Old 03-11-2011, 04:34 AM   #1
JoePokah
Member#: 154734
2005 Legacy GT LTD
Default Airbag Swap Question
I have a 98 rs and i am finishing swapping a complete 02 wrx into the rs. Everything from rear end, to transmission, engine, dash, wiring harness, steering column..., etc. Would i want to use the airbag from the wrx even though i just swapped EVERYTHING over? I could be completely off here but would it be a bad idea to put airbags from one car to another like that in a swap not knowing much about airbags at all? Could the airbags come out at a different angle than originally anticipated because of the difference in vehicle and slight changes in the positioning of both driver and the wheel itself? It seems to all match up but i am thinking full harness will do more for me than an airbag? Any input would be great as i want to finish the wiring and put it back together , but am still on the fence on this. Thanks,
Jeff
JoePokah is offline   Reply With Quote
Old 03-11-2011, 10:18 AM   #2
AKGC8
Member#: 1305
2000 Impreza
Yeah, the dimensions of the GD and GC are close, but nobody can say for sure how they will perform in the GC since they were not designed or tested for that chassis. Rather than play crash test dummy for the swap community I opted to pull the entire airbag system from my swap. Saves a good amount of weight so that's a plus.
The most important thing in a crash is wearing your seatbelt. If you're doing that, airbags will not make a huge difference.
AKGC8 is offline   Reply With Quote
Old 03-11-2011, 06:04 PM   #3
JoePokah
Member#: 154734
2005 Legacy GT LTD
Sounds like i was thinking correctly then. It looks like i am going to do no airbags and just add in harness and seats. Thanks for the input, if anyone else has anything to add that would be great. Otherwise i am just going to opt to take the airbags out.
Jeff
Old 03-23-2011, 01:01 PM   #4
ASHKIRA01
Member#: 277625
Are You Selling The Airbags
ASHKIRA01 is offline   Reply With Quote
Old 03-23-2011, 08:57 PM   #5
JoePokah
Member#: 154734
2005 Legacy GT LTD
Depends how swayed i am by a price
Full WRX to STi airbag swap Einherjar Subaru Conversions 6 03-06-2008 11:54 PM
Airbag swap 98 outback to 06 sti what do i need? elsanto Subaru Conversions 0 02-11-2008 03:06 PM
Definitive answers needed on airbag swap. elsanto Electrical & Lighting 0 12-12-2007 11:28 PM
Will an 04 sti airbag swap directly into an 03 wrx steering wheel? Nettalp Newbies & FAQs 1 01-27-2006 05:51 PM
RS -> WRX airbag swap.... DoorKnob Bay Area Impreza Club Forum -- BAIC 0 10-28-2001 12:30 AM
