Welcome to the North American Subaru Impreza Owners Club Sunday October 23, 2016
Old 07-14-2002, 03:20 PM   #1
Member#: 3768
Thumbs down DEFI gauges....
I have three Defi gauges. Boost, EGT and Fuel Pressure....the boost works fine, the fuel pressure needle wiggles a little, and the EGT needle wiggles a LOT! What is the deal! I am going to send it back and get a new one and see if it fixes the problem!!!! I really hope so! Anyone else had this same problem? Please enlighten me on how to remedy it!
adamsrs is offline   Reply With Quote
Old 07-14-2002, 11:41 PM   #2
Member#: 19295
Defi gauges are very sensitive to having a good ground....Try running the ground wire from the control unit directly to the negative terminal on the battery, and see if that doesn't fix the problem...
silvercharged is offline   Reply With Quote
Old 07-14-2002, 11:44 PM   #3
Member#: 3768
BUT THAT STILL MAKES NO SENSE! THE Boost gauge is fine! But the other two SUCK!
Old 07-15-2002, 01:09 AM   #4
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
I think it is normal.
They are just sensative. Very sensative. Also, they are "stepper motor" type gauges. Thats another reason why they are jerky.
Boost characteristics are much more stable than fuel pressure and EGT.
Fuel pump, doesn't pump constantly. It works like a heart. Pump, pump, pump, pump, pump... Not ppppppppppppppuuuuuuuuummmmmmmmppppppp. Thats why we have a fuel pulse dampner in our fuel sutem. So the niddle is jerkies since it is reflecting true real time fuel pressure.
Same with EGT. Exhaust pulses are very uneven and have diff temps based on what cylinder they come from.
Of course, they do need good ground. That could make them jerk for a different reason.
I don't know if you guys have seen SARD's STACK meter panel. Its the one that replaces the OEM center dash console. On its RPM gauge, the niddle is also jerly. It displays RPM in real time. Not like the stock "mushy" RPM that lags and fogvives engine's behaviour.
Imprezer is offline   Reply With Quote
Old 07-15-2002, 03:46 AM   #5
Member#: 2038
2000 RS-T
Silverthorn Metallic
Same prob here w/ the EGT. I had it fixed and now it is doing it again. I can tell what the temp is, but all the bouncing around is very annoying. Boost reads perfect, nice and smooth.
Kcz is offline   Reply With Quote
Defi gauges, Defi link,Greddy gauges,Fuel cut defender Dr. Dooms Interior/Dressup/Audio & Security 3 04-15-2010 09:44 AM
Defi gauges and new defi triple Gauge pod UGSTi NWIC Private Classifieds 7 01-19-2010 10:29 AM
Defi Gauges & Defi Triple Hood Gauge Holder $300 jzsurfer5 Interior/Dressup/Audio & Security 20 06-11-2009 04:48 PM
Defi Link Imperial and BF Gauges--Defi Blue and Red Racer Gauges--Defi Gauge Pods! Spun Autosports Gauges & Electronics 165 04-03-2009 07:52 PM
Defi BF amber gauges, Defi Gauge Pods, and NEW Black/Amber Apexi Turbo Timers!!! Z1 Performance Interior/Dressup/Audio & Security 3 07-05-2006 10:28 AM
