Old 07-15-2002, 12:10 AM   #1
MattDell
Member#: 16803
Default Why is the injen intake like this?
How come it gets the air from around the wheel well?
MattDell is offline   Reply With Quote
Old 07-15-2002, 12:12 AM   #2
cindergarden
Member#: 21158
94 FWD 2.5
Acardia Green
because (correct me if im wrong) the air in teh wheel well is 10 degrees cooler which will give you a 1% hp gain either way its colder air pushing in
cindergarden is offline   Reply With Quote
Old 07-15-2002, 12:25 AM   #3
MattDell
Member#: 16803
Sounds fair, I know they just didn't stick it there for the hell of it, I just wanna know why they chose there.
Old 07-15-2002, 12:26 AM   #4
AzNStiImpreza
Member#: 17181
2008 Impreza STi
Dark Grey Metallic
Default hmmm
i have the injen intake. i drove my car around for 30 minutes and came back. i opened the hood and it was steaming in there. i took off the little cover next to the hole where the intake enters the fender. i stuck my hand in there, and it is noticable cooler than it is in the engine bay. it is actually a lot cooler. they dun ahve official dyno charts for the intake, but i had the rallispec intake before i installed this one, and the injen actually performs a better. i think it is becuz i didnt have a heat shield for the rallispec. my bro has a 97' nissan 240sx. The injen intake for his car does almost the same thing, and the dyno charts reviel that it adds 14.9 hp to the wheels to the car. not bad not bad.
AzNStiImpreza is offline   Reply With Quote
Old 07-15-2002, 08:01 PM   #5
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
14.9 to the wheels!??.....correct me if im wrong but 14.9 to the crank is a little excessive for just a intake alone.
AustinSTi is offline   Reply With Quote
Old 07-15-2002, 09:57 PM   #6
OutbackMack
Member#: 21035
2000 Legacy Outback
White Birch on Sandlewood
Thats the same exact one I've got on order....Hopefully it'll be in this week...
Now with that upgrade, the exhaust is next...has to be next.
OutbackMack is offline   Reply With Quote
Old 07-15-2002, 11:46 PM   #7
AzNStiImpreza
Member#: 17181
2008 Impreza STi
Dark Grey Metallic
Default yea
im not lying, and im sure injen isnt lying. go to www.injen.com .look around, and ull probably come buy nissan 240 sx somewhere. check the dyno chart. also, i have an issue of sports compact car, and it also displays 14.9 whp gain for the 240sx. oh yea, apex n1 cat-back gives the 240sx 15hp to the wheels also. 30whp from intake/exhuast sounds incredible and unbelievable. better believe it.
Old 07-16-2002, 12:45 PM   #8
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
Default Re: yea
Originally posted by AzNStiImpreza
... and it also displays 14.9 whp gain for the 240sx. oh yea, apex n1 cat-back gives the 240sx 15hp to the wheels also. 30whp from intake/exhuast sounds incredible and unbelievable. better believe it. [/b]
I don't think it works out that way. You can show that one mod can add X amount of HP compared to stock and another mod adds Y amount of HP compared to stock. But you can't add X and Y together for total HP gained with those two modifications.
-vic
cRayZee is offline   Reply With Quote
Old 07-16-2002, 01:12 PM   #9
Reciprocity
Member#: 1165
1990 dcrawford died
for your sins
I highly suggest wrapping that long aluminum tube with something to prevent heat soak. Aluminum is a very good heat conductor and all that exposed piping in the engine bay is going to be effected by the heat the engine is producing. Every little bit helps!
And as far as the 240 goes...who knows, maybe the stock intake was really restrictive. Either way...it doesn't matter 'cause a 240 is not a Subaru.
NC
Reciprocity is online now   Reply With Quote
Old 07-16-2002, 03:56 PM   #10
AzNStiImpreza
Member#: 17181
2008 Impreza STi
Dark Grey Metallic
Default uh huh
exactly, 240 is not a subaru. but ne way, i have the injen for my car, and it is really good, better than the rallispec that i had before. mainly cuz i didnt have a heat shield for the rallispec. just go to www.injen.com . they have dyno charts for most of the cars they provide intakes for. average gain is 10 whp. oh yea, about the 30 whp intake/exhuast comment i put down, maybe im wrong, but that is the way i look at it. im simple minded. ahahaha.
Old 07-16-2002, 05:07 PM   #11
ObsidianRS
Member#: 17042
2004 Impreza WRX STi
Blue/Gold
To see why you can't add up mod hp, check out cobb's site. They have dynos for their Stage 1 and Stage 2 NA packages.
Baseline = 122 whp
Stage 1 = intake + cat-back = 135 whp (+ 13whp)
Stage 2 = intake + cat-back + headers + pulleys + cat = 145 whp (+ 23 whp)
So, no, you will not make 30whp for just intake + cat-back. Now, of course, 13whp is probably close to 18 hp at the crank, so you could probably realisitically claim around 183hp car While the stage 2 runs somwehre in the 190's at the crank.
ObsidianRS is offline   Reply With Quote
Old 07-16-2002, 09:48 PM   #12
AzNStiImpreza
Member#: 17181
2008 Impreza STi
Dark Grey Metallic
ok
Why Is The Engine Knocking Like Mad During Cold Snap? williaty Open Source Reflashes 7 01-03-2008 03:51 PM
Why is the MAIC so boring this week? VipersEatLotus Mid Atlantic Impreza Club -- MAIC 88 09-22-2006 08:49 PM
Is Cobb's Injen intake map made for the short or CAI? eshtog Factory 2.0L Turbo Powertrain 2 05-18-2005 08:10 PM
Why is my car starting like this?? SubaruImpreza_power Normally Aspirated Powertrain 18 10-25-2003 03:03 PM
Why is my Forester starting like this??? SubaruImpreza_power Service & Maintenance 5 10-01-2003 02:38 PM
Message Board Statistics All times are GMT -4. The time now is 06:39 PM.
