Old 03-03-2011, 10:12 PM   #1
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Default Phase I ej22 with phase II head gaskets.....is there a problem?
Hey all, just got done doing a lot of maintenance on my wife's '96 Legacy Outback. One of the things I did was replace the head gaskets. Since I was in there I thought I would drop in phase II head gaskets and get a small CR bump. Upon starting it back up it is extremely noisy. I know that the valve train is loud and will quiet down a little after a few days but when I rev it I think I might hear valves hitting the pistons! This has me worried as I don't want to destroy my motor by driving it around if the valves are contacting the pistons.
When I first put the timing belt back on the car I made sure to do it right. I spun the crank several times and all of the timing marks were still lined up. Upon start up it immediately jumped timing. It ran for about 8 seconds like that at a low idle. I thought maybe I had just timed it wrong and went to do it again but then found out my tensioner was dead. I got a new one and now I need to know if I made a horrible mistake.
Thanks,
Geronimo
geronimo81 is offline   Reply With Quote
Old 03-04-2011, 01:22 AM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
If you think the valves have contacted the pistons, don't start the car at all. Remove a spark plug, and look inside the chamber (won't be easy) to see if there are any marks on the piston.
I wouldn't think that using a HG that is about half a thick, on a block that has pistons with valve reliefs in them, would contact the valves. Can you post a sound clip or video to help diagnose?
IIRC, from 97 and up, the motors are interference, before that they weren't, at least, that's what I remember.
~Josh~
Old 03-04-2011, 09:08 AM   #3
kay95
Member#: 45494
95 impreza L awd
green
Well I know the EJ25D has pistons that clear the deck and you NEED the thicker gaskets and I think the P1 2.2 is the same way. So the piston might be hitting the head.
kay95 is offline   Reply With Quote
Old 03-04-2011, 11:49 AM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Oops.
Old 03-04-2011, 02:01 PM   #5
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Well I certainly feel like an ass right now. I know for a fact that the P1 pistons clear the deck as I observed it first hand. I did not even think about that. I will pull a spark plug and take a look inside to see what's up. I had to drive the car about 5 miles last night to get home so I hope it's not a total loss. Sometimes working on your own car can save you money....and then you make a mistake that makes all of your hard work a total waste! If I had the money I might be tempted to buy newer cars that are still under warranty and just sell them everytime the warranty is up. I wasn't raised that way but I can't stand having to do this big of a job more than once in so short a period of time. It wouldn't be a big deal but my wife needs her car.
So if the valves have contacted the pistons what am I looking at for a fix? Replace valves and pistons and I'm good?
Old 03-04-2011, 02:32 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
Do a leakdown test.
Old 03-04-2011, 02:52 PM   #7
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Okay, so when I drove it home last night my alternator/ps belt came loose and I ran on battery for the last mile. Long story...a couple of years ago I was on top of a mountain and the bolt for my alternator belt tensioner snapped. I stole one from the ps pump bracket and forgot about it. Last night when I put it back together I stripped the threads out of the alternator (the bolt was too short so it only grabbed the first few threads). So when I got home I didn't get to hear the motor. I just came home for lunch and installed a new longer bolt and decided to start the car and see if anything had changed....
I can't hear the sound at all!!! It must have just been the valve train. I cleaned the heads really well and ended up flushing most of the oil out of them so after driving it home last night everything seems to be great. I will drive it to work and make sure there are no leaks or anything.
- feeling like slightly less of an ass
It's Alive: phase 2 ej22 with phase 1 dohc heads in 96 Impreza ej20forester Normally Aspirated Powertrain 10 09-17-2010 03:38 PM
Is there engine problem with the 2011 STI? speed12sil Warranty Issues & SOA Problems 19 06-14-2010 11:10 AM
Is there any problem with driving in FWD mode? pawn Transmission (AT/MT) & Driveline 3 02-17-2010 10:42 PM
Phase Ii 5-spd Engine Phase Ii Auto Engine, Is There A Difference??? Jlynch24 Normally Aspirated Powertrain 5 12-19-2009 02:30 PM
Problems with early 90s head gaskets? procainestart 'Old School' Subaru Forum 4 12-11-2005 05:59 AM
