#1 |
Member#: 164038
NWIC
Vehicle:2013 WRX STAGE 2 Ice Silver |
Whats up NASIOC! Im currently tryin to get any info I can on this subject. Would be awesome if I could find someone who has done a EJ18/EJ22t head swap before.
I have a friend with a 95 Outback and alot of parts!! He bought everything from someone else and does have a clue how to do the build. Here is a lil list of parts.... 95 Impreza Outback AWD EJ18 block with EJ22t heads Greddy Emanage Ultimate 92 Turbo Legacy 5 speed transmission w matching rear diff 2000 wrx tranny Vf39 Vf11 TD04 What i need to know is which parts will work together, what parts I still need and is this even a good swap? Can the EJ18 handle the boost? Will the Emanage do the job for tuning? Really any and all info is welcome. Thank you for your time.
#2 |
Member#: 236927
NESIC
Vehicle:1993 Legacy Sedan 1984 BRAT |
Joejoe did a EJ18 build with 22T heads. He ran both VF34 and VF39 turbos.
Check out his build here: http://www.rs25.com/forums/f7/t81773-project-ej18t.html Everything and anything you need to know can be found within the confines of that thread. Check out his youtube videos too, they are pretty intense. |
#3 |
Member#: 164038
NWIC
Thanks alot man! GREAT INFO!
#4 |
Member#: 164038
NWIC
Anyone have any info on the Greddy Emanage Ultimate. How its gonna work with the ej18?
#5 |
Member#: 33782
Vehicle:96 bastard child search FIRST, then PM!!! |
I know guys use to run emange (before ultimate was out) in turbo NA EJ motors...probably have to search a bit.
My only experience with it was on a customer's SR20. I'd much rather get a standalone. |
#6 |
Member#: 108188
Vehicle:1993 Impreza L 1.8T Lotus Storm Titanium |
Here's some good reading:
http://www.rs25.com/forums/f7-turbo-superchargers http://www.rs25.com/forums/f7/t11515...t-project.html http://www.rs25.com/forums/f7/t81773-project-ej18t.html http://www.rs25.com/forums/f7/t79990...-l-thread.html I researched countless hours in the Turbo & Superchargers forum and talked to a few people before I got started. Remember don't believe everything people tell you as you'll find out in my thread(the last one posted) regarding coolant lines. |
#7 |
Member#: 164038
NWIC
Thanks man!
#8 |
Member#: 164038
NWIC
Couple of questions.....
What year exhaust manifold will work? Im thinkin of just installing an oil sandwich adapter so i dont have to tap the oil pan....?? |
| Thread Tools | |
| Display Modes | |
| EJ22T heads on EJ22E block, ok to do? | riderdude125 | Built Motor Discussion | 2 | 11-21-2010 09:24 PM |
| ej18/ej22t hybrid no spark | Fail Wagon | Normally Aspirated with bolt-on Forced Induction Powertrain | 82 | 08-23-2008 08:06 PM |
| will ej22 or ej22t heads fit on my ej18 motor? | 91turbosedaan | Normally Aspirated Powertrain | 5 | 03-06-2008 01:42 AM |
| FS: 95 BD Legacy w/ ej22T and TEC 3 | subiekid | NWIC Private Classifieds | 2 | 01-09-2007 10:06 AM |
| 95 Outback oil leak @ head and valve cover | akd | Service & Maintenance | 0 | 02-12-2004 08:46 PM |
