Old 03-02-2011, 11:34 AM   #1
BDZ
Member#: 246673
Default Misfire code P0302
My '06 2.5i set a P0302 misfire code. I cleared the codes with a scan tool and its been code free for 200 miles but the car seems to be running rougher than normal at idle and during acceleration from a stop.
My plug wires and coil all check out within spec per the service manual but with 125k miles could they be worn out and still test okay?
BDZ is offline   Reply With Quote
Old 03-02-2011, 03:49 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
The wires could be, don't know about the coil. Have you checked the plugs themselves? Do eet.
Old 03-03-2011, 09:24 AM   #3
BDZ
Member#: 246673
Plugs have less than 20k miles on them. Replaced at ~109k with Tbelt and waterpump.
Wires and coil pack ohmed out per service manual spec with no visible cracks or degraded insulation. I misted an alcohol/water mix under the hood to look for evidence of a bad wire but was unable to detect any arcing.
Old 03-03-2011, 01:17 PM   #4
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
a misfire is a hard thing to track down. I'm having the same misfire and I've been working on mine for a while. I would swap you plugs/ wires/ injectors and see if it follows the change. If not, find a place with a OBD II reader that can do freeze data and find out when the misfire is happening. It can be a number of other things like, bad cat or O2 sensor, timing, knock sensor, valve lash, or burnt valve but usually those will cause multiple codes. I have cams and a LW flywheel and crank pulley so i always thought that was my problem but it may have just been masking my actually misfire. After i did my 6-speed swap and put in a heavier flywheel all the misfires went a way but the p0302, so i may have had an actual misfire the whole time and didn't realize it.
aclver1 is offline   Reply With Quote
P0302 misfire code 03 spec r1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-14-2010 12:40 PM
#2 Misfire CEL Code P0302 SkunkBug02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 09-15-2009 12:47 PM
Code P0302 misfire #2 Impwrxza Vancouver Impreza Club Forum -- VIC 4 06-21-2009 09:04 PM
Misfires- P0301 P0302 P0303 P0304 AndyHidley Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-30-2001 01:18 AM
Check Engine Code P0302, "#2 Misfire" hillman Legacy Forum 5 06-26-2001 03:14 PM
