Old 02-06-2013, 10:32 PM   #126
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
^^thank you kind sir!
BigRob74 is offline   Reply With Quote
Old 02-08-2013, 12:03 PM   #127
CO11WRX
Member#: 304018
2011 WRX Sedan
TP Stage 1
Originally Posted by xluben View Post
Just clean it well and put some lube on the o-rings and maybe a little on the outside of the piston. You don't need to lube the top or bottom of the piston.
Thank you!
CO11WRX is offline   Reply With Quote
Old 02-16-2013, 07:26 PM   #128
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
Decided to try the green spring that came with it that was being raved about and it responded the best while letting off the throttle. But it felt very sluggish when building boost during partial throttle and even came up 1 psi short on my wot pull were im normally at 23psi on my 20g i was only hitting a little over 22. I then switched back to the yellow spring and it was back to normal and responds just fine and boost onset was quicker and hit 23psi again. Just thought i would share my experience im sure it is not the same for different applications.
nate_fisher is offline   Reply With Quote
Old 07-08-2013, 11:02 PM   #129
ltd.wrx_Matt
Member#: 361764
2012 Wrx Ltd
Grey Metallic
Is there any way using 100% recirc bpv, on a 2012 wrx to get the recirc sound audible without putting aftermarket sri, or a BOV on ? on my last turbo 2010 mazdaspeed 3, I had cobb sri, on and could really hear it...i kinda want that, but without messing with the intake, since they (forums state all need a tune for safe measure in our cars), and don't want to mess with certified warranty, factory warranty, plus dealer unlimited power train warranty.
ltd.wrx_Matt is offline   Reply With Quote
Old 07-08-2013, 11:31 PM   #130
J_Maher_WRX
Member#: 290307
In short, no. Putting even the forge BPV which is 100% recirc, or any aftermarket valve will be slightly louder than stock, but not worth buying for the difference it'll make. You need any intake at all and a BPV to really hear it.
J_Maher_WRX is offline   Reply With Quote
Old 07-08-2013, 11:58 PM   #131
A. G. Pym
Member#: 287398
2008 WRX Hatch
TP Stage 1
I've been running the forge BPV for over a year on the factory intake and there is absolutely no sound from it. I have the "second" version, though, which is the quiet one. It's awesome and does it's job and looks really good in black! If you want noise, you will need to get another bypass valve or blow-off valve. The Forge model won't make any noise (with the factory intake).
A. G. Pym is offline   Reply With Quote
Old 07-12-2013, 02:11 PM   #132
Ikkitousen
Member#: 354304
2012 WRX
I have an extra Green spring for $10 shipped if anyone is interested.
Brand new.
Reason why I went with the Green also was because when I boost in 5th on the hwy it would dump and have a little bit of surge. Now it recirculate smoothly and I noticed it doesn't dump as easily from 1st-2nd (which makes sense to me, why dump 2psi of boost while cruising slowly).
Ikkitousen is offline   Reply With Quote
Old 09-10-2013, 03:10 PM   #133
Rowrx11
Member#: 338312
hi everyone ! i need help... i have this forge for my 2011 wrx:
Uploaded with ImageShack.us
but i need the "flange" ... Where I can get that flange?
Rowrx11 is offline   Reply With Quote
Old 09-10-2013, 03:52 PM   #134
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
You got the wrong valve. Get the right one.
xluben is offline   Reply With Quote
Old 09-10-2013, 04:20 PM   #135
Rowrx11
Member#: 338312
I wanted to know if they could adapt .... was a gift.
Thanks anyway..
Old 10-19-2013, 09:54 AM   #136
nate_fisher
Member#: 270482
2011 turbotek fxt
Anyone have any issues with these leaking at the seams? I did a pressure test in search of leaks while hunting down a fuel trim issue the other day and found 2 leaks on my forge bpv. One was were the flange meets the valve it self and is screwed in from the bottom no matter how tight it would leak at the seam. The other is were the outlet for the turbo inlet return screws into the valve. The seam for the flange has a oring inside that seems to be to short so i got a thicker oring to help it seat better. The return outlet has no oring on it from the factory so i also installed a oring there as well. I will install it today and report back if it still leaks or not.
Old 10-20-2013, 08:33 AM   #137
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
mine seemed to leak there too with a soapy water test.idk. i took it all apart,cleaned and regreased. seemed better afterwards.
424wrx is offline   Reply With Quote
Old 10-20-2013, 08:54 AM   #138
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
what exactly are you re greasing? the spring?
Old 10-20-2013, 10:16 AM   #139
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
the piston where the spring sits.that unscrews and slides all apart. unscrew the bottom if i remember. i did it last year.
Old 10-26-2013, 04:08 AM   #140
Sidewinderpb
Member#: 312048
2011 BMW e92 335i
BSM
Thanks for the write-up Ben. This is the second thing that I've purchased based on your reviews; haven't been steered wrong yet!
Question for all Forge BPV owners: mine seems to have a short delay in releasing pressure, when compared to the stock BPV. The stock one would make the sound right when I let off the gas or shift. The Forge seems the have a delay between my shifting/letting off throttle, and the BPV sound.
Anyone else notice this?
I am running the yellow spring with no shims @ ~20lbs; no flutter or compressor surge (thankfully).
Thanks!
Sidewinderpb is offline   Reply With Quote
Old 10-26-2013, 05:44 AM   #141
Fstw3x
Member#: 369883
14 WRX SWP
I custom ordered the lightest green spring and it's been perfect, response is super fast between shifts and no flutter. I am @ 18 psi. I think the heavier spring the more delay, but I could be wrong. I'd wait for a few others to chime in.
Fstw3x is offline   Reply With Quote
Old 10-26-2013, 11:10 AM   #142
Rowrx11
Member#: 338312
I'm waiting for my forge bpv! I'll try the yellow spring without shims.*( 19-20 psi) .
I hope to have no problems with compressor surge without shims.
Old 10-26-2013, 12:11 PM   #143
secondchance
Member#: 219020
2010 STI
BLACK
Thanks!
Blue spring with 2 shims is very agressive and responsive.
Trust me
Should mention im running 19 psi with no surge issues what so ever.
secondchance is offline   Reply With Quote
Old 10-26-2013, 02:31 PM   #144
Rowrx11
Member#: 338312
Trust me
Mm really ? I thought to try the yellow spring with no shims. Now I'm confused with your comment. (19-20 psi ) .
Old 10-26-2013, 02:36 PM   #145
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
The spring/shims have nothing to do with how much peak boost you can hold. Only how fast it responds. A little spring will vent sooner. I liked the (special order) green spring the best. The included yellow one works well too. No need to go stiffer than that.
Old 10-30-2013, 12:54 PM   #146
Rowrx11
Member#: 338312
Forge Bpv installed!!! Perfect fitment...Yellow spring without shims ... sounds a bit higher with the aem intake, the response is much faster and the car feels stronger.
I have no sound of compressor surge ( shshshshshshshhhh )
I will make a video !
Old 10-30-2013, 03:09 PM   #147
danger1138
Member#: 279525
04 rex luger!
up to how many psi is the yellow spring rated up to on a subie?
danger1138 is offline   Reply With Quote
Old 10-30-2013, 04:10 PM   #148
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
The spring does not dictate how much boost it can hold. Yellow spring will hold more boost than your turbo can make.
Old 10-30-2013, 05:14 PM   #149
Rowrx11
Member#: 338312
I'm using the yellow spring and feel the car pretty well. I do not know what are the differences with the other colors....
Old 10-30-2013, 07:19 PM   #150
danger1138
Member#: 279525
04 rex luger!
Just checking. So 23 psi on a 16g xt should be fine then with the yellow spring.
FS : JNA front lip for 08+ wrx's, brand new jonnylin1 NWIC Private Classifieds 9 10-11-2010 02:12 AM
Forge BPV for sale DohcVtec NESIC Private Classifieds 7 04-21-2008 02:10 PM
WTT: Forge BPV for a BOV o2sys Engine/Power/Exhaust 11 05-05-2007 10:59 AM
Forge BPV for sale Adrenalin Rush Private 'For Sale' Classifieds 2 06-22-2006 12:56 PM
