbing right there where you're pointing out.
pleiades is offline   Reply With Quote
Old 07-15-2002, 10:23 AM   #10
HIHO
Member#: 7624
BD5; family sedan
I will have to look at mine but it just seems like they need to be flipped. If not verticaly than horizontally. I could be totally wrong too. Maybe the MY99 are different?
Old 05-23-2003, 05:21 PM   #11
onehotchili
Member#: 31962
2005 Legacy GT Wagon
Default maybe I should done a search first...
but I am having the same exact issue trying to install my front endlinks.
Snowone - did you ever resolve this?
I have a feeling that our MY cars are not compatible. It sucks to figure this out now...
onehotchili is offline   Reply With Quote
Old 05-23-2003, 06:33 PM   #12
richeich
Member#: 1353
2001 Impreza 2.5RS
I ran into the same deal when I installed mine. I had to file some of the bracket away to give them enough clearance to swing into place. It didn't take much, and it didn't seem like it would effect any structural integrity.
Rich
richeich is offline   Reply With Quote
Old 05-23-2003, 07:25 PM   #13
snowone
Member#: 6035
05 92-X Saabaru
87 VW Westfalia
I tried flipping, rotating, & pounding during install... ended up not using the links. I suppose it would've been fine to grind out some clearance to make them fit. However, I wasn't happy with the force fit.
I mentioned the issue to Whiteline when inquiry about their "upgrade program" for the new style rear endlinks, and they said they were unaware of this issue. I'll have to dig up the WL reply to my email with the photos of the front link fitment situation.
I'm waiting to see if they have a new front link design that will fit our application.
FS: *NEW* Whiteline HD Endlinks & Ingalls Camber Kits jezzy Suspension/Brakes/Handling 12 05-16-2007 08:56 PM
Whiteline/Kartboy endlinks, wagon fronts TTUsuby Suspension/Brakes/Handling 6 08-30-2006 07:14 PM
Whiteline HD front endlink doesnt fit 06'wrx wagon ? SammyRex Brakes, Steering & Suspension 3 04-11-2006 02:31 PM
Interesting event with whiteline HD endlinks MattSTi Brakes, Steering & Suspension 3 06-30-2005 08:14 AM
Whiteline HD endlink install txl146 Brakes, Steering & Suspension 2 08-29-2004 10:55 PM
