Old 05-10-2012, 10:35 AM   #1
torto
Member#: 302283
Default thumping & oil light, wont start.
whats up having a small issue. so i bought a wrx was told it needed valve cover gaskets but ended up being head gaskets and heads not torqued down. long story short i did all maintenance i needed and put it all back together properly. i double checked everything but now when i go to start the car it doesnt start. it turned over after charging the battery a bit but i hear a thumping and my oil light came on but im not leaking (thank god). i was thinking it could be that my ecu may be fried. the car is a 2002 wrx if anyone could help itd be great, thanks.
torto is offline   Reply With Quote
Old 05-10-2012, 10:40 AM   #2
All4bSpinnin
Member#: 99102
08 Corvette Z06
problem Traction?
if your oil light is on, you've probably got something else wrong. did you put oil in it?
All4bSpinnin is offline   Reply With Quote
Old 05-10-2012, 11:38 AM   #3
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Did the engine actually run? Or thumping while cranking?
KillerBMotorsport is online now   Reply With Quote
Old 05-10-2012, 12:13 PM   #4
drewvdw
Member#: 255776
2010 LR WRX
MPS and PAR powered.
Did you get the timing belt back on correctly?
Old 05-10-2012, 12:16 PM   #5
Dave D.
Member#: 130990
06 Red Wagon hta68
MPS tuned JDM 6-speed
That would be my thought.
Old 05-10-2012, 12:33 PM   #6
wrxguy04
Member#: 261086
2004 Impreza WRX
Platinum Silver Metallic
1: timing belt
2: starter cable
3: your car is f*cked.
You choose
wrxguy04 is offline   Reply With Quote
Old 05-10-2012, 04:42 PM   #7
2012WRXY
Member#: 316057
2012 WRX
I choose number 3. Lol I hope you didn't buy my old wrx at auction cause this sounds like it!!
2012WRXY is offline   Reply With Quote
Old 05-10-2012, 06:29 PM   #8
wrxguy04
Member#: 261086
2004 Impreza WRX
^lmao nah man he needs good news, not downers!
Old 05-10-2012, 11:41 PM   #9
torto
Member#: 302283
timing belt is timing perfect oil light went off. put enough oil of it although i did find a leak on the oil feed line but i kept tring to start the car with the hood open. i shut the hood to give it a rest and i figured one more try and it started right up but wont stay started and my battery keeps needing a charge. i know the cars not ****ed it was running fine before i pulled it. i checked the ecu, checked out fine. also the thumping doesnt happen when the hoods closed.. so confused any takes on this?.. Also i appreciate all the help guys
Old 05-10-2012, 11:43 PM   #10
torto
Member#: 302283
gonna do some work on it tomorrow morning so like always any advise or thought are great maybe one of you know something that i dont.
Old 05-10-2012, 11:50 PM   #11
ohemgeeitsNiko
Member#: 239620
2003 WRX Wagon
your sheirda mobile is a sherida mobile. you gotta give it the rub conversion and it'll start right up. freakin' newbs.
ohemgeeitsNiko is offline   Reply With Quote
Old 05-10-2012, 11:57 PM   #12
mr.books
Member#: 223490
2010 wrx
white
im thinkin it could be a serious muffler bearing problem.....or even worse, continium transfunctioner.
mr.books is offline   Reply With Quote
Old 05-10-2012, 11:58 PM   #13
ohemgeeitsNiko
Member#: 239620
2003 WRX Wagon
lol. in all honesty though.
we swapped my ecu into the car and the same problems persisted. the thumping is coming from the fuel pump (sounds like a helicopter) and the vibrations can be felt through the fuel lines in the engine bay. thumping primarily happens when the battery charger is left on it. even though the key is OUT of the ignition. i checked all the relays, everything is connected properly. it's just really weird. the pump only primes properly when the hood is closed which is ****ing weird. it makes me think the hood is grounding something out.
the car has the factory alarm, so that rules out any killswitches. i plan on ripping out the turbo timer tomorrow, hoping that maybe it's causing interference in the wiring harness, or the kid who installed it screwed some **** up in the ignition and i'm gonna check over all the connectors in the engine bay.
it's very odd because the car ran somewhat smoothly before we even pulled the motor and we never really touched any of the electronics so there's no reason for any of this **** be going on. this thing is frustrating as hell. i know my way around a subaru pretty well but this thing keeps out playing me on every turn.
(HELP)wrx wont start and the dash lights wont come on EJ20IMPREZAREX Newbies & FAQs 22 03-24-2012 10:59 AM
New walbro thumping and car wont start edogg6565 Factory 2.0L Turbo Powertrain 0 04-12-2010 03:00 AM
Please Help! STi Overheated And Wont Start! Cruise Light Blinking! Sube-Doo Factory 2.5L Turbo Powertrain 8 11-06-2009 05:00 AM
Parking lights wont work now car wont start inevitable_101 Electrical & Lighting 0 07-21-2009 04:51 PM
Wont Start? Lights work, etc/ Heat??? All4BeSpinnin Service & Maintenance 1 06-03-2009 04:25 PM
Message Board Statistics All times are GMT -4. The time now is 05:56 PM.
