Old 03-10-2011, 10:56 PM   #1
CambridgeRS
Member#: 236337
2000 Impreza GC6
Default Flywheel Confusion
OK Guys.....
I've been searching this problem for a couple of hours and I'm not getting anywhere.....
I'm about to swap an '07 WRX engine into a '99 Forester. The only question I have is.....will the WRX flywheel and clutch fit the Forester tranny?
I already know that both trannys have the same O.D.(25.2mm) and the same number of teeth(24). This makes me believe the the spline shaft isn't an issue, but what about the overall diameter of the flywheel? Is the WRX flywheel a larger diameter?
Any comments are good ones!
Thanks...
Jeff
CambridgeRS is offline   Reply With Quote
Old 03-11-2011, 12:12 AM   #2
CGMDan
Member#: 127883
'09 C63 AMG '99RSTi
'05 CGM STi - RIP
The bigger issue is are they "push" or "pull" type clutches.
CGMDan is offline   Reply With Quote
Old 03-11-2011, 07:37 AM   #3
CambridgeRS
Member#: 236337
2000 Impreza GC6
Both the '06-'07 WRX and '99 Forester have the push style clutch......
Old 03-11-2011, 04:01 PM   #4
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
you'll be fine. Same flywheel, same clutch action, same clutch....
well same should say interchangable.
confused on starter/flywheel zigzag801 Normally Aspirated Powertrain 7 03-19-2012 04:19 PM
Bar's "No Colors" sign confuses the easily-confused. Wagon Of Fury Off-Topic 32 12-04-2009 01:15 PM
Flywheels sale = clutchmasters aluminum flywheel 9 lb + stock flywheel grofry Drivetrain 4 03-09-2009 11:07 AM
Flywheel confusion! Flywheel, engine, clutch compatibility Schimke Transmission (AT/MT) & Driveline 4 03-16-2007 01:39 AM
Confused confused...need help Genner Electrical & Lighting 1 05-11-2004 04:09 PM
