Old 07-15-2002, 02:53 AM   #1
TaiChih
Member#: 3467
1998 Dinan3
Bleck
Unhappy N00b question, how to check for good ground?
DO I use a multimeter? Do I put it on the ohm setting and what reading should I get if it's a good ground. thanks,
TaiChih is offline   Reply With Quote
Old 07-15-2002, 03:03 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
set it to read ohms...measure the resistance between your ground wire(without touching it) and the area you wish to connect to.
Jeremy
Old 07-15-2002, 03:06 AM   #3
TaiChih
Member#: 3467
1998 Dinan3
Bleck
it's more like, how to check for a good ground at the ECU, at the harness plug.
Old 07-15-2002, 04:42 PM   #4
erice1984
Member#: 11778
1980 VWRabbit Diesel
w/AAZ Swap
I'm interested.. except the othe response wasn't very helpful. Need to be a little more descriptive/clear when you explain the motions of checking/doing something.
Thanks anyways,
-Eric
erice1984 is offline   Reply With Quote
Old 07-15-2002, 04:55 PM   #5
TaiChih
Member#: 3467
1998 Dinan3
Bleck
ah, ok, got it. if you use a multimeter, turn the meter to the highest ohm setting. test the meter by touching both probes together and make note as to where the ohm reading is. next, attach the + pos side of the probe to the wire you are testing and touch the - neg probe to the car chassis. If you have a good ground the ohm setting should jump to the original ohm reading, if not, then yo have a bad ground. good luck all and thanks for the help.
how to check for properly groundings? jacky599r Electrical & Lighting 4 02-07-2009 12:48 PM
How to check for a bad caliper? kainam00 Brakes, Steering & Suspension 8 09-29-2006 10:27 PM
how to check for an exhaust leak? paosti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 09-11-2006 08:59 AM
How to check for broken timing belt ? Legacy Normally Aspirated Powertrain 4 07-10-2006 10:20 PM
How to check for available vanity plates? gregaruWRX Off-Topic 5 09-09-2005 06:25 PM
