Old 03-03-2011, 08:20 AM   #1
BabyDoll0889
Member#: 274619
1997 Impreza L
Red & Black
Question AI Oil Light: Tranie Stuck In 4 wheel drive
I have 2 Subaru Impreza L AWDs and both of the transmissions are stuck in 4 wheel drive, one is a 97 (Driving) and a 96 (Parts ONLY) well the 97's AI oil light comes on and flashes, so we had it diagnosed and it turns out its stuck in 4 wheel drive and if we don't fix it then it will cause further problems its 1,100 (just dont have the money to do this, i work at McDonald, i make 7.25) to fix the actuator which we think is wrong with it. the 96 is just stuck in 4 wheel drive, were going to try and rebuilt this tranie and stick it in my 97. I just want my car to be fixed.
BabyDoll0889 is offline   Reply With Quote
Old 03-03-2011, 08:33 AM   #2
GEE-OTTO
Member#: 201277
2009 Legacy GT
Oh....... well I hope that works out for you
And 1100 to fix a L tranny is a joke
GEE-OTTO is offline   Reply With Quote
Old 03-03-2011, 08:36 AM   #3
BabyDoll0889
Member#: 274619
1997 Impreza L
Red & Black
yeah its at the subaru dealer both tranies have diffrent problems the 96 is our test tranie if we dont get it fixed then i will have to spend the money to get a tranie thats not stuck in 4 wheel drive or spend the money to fix my car either way its gonna be hard
Old 03-03-2011, 09:14 AM   #4
GEE-OTTO
Member#: 201277
2009 Legacy GT
Well try rs25.com you should be able to find a used L FWD trans there for cheap as people used them now a days for tent anchors or paper weights LOL
Old 03-03-2011, 09:25 AM   #5
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
Originally Posted by BabyDoll0889 View Post
I have 2 Subaru Impreza L AWDs and both of the transmissions are stuck in 4 wheel drive.
Stuck in 4WD? That is the way it is supposed to be unless you have an older 4WD Subaru transmission from an L series.
Newer Subarus are AWD meaning that they are in full time 4WD.
Older Subarus are offered with 4WD meaning that it is part time 4WD. One can switch from 2WD to 4WD.
Your 1997 Impreza is AWD so it is AWD all of the time, you cannot switch it up.
Jessekrs123 is offline   Reply With Quote
Old 03-03-2011, 09:38 AM   #6
BabyDoll0889
Member#: 274619
1997 Impreza L
Red & Black
Its not suppost to be stuck its frozen pretty much already took it to subaru i have a fwd box where i put in a fuse, my car isnt suppost to be flashin thr ai oil light im not stupid on awd its suppost to kick in and out.
Old 03-03-2011, 09:39 AM   #7
renyo
Member#: 93577
98 Impreza
I'm guessing Duty C broke.
renyo is offline   Reply With Quote
Old 03-03-2011, 09:43 AM   #8
Jessekrs123
Member#: 236927
1984 BRAT
No no no no.
AWD is fulltime AWD. There is no "kick on kick off". IIRC for the automatic transmissions, in 1st and 2nd, there is a 50/50 diff split and in the higher gears it goes 90/10 as long as the wheels aren't losing traction. There is never 100% in the front, therefore it is fulltime AWD.
And you should not use the FWD fuse to drive, that is strictly for towing. If you put that fuse in long enough, your rear diff will not get worked and it will crap out once you take the fuse out.
If you put the fuse in, then the FWD light on the dash should be illuminated. If not then you probably used the wrong fuse, but DO NOT use the fuse to drive or you will have problems in the future.
Old 03-03-2011, 10:14 AM   #9
BabyDoll0889
Member#: 274619
1997 Impreza L
Red & Black
No no no no.
My cars gone to subaru dealership repair. They said its frozen in 4wd!!!!!
Old 03-03-2011, 10:26 AM   #10
Jessekrs123
Member#: 236927
1984 BRAT
I'm thinking your dealership is ripping you off and just giving you an excuse so they can run up the bill. When my father's AT Oil light was on, he took it to the dealer and just had the tranny flushed and filled with new oil and that fixed the problem. They don't try to trick us because we know more than the average Joe.
Old 03-03-2011, 10:32 AM   #11
BabyDoll0889
Member#: 274619
1997 Impreza L
Red & Black
I do All my mantiace myself :/ sorry for spelling errors im sleepy n no spell check on iphone. I took it to a few other transmission places n they said same thing that the 4wd is froze
Old 03-03-2011, 11:28 AM   #12
silvercookie
Member#: 180033
2005 WRX
silvercookie is online now   Reply With Quote
Old 03-03-2011, 01:03 PM   #13
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
There is such a thing as the AWD getting "stuck" in 4wd. "Stuck" just isnt the right term. AWD w/ 4EAT automatic tranny is normally a 90/10 f/r torque split. When the duty solenoid kicks in it switches to 50/50 (lock), when front wheels lose traction. Normally, you should not be driving around in 50/50 lock, this means the duty solenoid is "frozen" in the lock mode. You will ruin your tranny this way. Replace the solenoid!
Samirr76 is offline   Reply With Quote
Old 03-03-2011, 01:06 PM   #14
BabyDoll0889
Member#: 274619
1997 Impreza L
Red & Black
I have no money.... Im replacing tranie with a rebuilt 1
Old 03-03-2011, 01:41 PM   #15
Jessekrs123
Member#: 236927
1984 BRAT
Thanks for clarifying. I thought OP meant that it was stuck in AWD as opposed to being stuck in a 50/50 diff split.
Stuck in snow! wheels wont move in gear! help! sti3573 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 39 02-09-2010 06:05 PM
What was the last song you had stuck in you head, driving you INSANE for days on end? Asinine Off-Topic 24 05-02-2008 10:30 AM
4 wheel Drive ExchangeGuy Texas Impreza Club Forum -- TXIC 20 05-23-2001 12:33 AM
New 4 wheel drive car craigc Bay Area Impreza Club Forum -- BAIC 3 03-02-2001 01:31 PM
