Old 07-02-2011, 10:17 PM   #51
bwrx03
Member#: 174372
Baby Im gunna butter
your biscuits
Got my tune today worst possible day being 90 degrees out, but had interesting results. First pull the air sensor maxed out and threw a cel. The intercooler has a **** ton of flow. The tuner kept saying how impressed he was with the intercooler and flow rate. Had a couple problems, first was the radiator for the IC. The radiator cap that came with it was opening when the water got hot after 10+ pulls. So they had to close off the over flow with some tubing, I'll be buying a 1.3 bar cap to fix that. Second problem is he maxed my injectors so I need 750cc's. So he turned down the boost to 15psi. Making 308hp and 338tq for now. Also the fan that was infront of the car stopped working so I was running hotter than usual.
To answer a few question. No you don't need a thermostat you just need a anti freeze mix
Ive seen people do a half size radiator then putting the IC radiator next to the smaller engine radiator. You could do that to keep your bumper beam.
My tuner loved tuning with this setup.
bwrx03 is offline   Reply With Quote
Old 07-02-2011, 11:51 PM   #52
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Originally Posted by bwrx03 View Post
No you don't need a thermostat you just need a anti freeze mix.
Figured as much.
OrbitalEllipses is offline   Reply With Quote
Old 07-11-2011, 04:36 PM   #53
blue_wrx_chic03
Member#: 34519
03 WRX
WRX blue
i had a similar air to water setup on my car but i had a larger water tank in trunk and lager intercooler i think. for the heat exchanger i had fluidyne 03 cobra one from summit. my setup never got to hot and ever spit water. water temps stayed nice and low during dyno runs and street runs. even better was the heat was 90 degrees and the one bag of ice yielded three runs with air temps below 60 at wot.
blue_wrx_chic03 is offline   Reply With Quote
Old 07-14-2011, 10:46 PM   #54
bwrx03
Member#: 174372
your biscuits
Any pics?
I decided put ice in my tank this morning. The ambient temp was 69 and the intake temp dropped to 59. Water temp gauge was below 70 that's all i know, when the gauge is below 70 it only reads LOW so I'm not sure of the temp. Unfortunately it only lasted about 25 minutes through traffic, then the water temp picked up to around 75 degrees and the intake to 83 degrees. I also put red line water wetter in the system, huge waste of money it didn't do ****.
Also i got my new radiator cap on so the leakage is stopped.
Old 07-15-2011, 07:14 AM   #55
svynx
Member#: 210371
2002 hybrid 16gxt
'03 Lifted TS
Any pics?
I'll be adding it as well when the system is finished (again, hopefully this weekend). It does help a little as far as keeping temps down, but the main reason is to keep the water from freezing during the winter.
svynx is offline   Reply With Quote
Old 07-15-2011, 11:08 AM   #56
bwrx03
Member#: 174372
your biscuits
I ran my car for 30 mins in 85 degree weather, the water temp was 80 degrees when i stopped. I put in two bottles of water wetter and jumped on the freeway and drove 40 miles. Weather temp raised to 87 on the way and the water temp raised to 84. I understand the non-freezing part, but it doesn't do anything for the temps. Atleast from what i saw.
Old 07-15-2011, 02:53 PM   #57
blue_wrx_chic03
Member#: 34519
03 WRX
WRX blue
i will find a pic of the rest of the stuff but i am running a 03 cobra water intecooler pump and fluidyne 03 cobra heat exchanger in the front. it was over 90 ambient while dynoing and then with ice air temps where 60 or less for about a hour.
Old 07-17-2011, 10:15 PM   #58
blackpearl44
Member#: 272581
2008 WRX STI
GREY
How does your cobra watercooler pump compare to Meziere pump?
blackpearl44 is offline   Reply With Quote
Old 07-20-2011, 01:16 AM   #59
omiotek
Member#: 272090
so when doing this are you guys having to fill the water tanks daily? how do you go about hook up for all this for DD purposes... im doing a supercharger build on my gc. figured this would be better then air to air for sure.
omiotek is offline   Reply With Quote
Old 07-20-2011, 07:27 AM   #60
svynx
Member#: 210371
2002 hybrid 16gxt
'03 Lifted TS
Quick answer would be no, you don't have to fill daily. Honestly in a perfect world you would only fill once. But, since there can be some evaporation from somewhere, it isn't a bad idea to check the level once in a while. As far as install, the main parts would be the radiator, pump, and the core. A reservoir box does help, but i feel that if the radiator is big enough, you wouldn't need one.
Update on my build: the reservoir box and the intercooler pipe with the bpv flange welded to it has a second coat of epoxy to seal any leaks. Just waiting for that to dry and I can install. Getting close now.
Old 07-21-2011, 01:24 AM   #61
omiotek
Member#: 272090
gotcha. yeah im just debating right now if i should spend some extra money and go air to water or go air to air with my m90 supercharger build....car will be a dd here in chicago.
Old 07-26-2011, 06:28 PM   #62
bwrx03
Member#: 174372
your biscuits
Nice setup wrx_chic what kind of power did you make? If you don't mind me asking.
And any progress on your build svynx?
Old 07-30-2011, 04:42 PM   #63
svynx
Member#: 210371
2002 hybrid 16gxt
'03 Lifted TS
^^^ yup. Only a little though. All parts have been welded, sealed, and painted. All that is left is the install itself. I'm out of town right now, so the plan is to do the install on Aug 6 along with my trans work. It's been a long time coming now, but there is finally light at the end of the tunnel.
Old 08-10-2011, 05:27 PM   #64
lager478
Member#: 247163
2010 WRX
Pearl White
debating on whether or not to go w2a, a little concerned about reliability though. What happens if the water pump fails? possibly blow up the engine?
lager478 is offline   Reply With Quote
Old 08-10-2011, 08:59 PM   #65
bwrx03
Member#: 174372
your biscuits
I can't say for sure but I don't think it would blow the engine. The water in the IC would get hot as **** with prolonged driving, but if you're an aware driver you should know if your pumps are working or not. The pumps going out are my main concern and so far my bilge pumps have been awesome. What I've learned from all my electronics classes are that electronic motors last about 50,000 hours. Which for me is close to a years worth of driving. If I were you I'd do the same thing i did with the bilge pumps that have the quick change cartridges. I spliced in quick disconnect connectors for the power and ground to the pumps. Then bought new pump cartridges put on the same quick disconnects, so if I'm on the road when the pumps go out I can quickly change them. It's really up to you if you want a AWIC, but from my experiences they're the best IC for any application. Hope this helped.
Old 08-10-2011, 10:07 PM   #66
lager478
Member#: 247163
2010 WRX
Pearl White
Thanks for the input, helped a lot.I guess a water temp gauge like the one you installed would be the best way to monitor the IC water temps? I like your quick change pump idea, I read your post about that earlier in the thread. What pumps did you end up getting? Im assuming you went to west marine or a similar store to get them. Would really like to try this out instead of going with an aftermarket tm or fm.
Only other thing I didn't really like was using my trunk space/not having my spare. Maybe I could mount the battery in the trunk and the fab a reservoir to mount in the engine bay.... it would have to be small though, maybe have heat soak problems? maybe mess up weight distribution also.
Old 08-10-2011, 10:44 PM   #67
bwrx03
Member#: 174372
your biscuits
I went with Johnson's bilge pumps from west marine. I took out the spare tire when i put on bigger wheels,(nearly 2 years ago) since the spare would screw with the center diff mixed with the 18's i have on. I DO NOT track anymore, just from all the damage I caused my car. I have more than 90 hours of track time in this car alone, so I'm really not desperate for more. So i couldn't comment on engine bay heat soak. But anything in the enginebay will absorb more heat than the trunk. You could do what I think svynx is trying and put the box in a wheel well. Then go to a custom wheel/alignment guy and do a corner balance to make up for the extra weight.
Old 10-05-2011, 08:46 PM   #68
svynx
Member#: 210371
2002 hybrid 16gxt
'03 Lifted TS
I guess it's time to show the progress. I'm short one hose to complete this project. Seems like there is always something going on to hold me back from finishing this. Here's some pics thus far.
I've finished the piping from the turbo to the cooler. The hose that I need now is to connect the BPV back into the turbo inlet. Once that is done, the system is done. I've completed the leak test and happily found no leaks.
Old 10-06-2011, 08:34 AM   #69
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
looks nice..frozen boost kit?
Old 10-06-2011, 09:03 AM   #70
svynx
Member#: 210371
2002 hybrid 16gxt
'03 Lifted TS
Yup
Old 10-06-2011, 02:31 PM   #71
draco159
Member#: 204121
2005 WRX Wagon
CGM
So it just sits on top correct, you didn't have a bracket made or anything? Looks awesome!
Oh and what do you do with the two tapped openings on the TB side of it?
draco159 is offline   Reply With Quote
Old 10-06-2011, 04:21 PM   #72
svynx
Member#: 210371
2002 hybrid 16gxt
'03 Lifted TS
I didn't have to make a bracket because the silicone cuplings are stiff enough to hold things in place.
The openings there do not go all the way through. I'm just going to leave them be. I might fab up a bracket at some point just to add some stability, but it's not needed.
Disclamer: I'm only talking about the core I have. Some are bigger, or different sizes and might require brackets.
Old 10-11-2011, 04:18 AM   #73
Alistairh
Member#: 268286
2011 STi
Dark Grey
So, I've been toying with going WTA for a long time, and never really got the whole FMIC thing.
Thinking of grabbing a properly sized WTA IC from frozen boost, putting the IC directly between the turbo and the TB, and mounting the rad where my FMIC was.
Does anyone have dyno graphs showing decreased spool time? Seems to me that if you removed the 8 feet of intake piping, you might be able to spool a few hundred RPM's quicker.
Alistairh is offline   Reply With Quote
Old 10-11-2011, 07:46 AM   #74
svynx
Member#: 210371
2002 hybrid 16gxt
'03 Lifted TS
I can't help you there. I really wasn't looking at spool time when I decided to do this. But common sence says that if you are switching from a standard front mount, your spool time will decrease because of you not having to pressurize all the piping and the much larger/thicker core.
Old 10-11-2011, 08:15 AM   #75
Alistairh
Member#: 268286
2011 STi
Dark Grey
That's exactly what I'm thinking as well.
I'm kind of curious if I could upgrade to a 35R from my 3076R and get more HP, and be well on my way to spoolin' by ~3300 RPM.
What the heck is this on his intake manifold? air/water intercooler?? STR8OUT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 03-25-2003 12:27 PM
STi air-water intercooler?? kotaro Legacy Forum 22 12-19-2002 01:51 PM
Air/Water intercooler install, any suggestions? BlueDemon South East Region Forum 3 08-25-2002 09:39 PM
Air/Water intercooler? FuZZyLoGiC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-29-2002 11:45 PM
Interesting Air/Water intercooler thought Legacy GTR Normally Aspirated with bolt-on Forced Induction Powertrain 9 02-13-2002 11:53 PM
