Old 03-07-2011, 10:39 PM   #1
207STi
Member#: 197062
1998 Swapped Impreza
black
Default Does this seem about right?
So I'm trying to piece together everything I need for my GC swap project I have going on right now. The biggest thing I have been trying to cross off the list is a low mileage EJ205. I have found one locally with 51k on it. It includes wiring harness, ecu, and all the accesories.
So....
1.) They are asking 2,500. Does this seem fair?
2.) The motor is from an 04 AUTO wrx. Do you think it being an auto will cause me headaches when I bolt it up to my impreza L 5mt?
Let me know what you guys think.
207STi is online now   Reply With Quote
Old 03-08-2011, 11:53 AM   #2
207STi
Member#: 197062
black
bump?
Old 03-08-2011, 03:38 PM   #3
scoobie_snacks
Member#: 212744
2005 Ver8 EJ207 VF37
6 speed
The engine, being from an auto wrx or a 5sped is the same.. When you go to take off the auto transmission check under/near the passenger side intake manifold, there will be a rubber plug take that off and turn the engine over with a wrench and socket clockwise.. till you see some bolts.
Take them off and the torque converter will be free from the flexplate. once you have the engine apart unbolt the flexplate. and bolt up your flywheel. the block will bolt up to your 5speed no problem. make sure you put the clutch release bearing on the trans before you put the two together
scoobie_snacks is offline   Reply With Quote
Old 03-08-2011, 03:40 PM   #4
scoobie_snacks
Member#: 212744
6 speed
oh and the price is not bad but... You can find a wrx longblock for cheaper though.
wiring the engine is a whole other story if you don't already have the full turbo harness.
Old 03-08-2011, 10:27 PM   #5
207STi
Member#: 197062
black
The engine comes already seperated from the transmission, but I appreciate the detailed instructions. It includes all the accessories and complete engine wiring harness. However the sale does not include an ECU. So the next logical question.
Will any 02-04 ECU work with this motor? Does auto/manual make the ECU any different?
WRX / Hard start / cold temp / does this seem right? andygold Factory 2.0L Turbo Powertrain 3 12-28-2005 11:40 AM
Boost Questions...Does this seem right? bajatuner Engine Management & Tuning 2 07-21-2005 09:13 PM
Does this seem right? 2Fast4U2 Newbies & FAQs 32 12-26-2003 08:16 PM
does this seem right???? Ft_Laud_wrx South East Region Forum 7 03-24-2003 09:36 PM
does this seem right to you guys? EnterTheDragon North West Impreza Club Forum -- NWIC 6 03-05-2002 10:12 PM
Message Board Statistics All times are GMT -4. The time now is 06:51 PM.
