Old 03-09-2011, 03:06 PM   #1
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Default Honda says plug-in Accord will go 15 miles on battery
Honda says plug-ins will go 15 miles on battery
The new line of mid-sized plug-in hybrids that Honda Motor Co. aims to introduce next year will be able to travel up to 15 miles in electric-only mode, an executive says.
That would counter criticism that Honda's current hybrid technology is too weak to provide extended motor-only travel. The Integrated Motor Assist system used in the Honda Insight, Civic and CR-Z hybrids uses the electric motor mostly to assist the gasoline engine.
The new technology, which is scheduled to debut in 2012, is a two-motor system that runs on a lithium ion battery. The battery will be supplied through Blue Energy Co., Honda's battery joint venture with GS Yuasa Corp, said Hirohisa Ogawa, a chief engineer of battery research at Honda.
Ogawa, speaking at the International Rechargeable Battery Expo in Tokyo, said the new plug-ins would be able to run nine to 15 miles in electric-only mode.
Honda began testing the vehicles late last year, he added.
President Takanobu Ito has said his engineers are preparing to put the system in the Accord mid-sized sedan. Honda discontinued an earlier hybrid Accord, which was equipped with the Integrated Motor Assist system, in part because it was underpowered.
Old 03-09-2011, 03:08 PM   #2
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
According to a recent report, Honda will introduce an Accord Plug-in Hybrid sometime next year.
Details are limited, but the car will likely adopt the plug-in hybrid technology that was showcased at the Los Angeles Auto Show. This means we can expect the Accord to feature a 2.0-liter four-cylinder petrol engine, a 6 kWh lithium-ion battery, and an electric motor that develops 161 hp (120 kW / 163 PS).
Thanks to this setup, the Accord would be able to travel 10 to 15 miles (16 to 24 km) on electricity alone at speeds up to 62 mph (100 km/h). Furthermore, the battery could be recharged in 2 to 2.5 hours with a conventional 120 volt household outlet or 1 to 1.5 hours with a 240 volt rapid charger.
nmnmnm
Old 03-09-2011, 03:45 PM   #3
JuggernautTCW
Member#: 169223
i thought 15 miles was a typo and it actually was 150...
JuggernautTCW is offline   Reply With Quote
Old 03-09-2011, 03:51 PM   #4
SilverSubaab
Member#: 88288
.... At this point,
even I have lost track.
Wow, way to go Honda (to be read in a very sarcastic voice, with a borderline painful eye roll).........
SilverSubaab is offline   Reply With Quote
Old 03-09-2011, 04:09 PM   #5
MrSaabaru
Member#: 74709
2007 Solstice
05 Yamaha R6 & 04 Saab 93
this is good news. now i just need to convince everything in my life to move a little closer to where i live...
actually, work, home, the grocery store and most friends are all within a mile or two, but i wanted to comnplain.
the 15 miles seems a little silly. it's not enough for most commutes i'd say, as opposed to the volt it seems woefully underwhelming.
MrSaabaru is offline   Reply With Quote
Old 03-09-2011, 04:56 PM   #6
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
...10-15 miles on battery alone, unless you need heat or A/C.
Spenk is offline   Reply With Quote
Old 03-09-2011, 05:23 PM   #7
Scooby-Doode
Member#: 28976
2007 Twin Turbo
Spoolin'
What about the steering? Wonder if its EPS or Hydraulic.
Old 03-09-2011, 05:34 PM   #8
Kubek
Member#: 53222
'10 Genesis Coupe
'99 Miata
GM took $20k Cruze, put 16kWh battery in it and made a $40k Volt.
If Honda can take $23k Accord and put a 6kWh battery for ~$30k total, that's a better deal in my book. I live in city and I do a lot of short trips, my cars are usually cold and gas mileage is not so good. With 2 hour charge time, a could have my car always topped up.
Kubek is offline   Reply With Quote
Old 03-09-2011, 08:44 PM   #9
bal00
Member#: 54772
Good, because it doesn't have to be. Batteries are extremely expensive, which means you do not want to install more battery capacity than you can use in a day. If you need to run the gas engine for a few miles, that's no big deal. If your battery is not completely empty when you arrive at home, that is a big deal, because it means you spent thousands on batteries you're not using.
bal00 is offline   Reply With Quote
Old 03-10-2011, 03:18 AM   #10
Balantz
Member#: 101457
Czar of Sweet Dance
Moves
You, with the common sense - out. This is for zomgelectriccarzaredum!!1 comments only!
Balantz is offline   Reply With Quote
Old 03-10-2011, 07:58 AM   #11
Spenk
Member#: 7164
2000 Miata LS
Do you really think Honda wouldn't factor-in directional changes?
Old 03-10-2011, 08:07 AM   #12
Masterauto
Member#: 198376
STI E30 M3
Nissan GT-R 15
Can you drive it on a golf course?
Masterauto is offline   Reply With Quote
Old 03-10-2011, 08:23 AM   #13
MrSaabaru
Member#: 74709
2007 Solstice
I don't think you can compare the two, or at least you need an asterisk. sure the accord is bigger, but a cruze with the same options as a $23,000 accord wouldn't be $20,000. Also, just because they share a platform doesn't mean the cruze was the starting point. and it doesn't mean they are that similar.
to be fair, i did say i just wanted to complain. ...but seriously, i've heard of a lot of people who commute farther and farther to work because of the lagging job market. 15 miles isn't just not enough for a commute, it isn't even close in some places, making a normal hybrid like the prius probably just as cost efficient and green. at every other job i've held, before i moved from suburbs of detroit to fort wayne indiana, 15 miles wouldn't even get me to work, let alone a round trip and a trip to the grocery store. when the battery covers 30% of my drive, that's not the same as 'gets almost home, and it's better to charge from dead'...And i'm not sure it's better to charge from dead anyway. i don't know enough about the batteries, but it seems like they would have designed it another way. what if your trip is only ~10 miles? they don't expect you to drive in circles just to run it down the rest of the way. and they don't expect you to leave for work in the morning with only 5 miles left.
Old 03-10-2011, 08:30 AM   #14
Spenk
Member#: 7164
2000 Miata LS
^^^^^^ Perfect example of why these current plug-in hypebrids suck.
You're always left hauling around the extra weight, even if you're getting less than the full benefit from it. Screw that.
If some carmaker would grow a brain and produce a car that uses an onboard diesel generator to power an all-electric drive system (like a train engine), I'd fully embrace and become a promoter of such a car with religious-like zeal.
Diesel too dirty for you? Fine, let the generator run on CNG.
Old 03-10-2011, 10:04 AM   #15
MrSaabaru
Member#: 74709
2007 Solstice
sorta like a car version of the generators used on long haul vehicles. i know running a car is different from running a few accessories at a rest stop overnight, but carrying an engine that solely does charging for other stuff isn't such a foreign idea.
Old 03-10-2011, 10:18 AM   #16
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
Trains (heh, spenk even said as much)
Old 03-10-2011, 10:21 AM   #17
MrSaabaru
Member#: 74709
2007 Solstice
i was talking about trucking. i worked on a generator that bolted to the frame on 18 wheelers.
Old 03-10-2011, 11:50 AM   #18
bal00
Member#: 54772
Well those are two different issues. Lithium batteries will last longer if they're not fully charged or discharged. Vehicle manufacturers already take care of that by charging them to say 80% and discharging them to like 30%. They generally don't use the full capacity.
That's not what I was talking about though. Batteries are too expensive to include more capacity than your customers can use on a typical day.
Look at airlines for example. If they have enough passengers to fill 10 planes on a regular week day and 20 planes on the weekends, they're gonna go with the lowest common denominator, buy 10 planes and tell the extra weekend passengers to pound sand. Any additional planes would only see action on the weekends, and a plane that only flies 2-3 days per week is never going to make money. A passenger jet needs to be 80% full 7 days of the week to be profitable.
The same is true for batteries in plugin hybrids. Batteries that don't get used 100% every day cost more upfront than they will save you in gas over the life of the car, so if you have customers with 15, 30 and 45 mile commutes and you only want to offer one battery size, you have to go with the lowest common denominator and use a 15 mile battery.
Old 03-10-2011, 02:32 PM   #19
MrSaabaru
Member#: 74709
2007 Solstice
if your commute is more than double the battery capability, you're screwed. if your commute is 5 miles a day, 10 miles a day, it doesn't matter what kind of car you have. the cheaper thing to do is buy an inexpensive car anyway.
unlike gas cars, where you can fill up across the street from home and across the street from work, until they get charging stations everywhere, being too far away means you won't buy a plug in, a much worse thing from the standpoint of the car company than wasting a little battery life. or needing to use the rest of the charge tomorrow.
Old 03-10-2011, 04:02 PM   #20
Kubek
Member#: 53222
'10 Genesis Coupe
'99 Miata
This car can be charged in 2 hours from any wall socket, all you need is $20 extension cord.
Old 03-10-2011, 04:08 PM   #21
Member#: 67
1999 Outlasting
the competition.
AND if you plug in enough cords you can make it a lot further.
Old 03-10-2011, 04:16 PM   #22
boxerinside
Member#: 191994
Nice I'll just need to stop on my way to work for 2 hours to charge the batteries so I can make it.
boxerinside is offline   Reply With Quote
Old 03-10-2011, 04:19 PM   #23
Kubek
Member#: 53222
'10 Genesis Coupe
'99 Miata
You still have engine in your car. You don't have to relay on battery power to get where you wont to go.
Old 03-10-2011, 04:58 PM   #24
rallymaniac
Member#: 52189
2006 MINIiiiiii
yes, because common corporate or office buildings will let you run a cord to the parking lot from the lobby
rallymaniac is offline   Reply With Quote
Old 03-10-2011, 05:19 PM   #25
Kubek
Member#: 53222
'10 Genesis Coupe
'99 Miata
We have electric outlets next to every truck parking space (used in a winter to heat engine block), I could leave my car there when I take my truck.
Study Says Big Impact of the Plug-In Hybrid Will Be Decades Away AVANTI R5 Non-Subaru News & Rumors 23 01-28-2010 10:00 PM
Dems give up on compromise w/ Reps, will go it alone on healthcare Balantz Political Playground 224 08-24-2009 12:17 AM
*OFFICIAL* Thread where the Youtube video of Jane Fonda saying the C word will go Whitford Off-Topic 31 02-14-2008 10:52 PM
FS: 18x8 Compomotive MO's w/PS2's...less than 15 miles on both...$1675 shipped! Paulie Private 'For Sale' Classifieds 13 02-28-2005 07:20 PM
FS: silver sti bbs, will have 10 miles on them traction North West Impreza Club Forum -- NWIC 11 04-03-2004 05:56 PM
