Old 03-10-2011, 01:11 PM   #1
rallyvovo
Member#: 167738
Default Timing Cover Gasket
Do you need to replace timing cover gasket if you pop it off to inspect condition of the timing belt?
rallyvovo is offline   Reply With Quote
Old 03-10-2011, 01:15 PM   #2
95imprezagc8
Member#: 218001
1995 impreza
carriban green
if its stretched like mine..than yeah.
95imprezagc8 is offline   Reply With Quote
Old 03-10-2011, 01:18 PM   #3
rallyvovo
Member#: 167738
So basically, if it fits back in to its grooves youre good to go?
Old 03-10-2011, 01:27 PM   #4
BDZ
Member#: 246673
You should be.
When I replaced my timing belt the gasket was compressed so it got replaced with a new one that fit tighter.
BDZ is offline   Reply With Quote
Old 03-10-2011, 01:54 PM   #5
95imprezagc8
Member#: 218001
1995 impreza
carriban green
yea if it sits back in your good. but most of the time it doesnt. good to have one on hand just incase. if you dont need it return it.
Old 03-10-2011, 02:36 PM   #6
rallyvovo
Member#: 167738
turns a damn checkup into a $30 job!
Old 03-11-2011, 10:29 AM   #7
BDZ
Member#: 246673
How many miles are you at?
If its less than 105k why does it need checking?
Old 03-16-2011, 10:31 AM   #8
rallyvovo
Member#: 167738
194k on it.
My guess is its either excellent or F'd. Going on a 2k+ road trip in a month and need to cover some bases! Plus i have a front (something) seal leak i need to inspect.
i need the bottom timing cover gasket. ASAP!!!! wrxej205 Private 'Wanted' Classifieds 4 03-07-2009 03:09 AM
FS: ej25 water pump/cam seals/oil pump seals/timing belt cover gaskets sti charles Engine/Power/Exhaust 24 11-02-2008 02:10 PM
ej207 timing covers=stock wrx timing covers? skate enjoi Subaru Conversions 13 06-20-2008 10:54 PM
Timing belt cover gasket Tomnel Service & Maintenance 8 02-10-2004 01:28 PM
Timing Belt Cover Gasket??? I3eXa Normally Aspirated Powertrain 4 03-06-2003 03:53 AM
Message Board Statistics All times are GMT -4. The time now is 01:24 PM.
