Old 03-04-2011, 12:17 AM   #1
STI_GUY_06
Member#: 250750
2006 sti
black
Default megan header welding
I would like to purchase a megan header/upipe manifold but am concerned a little bit about leaks and cracks with this piece. Would taking it to an exhaust shop and having them weld over the original welds before installation make a difference in increasing the longevity/reliability of it? And one more question, would doubling the gaskets between the manifold and the heads help prevent exhaust leaks if they were to occur?
STI_GUY_06 is offline   Reply With Quote
Old 03-04-2011, 02:20 AM   #2
SHARP_DAL
Member#: 183247
2005 WRX
Double welding wouldn't make a difference unless the welds did not fully penetrate the steel. Just go over all the welds and make sure it fully penetrated. Plus I think getting someone skilled to go over all weld will cost a fair bit, but If the headers have slip joints then welding the slip joint will prevent leaks.
Do not double up gaskets it will just cause bigger leaks. Use quality OEM or grimmspeed gaskets, you will only experience leaks if the flangs are thin and warp. Biggest issue with the headers will be crack in the steel and in weak joints.
Run them for a year, if they crack weld it up, or toss them out... good luck with installation btw.... I'm not too sure but many 4-2-1 headers have fitment issues and need trimming of the subframe to fit..
SHARP_DAL is offline   Reply With Quote
Old 03-04-2011, 07:05 PM   #3
jjagg0125
Member#: 163452
2006 sti
aspen white
do not do this.... im a welder and have welded many subaru headers, honestly the less welding you can do to the headers the better, if they crack then weld them. welding causes stress especially on stainless when it cools which can at times cause cracks itself and or make the headers warp or pull especially on a cheaper header with a cheaper grade of stainless... just my .002
jjagg0125 is offline   Reply With Quote
Old 03-07-2011, 10:52 PM   #4
siikfast
Member#: 276110
2006 WRX
Gray
Agree With this, One thing to add is, Put the header on, before you weld the slip joints and mark the tubes.. Not every header is built equal.
STI_GUY_06 - Dont double the gasket, Take it to a pro- and have them surface the flanges. Second, Dont buy cheap. Buy a header that is made of a good quality stainless. Its not cheap to be cool!
siikfast is offline   Reply With Quote
Perrin catback,megan dp,megan header and more Derek C Engine/Power/Exhaust 9 08-27-2009 06:39 PM
FS:Perrin Catback, Megan Header, Megan dp and more Derek C Engine/Power/Exhaust 9 07-18-2009 06:55 PM
02-03 Wrx Brand New GT Spec Megan Headers, uppipe, Header Wrap dezwrx03 Private 'For Sale' Classifieds 0 10-02-2004 05:14 PM
CA: 02-03 Brand New Megan headers w/ flex uppipe + header wrap dezwrx03 Private 'For Sale' Classifieds 1 09-04-2004 10:46 PM
('93-'01) Borla Header weld leak Splat_One Impreza Forum 4 09-03-2001 01:26 AM
