Old 03-07-2011, 10:26 PM   #1
krismo
Member#: 139053
Default misfire cylinder 2 and 3 !!! Anyone seen this before?
Still dealing with rough idle and stalling at stop signs.
It's not coil pack or spark plugs.
Why misfire on Cyl. 2 and 3? Can this tell something?
It's a 2005rs with 80k on it.
H e l p p l e a s e !!!
krismo is offline   Reply With Quote
Old 03-08-2011, 02:02 PM   #2
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
Then its probably head gaskets. Check your coolant, see if its low and see if theres any air bubbles in it.
Samirr76 is offline   Reply With Quote
Old 03-08-2011, 03:14 PM   #3
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
How did you come to this conclusion? There are so many other things that are easy to chk and easy/cheap to fix. Besides a bad headset usually has other symptoms. stalling and rough idle are not typical symptoms of a bad head gasket.
OP - any recent maintenance or out of the ordinary events like driving through deep water? Any mods? misfire can be caused by so many things that its not enough by itself to narrow much down. Plugs, wires, coilpacks are god to chk on the spark side of things. How have you ruled out the plus and coils? Inspect the Intake system for damage or loose couplings, the MAF sensor for security and the wiring harness for damage/security. Fueling could be the culprit too. How many miles on the front O2 sensor? Exhaust leak pre O2 sensor?
Old 03-08-2011, 04:22 PM   #4
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Something else that's free to check/fix is to see if the cam timing is off.
Old 03-08-2011, 04:54 PM   #5
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
^if the cam timing was off wouldn't it be a miss fire for both cylinders on one side not just one cylinder on each side? Cyl 2 and 3 are on opposite sides. You can check valve lash though it's not likely. Maybe clogged injectors, ICV or exhaust leak. You should get the codes pulled with Freeze frame so you can see when the misfire is happeneing. there are too many things that cause a misfire.
aclver1 is offline   Reply With Quote
Old 03-08-2011, 06:42 PM   #6
Y_I_K_E_S
Member#: 159449
2005 WRX STi
"Ali"
Plug wires?
Y_I_K_E_S is offline   Reply With Quote
Old 03-08-2011, 08:17 PM   #7
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
Where did you get this conclusion? I have seen a ton of Subaru's with leaking, and blown headgaskets and not have a misfire.
OP- How did you rule out the coil? How about the wires? Have you tried swapping them to see if the misfire changes cylinders?
blackfang is offline   Reply With Quote
Old 03-08-2011, 10:08 PM   #8
krismo
Member#: 139053
I thought it was my plugs so I changed them to brand new OEM plugs.
Then I though it was my coil pack - I swapped it with someone with no help. I also changed PCV valve, battery and I had my alternator checked.
I can data log but I don't know what to look for. Somone had a lookie, and they said that there is something wierd with my rear O2 sensor.
Could that couse rough idle/misfire?
Thanks for all your help!
Old 03-08-2011, 10:19 PM   #9
blackfang
Member#: 131347
2007 Legacy 2.5i SE
I can't see a rear oxygen sensor causing it, but a bad front one can cause the ECM to add more fuel or cause it not to add enough. What have you done about wires? have you swapped them? Check for arcing?
Old 03-08-2011, 10:39 PM   #10
krismo
Member#: 139053
Still original wires. I did check the resistance though, sprayed it with water, and had a look when it was dark.
Old 03-08-2011, 10:40 PM   #11
blackfang
Member#: 131347
2007 Legacy 2.5i SE
Hmmm... Spark plugs are gapped correctly?
Old 03-08-2011, 10:44 PM   #12
krismo
Member#: 139053
Yeah, I thought that front O2 sensor could be at fault, but I guess they work as a pair, so rear sensor can fool the front one...?
I don't know if it makes sense, but that's how i understand it.
Old 03-08-2011, 11:24 PM   #13
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
If you can data log chk you're long term fuel trims to see if its a fueling issue that would point to an O2 sensor.
Old 03-09-2011, 08:23 AM   #14
Y_I_K_E_S
Member#: 159449
2005 WRX STi
"Ali"
OK, if your plug wires have 80k miles on them, change them. Even if they work fine right now, they're very near the end of their life cycle.
The rear O2 sensor on a 2005 RS can make very minor adjustments to your fuel trims, +/- 5% IIRC. That's all your ECU will allow it to make. It's only there to compensate for a degrading cat efficiency. Even if it was maxing the fuel trims to 5%, that shouldn't be enough to cause a misfire, and it sholdnt be causing a misfire on only 2 cylinders.
My bet is plug wires or injectors.
misfire cylinder 1 and 3? Scott_2.5TS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 60 09-20-2009 09:41 PM
Misfire on cylinders 2 and 3 after reflash Farns801 AccessPort 2 04-21-2008 09:09 PM
cylinder 2 and 3 misfire prometheum Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-26-2006 01:07 AM
Anyone seen this before? Beam Off-Topic 14 03-02-2004 06:13 PM
Anyone seen this before? R0ME02984 Member's Car Gallery 6 09-27-2001 02:57 PM
