Old 07-15-2002, 10:42 AM   #1
rangere7
Member#: 1955
Default tec-3 iac
Has anyone used the iac with the tec-3 yet? I am getting a kicking motion at closed throttle, the book says to check the iac. Does anyone else have this problem? If I give it gas then cut it back in any gear, more so in the lower ones, it will buck like I am on a bull. I am afraid that this will brake my trans one day.
Thanks,
Rangere7
rangere7 is offline   Reply With Quote
Old 07-15-2002, 06:28 PM   #2
Austin
Member#: 7089
2016 STi
What do you mean a kicking motion at closed throttle?
Around what RPM's does this happen?
What are your hot and cold DECEL values? DCCL0 and DCCL1
What is your DECEL activation value? DCCL2
Austin is offline   Reply With Quote
Old 07-15-2002, 11:48 PM   #3
Z1 Performance
Member#: 9327
are you using the TEC as a full standalone, or piggybacked to the factory ecu?
On a Subaru, you are far better of leaving the stock ecu controlling idle and the a/c, and let the TEC do the rest
adam
Z-1 Performance
Z1 Performance is offline   Reply With Quote
TEC 3 IAC wireing ChAi Engine Management & Tuning 36 06-10-2004 07:29 PM
WTB: TEC-2 or TEC-3 Boost4U Private 'Wanted' Classifieds 3 11-18-2003 10:10 AM
Good News for PossumLink, LinkPlus, Tec-2, and Tec-3 Owners! DataLogLab Engine Management & Tuning 18 04-24-2003 05:49 PM
Electromotive TEC-3 Skidd Normally Aspirated with bolt-on Forced Induction Powertrain 6 09-26-2001 11:09 PM
Has anyone heard to much about the TEC 3? E'scubi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-16-2001 11:24 AM
