#1 |
Member#: 273302
Vehicle:1993 legacy sport white |
Hello i am new to the site i own a 94 legacy wagon n/a. I have been looking around and thare are alot of options to choose from.
i am looking to upgrade the hp and torque and possibly with out messing with the ecu any suggestions will help thanks.
#2 |
Member#: 187936
Vehicle:97 Legacy w12:1CR 05 LL Bean outback |
2.2/2.5 hybrid.
/thread |
#3 |
Member#: 275412
Vehicle:1998 Legacy L green |
I own a 1998 legacy l with a 2.2 also. to my knowledge we cant do much with our engines. our engines basically stay stock. i have been searching for a year and i only found one thing and it is out of stock everywhere. it is a single port exhaust header.
#4 |
Member#: 139989
Vehicle:C6 Z51 Corvette 2000 Impreza beater |
I heard you can put 251 cams in to increase throughout the entire power band without any modification to the ecu.Also another option is to find a junkyard 2.5 longblock and drop that in.
#5 | |
Member#: 187936
a 2.5 long block is a wiring challenge apart from forced induction the 2.5l short block 2.2l head combo is the most cost efficient way to make more power op get a NA 2.5L (doesn't matter what year just as long as it's an ej series) and bolt your 2.2L heads to it, run 89 octane and be done with it |
#6 |
Member#: 273302
with the 2.2/2.5 will everything match up if not what will i half to rework or change
right now i am working on the heads and i am finding it very difficult to compress the valve springs any tips on the best tool for the job thanks for the help |
#7 |
Member#: 187936
everything should match up perfectly, only change is the head gasket and the crank sprocket ( use the one from you 2.2L )
with MY94 heads I'd figure the comtec gaskets designed for this combo would be your best ( read this thread too: http://forums.nasioc.com/forums/showthread.php?t=631527) you can rent a valve spring tool from advance or auto zone that looks like this: ![]() makes taking the valve train apart much easier |
#8 |
Member#: 142972
Does anyone have part numbers to look for?
#9 |
Member#: 273302
thanks for the help
| Thread Tools | |
| Display Modes | |
| FS : Sold | jaybirde978 | 1993 - 2001 Impreza Specific Parts | 6 | 03-14-2011 07:26 PM |
| costs of a 2.2 rebuild/upgraded internals? | legacy2003 | Normally Aspirated Powertrain | 9 | 05-03-2004 04:06 PM |
| 2.2 rebuild options | serious | Legacy Forum | 0 | 12-06-2002 03:30 PM |
| Turbo 2.2 rebuild | serious | Legacy Forum | 13 | 10-22-2002 10:57 AM |
| Who can rebuild/upgrade an IHI VF23? | 2OHOH2WRX | Factory 2.0L Turbo Powertrain | 7 | 09-05-2002 08:34 AM |
