Old 08-22-2012, 10:34 AM   #501
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Originally Posted by K1WRC View Post
While I agree they should be on a 9" rim, I also have the 235 size on the same size rim and they are similar but not nearly as bad
it isnt the tires...it IS your suspension/chassis that is sloppy
Old 08-22-2012, 11:59 AM   #502
K1WRC
Member#: 64511
2003 WRX sedan WRB
VF36 EJ207
Nope, it is definitely not that, I have fairly stiff coilovers RCE Tarmac 2's with the 500f and 400r springs and every bushing is either poly or tic delrin stuff. (well all except the inner front control arm bushing). I think I just made the mistake of putting 255's on the Sti bbs wheels and trying to track on them. While there was good grip the transitions were squishy
K1WRC is offline   Reply With Quote
Old 08-22-2012, 03:30 PM   #503
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
then if you dont have hd cowl stays and srut tower bars and a lower arm bar and all the chassis braces ya can get on the car.....then yeah
ya end up with sidewall flex and chassis flex and the bugeye gd is REALLY sloppy up front
the hd cowl stays...if ya dont have them...should be the first thing you buy
also...what front strut tops???
Old 08-22-2012, 03:41 PM   #504
K1WRC
Member#: 64511
2003 WRX sedan WRB
VF36 EJ207
I have the fender braces and a lower arm bar. No strut tower bar though. I do have the TIC x brace for the rear. I have GTWORX pillow ball strut tops front and rear. I honestly just need to try em on some 17x9's. The last 2 track days I have just found them to be a lil squishy. I think in comparison to the NT01's I ran before these, the RS3's just feel a little weird till they take a set in the corner (mainly higher speed corners)
I think when you compare the RS3's to the Dunlop Star Specs, AD08's and RE11, the RS3's have a little softer sidewall, at least that is what I have read
Old 08-24-2012, 08:54 PM   #505
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
The sidewalls on my conti DW tires are so soft, that many times a week I'll be looking at my car and feel the need to check my tire pressure because they look kinda low. Only to find out they are fine.
For the price though, they grip well and are decent off-road (gravel, dirt, sand). Definitely a good purchase.
ManualOverAuto is offline   Reply With Quote
Old 10-04-2012, 02:24 PM   #506
RM3851
Member#: 232522
'13 STi
WRB/Ag Croatianized
I got Nitto NT555 tires (35PSI all around) on an 05 STi in a 235/40/18 size on Enkei NT03 (18x8.5et38) sitting on KW V3s/Whiteline 24 f/r + Kartboy endlinks, and -1.1 degree alignment all around combo...
Street driving only, SoCal weather and OC roads. Can not find a better place to DD this setup...
cca 5500 miles now, and tires are loud(er?). Tires were somewhat loud right off the bat, installed them brand new with the wheels BNIB on the same day.
Yesterday they were rotated, balanced, re-aligned and I just hit the local toll road and I feel as my wheel bearings wanna jump off the hub. Also, they formed slight cupping on the sides.
Thank God we have Luke@TireRack and, as always, he was more than helpful over the phone.
Tread pattern and 300A rating on this rubber make it no Mercedes ride, as expected, but I did not expect it to be SO loud.
Even with the catted Invidia/GReddy Evo2 exhaust I can hear them pretty well.
Now, I am done complaining.
Thanks for reading.
Rob
RM3851 is online now   Reply With Quote
Old 10-05-2012, 12:46 AM   #507
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Thanks for reading.
Rob
so ya bought garbage tires and likely have a bad alignment and didnt rotate the tires often enough
wassa big deal??
Old 10-05-2012, 01:50 AM   #508
RM3851
Member#: 232522
'13 STi
WRB/Ag Croatianized
wassa big deal??
Wow, what a big boy comment over here. Let me guess, your Einstein suggestion will be to get a 140AA tread tire for the street use aka RS3s?
Tell me, you rotate your tires more often than every 5k?
And my RADICAL alignment specs bug you so you cant sleep at night?
Tell me more, Im curious...
Good job!
Old 10-05-2012, 06:00 AM   #509
krzyss
Member#: 8365
2005 Legacy GT Ltd
Atlantic Blue
Nope. Uncle will try to convince you to buy Federal S595 RS-R.
"Tread pattern and 300A rating on this rubber make it no Mercedes ride, as expected, but I did not expect it to be SO loud"
As as far as I know tread pattern has impact on comfort, noise comfort precisely but treadwear and traction (you missed temperature rating) has next to none.
So NT555 are loud, how Luke helped to fix this problem? Suggested louder music or different tires?
Krzys
krzyss is offline   Reply With Quote
Old 10-05-2012, 08:32 AM   #510
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Good job!
OK...yer an idiot
NEXT!!!!!
Old 10-05-2012, 11:50 AM   #511
RM3851
Member#: 232522
'13 STi
WRB/Ag Croatianized
Krzys
My main preoccupation was to get a professional input on the humming coming from the tires at certain speeds; whether it was rubber related, or my hub was going.
Since I just rotated and re-balanced, the hum didnt diminish, so Luke was on the speed dial.
Yes, I forgot, it is a 300AA tire...
Old 10-05-2012, 11:51 AM   #512
RM3851
Member#: 232522
'13 STi
WRB/Ag Croatianized
OK...yer an idiot
NEXT!!!!!
Awesome! Go tell your mom to make you a meatloaf.
Old 03-11-2013, 07:48 PM   #513
Kantnerner
Member#: 341977
2007 WRX wagon
I will be running 18x8.5 +48 very shortly. I am looking for 225/40 tires. These will see the roads only from april-august in PA. So basically a 100% summer tire. They need to be good in rain but they dont need to be AMAZING or praised for their rain performance.
Whats the "best bang for your buck" tire?
Kantnerner is offline   Reply With Quote
Old 03-11-2013, 08:22 PM   #514
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
it aint the nitto nt555 that the idiot, above, bought
Old 03-11-2013, 08:23 PM   #515
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Yes, I forgot, it is an idiot tire...
yeah...how'd that work out for ya
Old 03-15-2013, 12:36 AM   #516
faraco3
Member#: 231272
06 STi
FLI Stage 2.5 288/311
Default New RE-11A's
I just noticed on tirerack that there is a new Bridgestone Potenza Re-11A. I am looking to get new tires in the next month or so and am looking to see if anyone has these yet and how they feel about them.
http://www.tirerack.com/tires/tires....I&autoModClar=
faraco3 is offline   Reply With Quote
Old 03-15-2013, 11:35 AM   #517
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
Merged
Old 03-15-2013, 11:53 AM   #518
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
They are considerably less expensive and have a longer wear rating so I'm guessing less sticky rubber with same tread pattern. Probably a reasonable buy on a street only car.
A-man07 is offline   Reply With Quote
Old 03-15-2013, 09:06 PM   #519
Subydude81
Member#: 118266
2007 Lexus IS250 RWD
6MT
Uncle Scotty has alot of good info but to say the Nitto NT555 is garbage is not one of them.
I ran the NT555 and a bunch of other tires in the same category and the Nitto was the best in the price range.
Subydude81 is offline   Reply With Quote
Old 03-17-2013, 04:38 PM   #520
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
so ya had the best sack of **** in the pile of sacks of ****
brilliant
BRILLIANT
still garbage
Old 03-17-2013, 08:35 PM   #521
Subydude81
Member#: 118266
6MT
brilliant
BRILLIANT
still garbage
Would be nice if you had some facts to back that up, which you don't. Not everyone likes to run those piece of **** Federal ss595 or RS-R. And yes they are pieces of ****.
Old 03-17-2013, 08:41 PM   #522
krzyss
Member#: 8365
2005 Legacy GT Ltd
Atlantic Blue
Kettle meet pot, pot meet kettle.
or so it seems.
Krzys
Old 03-17-2013, 11:04 PM   #523
JonnyV2889
Member#: 197384
2006 WRX Ltd
Is tire rack still going to have monopoly on the new star spec as well?
JonnyV2889 is offline   Reply With Quote
Old 03-21-2013, 08:43 PM   #524
bassplayer5504
Member#: 296521
2003 WRX wagon
Stage 2
Been looking and researching but not finding for sure answers.
I have dedicated studded winters. Look for a summer performance that is somewhat not noisy and is comfy but great cornering traction with wet and dry traction also.
Looking for 225 40 18 going on OZ Superleggera 18X8 +35.
Was intially thinking re760 but a little pricy. Maybe Kuhmo Ecsta SPT? Let me know some personal opinions please!
bassplayer5504 is offline   Reply With Quote
Old 03-21-2013, 09:57 PM   #525
krzyss
Member#: 8365
2005 Legacy GT Ltd
Atlantic Blue
If you do not like re760 pricing I bet you will not like Michelin Pilot Super Sport.
Maybe buy cheaper wheels and better tires?
Krzys
PS I did like Hankook Evo V12 but I think Goodyear Eagle F1 Asymmetric 2 are even better.
The Winter Tire thread- all winter tire questions go here !!! Luke@tirerack Tire & Wheel 3487 05-28-2013 09:59 AM
THE Chico Meet Thread: Post all Chico Meets here mrbodega15 Bay Area Impreza Club Forum -- BAIC 2021 05-17-2013 02:57 PM
Absurd science questions go here -=C=- Off-Topic 319 05-09-2011 03:20 PM
Performance All-Season Tires or Max Performance Summer Tires Skiitec Tire & Wheel 18 02-08-2010 12:53 PM
WTT: Winter wheels/tires for all-season wheels/tires igor New England Impreza Club Forum -- NESIC 7 02-02-2005 02:34 PM
Message Board Statistics All times are GMT -4. The time now is 04:45 PM.
