Old 03-04-2011, 08:43 PM   #1
Overboosting04
Member#: 202417
04 WRX
EJ207/Rotated/E85/6spd
Default External wastegate fab help needed
Ive got the new tial 38mm wastegate and want to modify my invidia uppipe to make it work but ive got a few questions is 321 stainless a better choice even if the uppipe is 304 and what size pipe would be the best to have the flange welded on(im assuming the wrong diameter pipe could cause boost creep and other problems). Heres what im looking at
http://www.burnsstainless.com/321sstubing-6.aspx
Overboosting04 is offline   Reply With Quote
Old 03-04-2011, 09:20 PM   #2
TIGWERKS
Member#: 256615
use 1.75" tube as it will slide into the counterbore on the inlet flange. 321 is best but 304 will do, just brace it for extra security. I strictly use 321 on all preturbo tubing.
TIGWERKS is offline   Reply With Quote
Old 03-04-2011, 09:40 PM   #3
Overboosting04
Member#: 202417
04 WRX
alright thanks and im assuming the 16 gauge would be the best?
installing a external wastegate please help. bradsti Newbies & FAQs 4 08-17-2009 06:37 PM
ATX: External Wastegate Gasket - I need one lovethebugeye Texas Impreza Club Forum -- TXIC 6 02-25-2008 06:19 PM
SZ49 perfection? External wastegate help needed ESEMES Proven Power Bragging 20 05-15-2005 11:21 AM
external wastegate sound clip needed bottlediger Factory 2.5L Turbo Powertrain 22 02-01-2005 02:40 AM
Exhaust fab shop for external wastegate setup paulw North West Impreza Club Forum -- NWIC 1 01-24-2005 10:55 PM
Message Board Statistics All times are GMT -4. The time now is 05:22 AM.
