Old 03-04-2011, 08:14 AM   #1
haze89
Member#: 275036
Default Engine No- star issue
I have a 1995 Impreza L 1.8L 5-speed manual AWD who's sometimes its engine fails to start. After letting it rest a while it will start and run normally. The ignition coil is working good because while the engine running I disconnected each spark plug wire and they all have a strong spark.
This is what i've done so far:
Replaced spark plugs
Replaced spark plug wires
Replaced fuel filter
I hooked up a fuel pressure gauge to the system and is giving 30psi, specs says it is supposed to do about 26-30 psi. But since then I haven't had the no-start issue until this morning. It failed to start, I open the hood and the gauge read 20 psi, I turn the key OFF then ON and I heard the fuel pump relay activating, I went back under the hood and fuel pressure was at +30 psi. Finally I cranked over and over and it wont start, fuel pressure at this point was at 15 psi. I turn OFF and ON the ignition then I had almost 40psi, crank it and the engine ran normally and fuel pressure at steady 30psi. Now the question is....Is it normal to have 15-20 psi after cranking the engine over and fail to run?? Is is possible the fuel pump to fail some times? After the engine is running it continue to do it normally, although some time I have hesitating issues when I let the engine reach like 500rpm when taking off in 1st gear
haze89 is offline   Reply With Quote
SOCAL: 04 JBP WRX (front end dmg, no engine no tranny) paulsaidhi Complete Car Part-Out 1 07-17-2009 11:00 AM
SOCAL: 04 JBP WRX (front end dmg, no engine no tranny) paulsaidhi SCIC Private Classifieds 18 07-14-2009 06:50 PM
Got Protuned No a Issue At 7k RPM's spoolinsti05 AccessPort 6 08-21-2007 11:44 PM
Assuming no alignment issues, what is the best performing (dry) tire that is QUIET! Drew888 Tire & Wheel 0 04-12-2005 09:30 PM
60,000 miles. . no tranny issues 855m0n0 Transmission (AT/MT) & Driveline 18 06-30-2004 10:22 PM
