Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 03-07-2011, 02:48 PM   #1
dahlinc
Member#: 151810
2003 Subaru Wrx
Default Axle Questoin
So the other day when I fixed my front sway bar i noticed that my axle on my passenger front was leaking some goo probably grease.
Im sure thats not good, but im not sure how urgent it is to be fixed?
and how hard it would be to fix?
any input is appreciated
thanks
dahlinc is offline   Reply With Quote
Old 03-07-2011, 03:07 PM   #2
PCSkiBum_21
Member#: 164437
EVO IX - Track Car
BRZ - Daily
you likely need a cv boot rebuild kit. you can get them from the dealer. it's pretty cheap, but they're a pita to change. i would pull the axle out of the car and take it somewhere to have them replace the boot. solid did my last one for me.
PCSkiBum_21 is offline   Reply With Quote
Old 03-07-2011, 03:28 PM   #3
subiewrx001
Member#: 193591
04 WRX VF34
water/meth, spt intake
I just had les schwab do mine a month ago for $200 for a brand new axle cause your downpipe cooks the boot so I wanted a brand new rather than a refurbished and make sure you tell them you want a new one at les Schwab or they will put in a remanufactured one
subiewrx001 is offline   Reply With Quote
Old 03-07-2011, 03:35 PM   #4
dahlinc
Member#: 151810
2003 Subaru Wrx
awesome thanks for the info!
is it pretty pressing to get it changed?
do you think waiting like 2 or 3 weeks would be bad?
Old 03-07-2011, 03:36 PM   #5
godfather2112
Papi Chulo
Member#: 53794
2005 BMW M3 - 6spd
2007 Denali Land Yacht
You should be fine for a few weeks. If you start to hear loud clicking, then it's bad.
godfather2112 is online now   Reply With Quote
Old 03-07-2011, 03:46 PM   #6
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
Or you could get a reman axle at autozone for 60 bucks, and not have any extra downtime. Also you could realistically drive on the axle for quite some time depending on how quick it looses all the grease and gets exposed to the elements. And autozone no care that your core has been run dry until it started clicking, and if they do its only 10 bucks
Rick
scoobydorift is offline   Reply With Quote
Old 03-07-2011, 03:55 PM   #7
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
Also the install is not too bad, but it depends on your mechanical skills. You will need a long thin punch for the pin that holds the axle to the transmission stub, a big socket (cant remember the size, 32mm?) for the axle nut, a breaker bar, torque wrench, and you will need some way of popping the ball joint off the control arm. There are great writeups for the install on this forums, as well as videos on youtube I'm sure. I would give yourself an entire afternoon to do it.
Thanks,
Rick
Old 03-07-2011, 03:57 PM   #8
dahlinc
Member#: 151810
2003 Subaru Wrx
haha it took me almost 4 hours to figure out how to put my stock sway bar back on i think i would rather pay someone. my back still hurts from laying on the concrete haha thanks for the info though
Old 03-07-2011, 04:55 PM   #9
axleon2
Member#: 154117
2003 Forester
Did someone call my name?
axleon2 is offline   Reply With Quote
Old 03-07-2011, 05:32 PM   #10
dahlinc
Member#: 151810
2003 Subaru Wrx
haha maybe
whats your # ill give you a call when im ready
Old 03-08-2011, 12:03 PM   #11
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
There's a place in south salt lake called cv axle that will rebuild yours for pretty cheap. I had them do mine years ago
car_cursed is offline   Reply With Quote
Offset Calculation Questoin MY99 2.5GT Tire & Wheel 2 08-27-2003 05:29 PM
questoin about tires WuWrx Tire & Wheel 7 06-20-2003 03:10 PM
quick questoin. Tragic Southern California Impreza Club Forum -- SCIC 2 12-31-2002 12:48 PM
questoin about the ISR oil drain line smacksube Normally Aspirated with bolt-on Forced Induction Powertrain 3 12-10-2002 03:25 AM
Questoin on Equalizers Scoobie Newbie Car Audio, Video & Security 4 07-10-2002 01:48 AM
