Old 03-05-2011, 04:36 PM   #1
Geoffman72
Member#: 27891
2001 Impreza 2.5 RS
Blue Ridge Pearl - R.I.P.
Default 2007 OBS troubles
Hi all,
Vehicle in question is my girlfriends 2007 OBS with the 4EAT and 46,xxx on it. She bought it back in September and its having a few issues so we'll start with the one that could be the biggest problem.
1) Transmission slam shifting itself from first to second when cold and light throttle. I've only had it happen to me once but she complains of it happening most nights leaving work.
2) Throttle surging at the transition from low speed coasting to light throttle. I've seen theres a reflash available for this issue but the dealer I go through seemed hesitant to apply the fix.
3) Cranks over but wont fire on cold mornings when I've started it for half a minute to get my car out from in front of hers. Flooding and 2007 shouldn't be in the same sentence with the mileage on it.
Anyone had a similar experience? TIA
Geoffman72 is offline   Reply With Quote
Old 03-05-2011, 08:20 PM   #2
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
1) Well when the transmission is cold and the weather is cold, the fluid is cold and it can be very jerky to almost hard shifts during shifting until the fluid warms up. Have her warm the car up for 5-10 minutes and drive and see if that helps. Starting a car up when it is cold out and immediately driving it and expecting flawless operation isn't going to happen.
2) Ignore the reflash for now and address the problem by having a technician diagnose the issue. Everyone on the internet reads and interprets the term reflash and assumes this fixes everything. She may have already have the most updated logic in the ECU.
3) Are you giving it gas when this happens or are you starting the car without giving it gas? I ask this because there are people that still mash the gas medal on fuel injected cars and wonder why they are hard to start. If that is not the case, you could have a fuel issue or a fuel pressure issue.
blackfang is offline   Reply With Quote
Old 03-05-2011, 08:20 PM   #3
blackfang
Member#: 131347
2007 Legacy 2.5i SE
Double post.
Old 03-05-2011, 08:53 PM   #4
Geoffman72
Member#: 27891
2001 Impreza 2.5 RS
I should add that I work on all my cars and don't usually have a problem with diagnosis. Just seeking other opinions to see if there anything I've missed before I take anything apart.
When I said slam shifting I didn't mean anything that could be confused with cold fluid but more akin to a screwdriver being jammed in the flywheel teeth for a split second between shifts. It acts like the TCU is confused for a second at light throttle.
For problem number two, techs at the local dealer have diagnosed twice for all three of these problems and couldn't find anything. They knew of the reflash but since it didn't have a problem for them they were hesistant to do that.
For problem three, definitely not a thought of giving it gas until the final act of treating it like a flooded carbureted car. It did start after sitting for a min then giving it part throttle to let air clear the cylinders.
To be perfectly honest any time I drive the car 99% of the time its as perfect as a 5 year old Subaru with 46k should be. Only issues I've had are the one time it shifted hard, then once when it didn't start, and a few instances of light throttle surging.
Just want this solved so my girlfriend will stop being so doom and gloom about her car. Don't want her getting a bad taste for Subarus after my RS has been mostly bulletproof for 160k!
Old 03-06-2011, 12:49 AM   #5
JustROLLIN
Member#: 267646
2007 2.5i Wagon
Pearl White
#1 & #2
I have both of those issues to some degree. Mine does not "slam" into 2nd gear, but it does shift rather firmly. As mentioned above, this is not all that uncommon in cold climates. I am located in MN, so needless to say, its something I have experienced before on many different vehicles.
JustROLLIN is offline   Reply With Quote
Old 03-06-2011, 12:55 AM   #6
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Has anyone checked the ATF fluid?
Old 03-06-2011, 07:39 AM   #7
blackfang
Member#: 131347
2007 Legacy 2.5i SE
Ok, but does this happen when it is cold out and the vehicle has not been warmed up or does it happen all the time? I ask this is because if the fluid is cold, the TCM will act a little more erratic and hard shifts can be expected. The TCM also reads the fluid temps too. Also sometimes when it is cold it will shift faster into higher gear to allow it to warm up to operating temps faster.
If the above is not an issue and this happens all the time when warm and cold have you checked the fluid levels?
As to why the techs did not reflash the vehicle that is odd. Since they have diagnosed the issue and found nothing and they know there is a reflash for it and the ECM does not have the current logic, then they should have reflashed it. Reflashes are covered for 8 years or 80k whichever comes first.
Old 03-06-2011, 09:40 AM   #8
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
The OP clearly stated that it happens when its cold and fist driving. So obviously the fluid is cold. The "techs" didnt flash the ecu because they could not reproduce the problem. Flashing changes many things and can cause "problems", in high mile/wear vehicles its more likely to cause unwanted behavior. If the vehicle was fine before and now shifts abnormally, software is unlikely to correct it.
Personally id say changing the atf fluid for a quality syn fluid would be a good place to start. It will have more stability across temp range and probably needs to be done anyway. I think its recommended at 40k miles by subaru and its cheap and easy to do.
Old 03-06-2011, 12:57 PM   #9
blackfang
Member#: 131347
2007 Legacy 2.5i SE
There is nothing in the OP that clearly states when it is first driven only. He mentioned when cold and most nights and it only happening once to him. That is why I inquired with my posts to see if it is happening all the time when driving or only when first driving because it could be user error. There is a difference in cold fluid when first driving verse the same but in cold weather. I have seen several people who complain of the same thing and in most of those cases it is because they jump in the car when it is cold outside and go and expect the car to drive normally. That is not always the case.
There is nothing wrong with reflashing a vehicle that has an issue when they have ruled all other possibilities out. I wouldn't reflash a vehicle as the first step without looking at other components first. If there is a reflash out there for that concern, and the ECM doesn't have that current logic already, then reflash it.
Also, please explain what kind of problems reflashing a ECM with factory programming can do?
How does 46k equate to high mileage?
The reflash was not for the hard shifting, it was for throttle surging from low speed coasting and light throttle.
Changing the fluid will not address that concern if his concern is related to driving when the trans fluid is cold and the temps are cold. Even synthetic fluid will still do the same if it is 10-20 degrees out and you just jump in the car and go. Also Subaru recommends replacing the fluid every 15,000 miles in severe service, but recommends inspecting it at 30k. We always changed the fluid at 30,000.
Old 03-06-2011, 05:54 PM   #10
archdude
Member#: 205968
My car used to shift a little jerky sometimes back when I had about 10k miles on it. Once i flushed the trans fluid, it seemed to stop happening. Check the ATF fluid, if it's not clean/pink looking then it's worth a change regardless.
archdude is offline   Reply With Quote
WTB : 2002-2007 OBS stock suspension twagoon NWIC Private Classifieds 2 01-28-2011 11:08 PM
97 OBS trouble starting.. not the battery... nperkins Electrical & Lighting 3 01-27-2010 08:52 AM
30 MPG in 2007 OBS supernootz General Community 1 08-26-2007 09:57 PM
Trouble finding Brake Pads & Rotor 2002 OBS Mayor McCheese1 Brakes, Steering & Suspension 4 09-12-2005 12:51 PM
