Old 07-14-2002, 01:11 AM   #1
The Real Oaf
Member#: 6608
1996 Legacy Outback
Default How to install uderseat woofer?
Got the box w/harness. I have a Sony head unit with an adapter harness(a la Crutchfield). This adapter does not have a signal input; the woofer powers up but no boomboomboom.
Can I run a parallel signal output, say from one of the four speaker outputs to the woofer?
Any advice is appreciated.
Paul
The Real Oaf is offline   Reply With Quote
Old 07-14-2002, 02:35 PM   #2
jr34596
Member#: 14529
do u have a seperate amp, or are u using the headunits internal amp?
jr34596 is offline   Reply With Quote
Old 07-14-2002, 10:34 PM   #3
The Real Oaf
Member#: 6608
1996 Legacy Outback
All that I've replaced is the head unit & speakers; still running stock wiring.
My plans are use seperate amps for the front and rear channels, using the RCA outputs off the head unit.
That leaves the factory speaker outputs for the woofer.
Paul
Old 07-15-2002, 11:48 AM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Normally the rear speakers power the subwoofer. I dont understand though, if you have the stock wiring the subwoofer should already be receiving a signal. Or did you run new wires for the speakers.
Also Id suggest dumping that crap arm they include to install the sub. Attach the sub to the bottom of the seat in some way that it cannot "float."
I used some large zip ties around the normal screws in the bottom (with a washer) and the sub is now very secure against the bottom of the seat. The passenger now gets a nice but massage
Old 07-15-2002, 01:36 PM   #5
jr34596
Member#: 14529
if u r trying to run a sub off of the head unit it might not be enough power. Most replacement head units have liek 4x45 watts. If u were able to put all the wattage to the sub u would be straight, if not there is most likely not enough power
Old 07-15-2002, 02:03 PM   #6
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
he's talking about the factory underseat sub
yes, hooking it in parallel (preferably to a back channel. but it doesn't matter) should work.......
sybir is offline   Reply With Quote
Old 07-15-2002, 10:31 PM   #7
The Real Oaf
Member#: 6608
1996 Legacy Outback
Thanks for the advice...I'll let you know how it turns out.
How to install DCCD (adj diff)? How many hours? garface Transmission (AT/MT) & Driveline 31 02-07-2003 05:39 PM
how to install WRX headunit to cars with extending antenna's. kenchan Car Audio, Video & Security 7 10-29-2002 10:38 AM
Back to basics...How to install top hats? Ru fan New England Impreza Club Forum -- NESIC 4 10-17-2002 07:41 PM
How knows how to install a clutch / Where to get my clutch installed? BrysImpreza New England Impreza Club Forum -- NESIC 4 09-23-2002 10:33 PM
Iam going to buy A turbo Any body know how to install it? Boom New England Impreza Club Forum -- NESIC 2 04-28-2001 12:36 AM
