Old 03-08-2011, 10:49 AM   #1
fourdown
Member#: 230408
2006 Impreza 2.5i
Default Oil pressure switch location?
The other day I cold started my car and heard like a low taping or maybe a knocking noise. It did it between idle 700-800 rpms to a 1000 rpms, after that the noise is gone. I drove my car slowly to my house and got it in the garage to see if I could recreate the noise but didn't had luck.
Anyway i got an oil pressure gauge and want to make sure which on is the oil pressure switch. Can anyone confirm me if it's the one almost under the alternator. I have a 2006 Impreza 2.5i.
Thanks, any help would be much appreciated, I'm a little concern for the noise. It doesn't increments with rpm. In fact it disappears after 1000 rpm and you can't hear it on idle, just in between.
fourdown is offline   Reply With Quote
Old 03-08-2011, 04:25 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
yes, it's under the alt. does this noise happen even if it's warm started?
Old 03-08-2011, 05:18 PM   #3
fourdown
Member#: 230408
2006 Impreza 2.5i
Actually I heard the noise again today. It's very dificult to recreat because
it only does it between idle and 1000 rpm. If you go over 1k it can't be heard. And the problem is that my car id throttle by wire so I have to rev it from inside the car and can't figure out if it's from the block or the timing belt area like I've been hearing people talk about.
Any help with a similar problem would be much appreciated.
Thanks
Old 03-08-2011, 08:19 PM   #4
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
Ok, but do you hear this only when the engine is cold? How many miles?
blackfang is offline   Reply With Quote
Old 03-08-2011, 08:28 PM   #5
Jessekrs123
Member#: 236927
1993 Legacy Sedan
1984 BRAT
Are you sure it's not just normal valve train noise or maybe an exhaust leak? Subaru valve trains are rather loud.
Jessekrs123 is offline   Reply With Quote
Old 03-08-2011, 08:33 PM   #6
blackfang
Member#: 131347
2007 Legacy 2.5i SE
^ especially when cold. I have heard some that were close to a damn deisel engine...lol
Old 03-08-2011, 09:08 PM   #7
SiouxBe1
Member#: 157247
1991 Legacy L+AWD BJ
probably a sticky HLA (aka sticky valve lifter)
SiouxBe1 is offline   Reply With Quote
Old 03-08-2011, 09:14 PM   #8
fourdown
Member#: 230408
2006 Impreza 2.5i
Actually I drove a couple of miles today. I had to do some stuff today and even when the car was at normal temperature and drove it for a while I could hear it from time to time. So no, not just in cold. Actually the first time I heard it, it was a very cold day and it was more noticeable It's just difficult to recreate and is a low noise.
Old 03-08-2011, 09:16 PM   #9
fourdown
Member#: 230408
2006 Impreza 2.5i
No, it's not a valve train noise. I know what your saying and I've heard mine, but it's not the same noise.
Old 03-08-2011, 09:20 PM   #10
fourdown
Member#: 230408
2006 Impreza 2.5i
Today I drained my engine oil, but didn't found anything. At least nothing that I could see on a simple view. Since i got my drain pan really clean before draining the oil I got a magnet in the oil, but nothing came out of it.
Old 03-08-2011, 11:27 PM   #11
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
Except the ej 253 has solid with rollers
RaceFaceXC is online now   Reply With Quote
Heavy oil leak - oil pressure switch ? chuck_1686 Newbies & FAQs 4 06-10-2009 07:18 PM
A/C low pressure switch location? DFWrxWagon Service & Maintenance 6 02-26-2008 04:27 PM
A/C pressure switch location? DFWrxWagon Texas Impreza Club Forum -- TXIC 1 02-11-2008 01:09 AM
oil pressure sender location on 04 STi t00r t0g Interior & Exterior Modification 2 11-13-2004 11:49 AM
Oil pressure mounting location ellisnc Factory 2.0L Turbo Powertrain 11 10-29-2001 07:16 AM
Message Board Statistics All times are GMT -4. The time now is 11:21 PM.
