Old 03-10-2011, 06:21 PM   #1
chickennecks?
Member#: 247605
2002 impreza ts
Default Random Po302 cel..... help.
Got my h/g's, timing belt, waterpump, clutch done about 5k ago. Ever since, i have been getting a random cylinder #2 misfire code. Usually at idle. The mechanic has checked it, and last time said it was a bad plug. Still getting it though. Any suggestions greatly appreciated. Its an '02 ts.
chickennecks? is online now   Reply With Quote
Old 03-10-2011, 06:47 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
is there oil on the spark plug? how's the valve lash? run injector cleaner through it lately?
you can switch spark plug wires to see if the code follows that. you can switch injectors to see if the code follows.
Old 03-10-2011, 06:58 PM   #3
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
Try/chk all yarrgh's suggestions as they are all easy and free to do, then go from there.
Is your name an offer? If so, yes please.
RaceFaceXC is offline   Reply With Quote
Old 03-11-2011, 03:48 PM   #4
chickennecks?
Member#: 247605
2002 impreza ts
sure its an offer, but it will cost ya....
thanks for the help
Old 07-10-2011, 07:53 PM   #5
chickennecks?
Member#: 247605
2002 impreza ts
Update! switched injectors , switched plug wires, new plug, reset ecu...still getting code! What next? new coil pack?
Random Po302 cel???? chickennecks? Vancouver Impreza Club Forum -- VIC 8 04-18-2011 07:55 PM
Upgraded exhaust, will borla, and random cause CEL? steven765 Baja Forum 9 06-07-2010 04:11 PM
Randomly threw CEL, flashing cruise light... Falkon Service & Maintenance 3 04-19-2010 01:48 AM
Strange PO302 code, help please(03 wrx) 0260B4U Service & Maintenance 0 03-23-2009 08:49 PM
Random CEL, HELP! SubWRX2104 Newbies & FAQs 4 03-02-2009 01:13 PM
Message Board Statistics All times are GMT -4. The time now is 05:29 PM.
