Old 03-09-2011, 08:58 PM   #1
kometo
Member#: 230792
02 OBS 5mt
PSM/Graystone
Default Does the engine oil pressure warning light dim?
The engine oil pressure warning light is on in my '02 OBS, sort of. I just got back from a 5 day vacation and started it up. Oil pressure warning light lights up along with the seat belt light when started, then OP light goes out, but then comes back on although very dim. First time it's ever done this. Oil level is ok and no oil on the ground.
Does the OP warning light dim, and if so, why? Or should it only be on or off if OP is low?
Thanks
kometo is offline   Reply With Quote
Old 03-09-2011, 09:46 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
clean it.
Old 03-09-2011, 10:03 PM   #3
Wrencher86
Member#: 250463
2010 Impreza 2.5i
Originally Posted by yarrgh View Post
clean it.
Clean what?
OP:
I'm not sure how Subaru has their light wired up, but usually the oil pressure light is grounded through the sensor. When you turn the car on the oil pressure inside the sensor pushes on a diaphragm and moves a set of electrical contacts apart, removing the ground and making the light go out. It's either on or off, like a light switch.
If the light is on dimly it (usually) means that the bulb is getting a partial ground somewhere. The sensor could be bad, there could be a short somewhere or something could be backfeeding into the wiring. Get yourself a wiring diagram and check for power and ground. It should be a pretty simple system.
Wrencher86 is offline   Reply With Quote
Old 03-09-2011, 10:42 PM   #4
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ You pretty much got it. It's a grounding issue.
Tighten it a touch and the light usually goes out. This is pretty common for cars that see a lot of moisture. It can be removed and cleaned/replaced too. I've neaver heard of it being anything other than the sensor connection to the block so that's a good place to start.
If there's an oil pressure problem is will be ON
KillerBMotorsport is online now   Reply With Quote
Old 03-09-2011, 11:20 PM   #5
kometo
Member#: 230792
02 OBS 5mt
PSM/Graystone
Thanks for your replies and great info. I'll check the sensor, connections and wires.
oil pressure warning light on when engine cold usenet4life Normally Aspirated Powertrain 10 01-14-2008 08:00 AM
oil pressure warning light Sublime5260 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 06-12-2004 04:07 AM
Help please Oil Pressure warning light blueimpreza25rs Tri-State Area Forum 4 10-27-2003 12:10 PM
Oil Pressure warning light WRX_junkie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-25-2002 04:44 PM
How does the factory oil pressure sending unit work? Jasno999 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-13-2002 02:16 PM
